• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
Locked
0
flash player was uninstalled by an anti virus program, now i cant download and reinstall
New Here ,
Apr 18, 2018 Apr 18, 2018
tile says it all. I was using a Cogeco Cable systems antivirus program that uninstalled Flash player on windows 10 with the company installed browser and it has turned into a severe headache trying to get it reinstalled. not using the edge browser.
Views
374
Translate
Translate
Report
Report
Community guidelines
community guidelines
Adobe Employee ,
For which browser are you attempting to install Flash Player for?
<edit>
what happens when you try to download Flash Player?
Votes
Translate
Translate
Report
Report
New Here ,
Apr 19, 2018 Apr 19, 2018
Internet explorer not sure of which version,
Came installed about 3 years ago
Sent from Mail<https://go.microsoft.com/fwlink/?LinkId=550986> for Windows 10
Votes
Translate
Translate
Report
Report
Adobe Employee ,
See my reply above.  Flash Player is built-in to Internet Explorer on Windows 10.   You can try removing and reinstalling the last Windows Update that affected Flash and/or Internet Explorer.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
LATEST
Essentially Cogeco Cable's anti-virus should not be deleting the embedded Flash Player ActiveX on Windows 10. Microsoft considers this a component of the browsers and locks the files so users can't easily delete it (without jumping through hoops).  Since Microsoft embeds Flash Player ActiveX in IE and Edge on Windows 10 there is no separate installer to install it and all updates are distributed by Microsoft via Windows Updates.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
You'll want to download Flash Player from the browser that you actually want to use.
Flash Player is a built-in component of Internet Explorer and Edge.  If your antivirus managed to uninstall those, that's more complicated, as they're not directly installable and we don't distribute installers for them.  ]
If that's what happened, I generally have good luck with removing and replacing  the last update for Flash Player that you can find under Settings > System > Apps and Features.  Once removed, reboot and then run Windows Update again to reinstall.
If that doesn't work, the Windows System File Checker, might sort it out:
https://support.microsoft.com/en-us/help/4026529/windows-10-using-system-file-checker
For Google Chrome, Flash Player is also built in, so removing and reinstalling Chrome might be the easiest solution.
For other browsers, simply go here, and we'll give you the appropriate installer for the browser you're using:
https://get.adobe.com/flashplayer
If that's not working, you might uninstall Flash Player first, in case the antivirus product left things in bad state:
Uninstall Flash Player - Windows:
https://helpx.adobe.com/flash-player/kb/uninstall-flash-player-windows.html
If none of that helps, installer logs would give us a good idea about what's failing.
Instructions are in the troubleshooting guide below:
https://helpx.adobe.com/flash-player/kb/installation-problems-flash-player-windows.html
Votes
Translate
Translate
Report
Report
