4 Replies Latest reply on Apr 18, 2018 1:53 PM by JohanElzenga
    importing photos makes lightroom ad some changes to the photos
    davids85978952
      importing photos makes lightroom ad some changes to the photos i don't want.
      Ive been importing no problem at all and all of sudden lightroom start to make some changes to the photo's automatically. I carefully watch that everything is unchecked when i do my import but still the changes are made. How can i turn this off?
        • 1. Re: importing photos makes lightroom ad some changes to the photos
          dj_paige Level 10
          If you are importing RAW photos (are you?), this is perfectly normal and cannot be turned off. Lightroom uses the JPG preview inside the RAW file to display the photo initially, and then after Lightroom has time to make it's own rendition of the RAW photo, it shows that to you.
          You can apply develop presets at the time of import so that the initial rendering of the photo is more to your liking (for example, higher contrast, higher saturation, etc.)
          • 2. Re: importing photos makes lightroom ad some changes to the photos
            davids85978952 Level 1
            Yes I shoot in raw,  a flat image that contains all the info. I want to work with this image, before this was possible. Now lightroom opens up the shadows add brightness etc. Stuff i can not undo and this makes it harder for me to because i have to manually undo everything tone down the sharpness,   camera settings you name it. It never did this before !!! I was until recently able to start with the flat image.
            • 3. Re: importing photos makes lightroom ad some changes to the photos
              Then what has changed? Lightroom always applies default settings. As DJ mentioned, Lightroom first displays the embedded JPEG preview which includes in-camera adjustments that could have been applied to that JPEG preview and probably were applied to the raw image. But Lightroom does not read those adjustments made to the raw images because every camera maker stores those adjustments differently. That's why Lightroom has to provide specific support for each new camera model. You could create new camera defaults that reflect the way you want your raw images to appear.
              • 4. Re: importing photos makes lightroom ad some changes to the photos
                JohanElzenga Adobe Community Professional
                It sounds like you either apply a preset on import (maybe without even realising it), or that you have (again perhaps without realising it) changed the camera defaults. So do two things:
                1: Check in the import panel that you do not apply a develop preset on import
                2: Select one of those images in the develop module and press the 'Reset' button. Does that not change the settings back to zero? Then you have indeed changed the camera defaults by mistake. In that case, hold the shift-key and press that button again. Its name should change to 'Reset (Adobe)' and the settings should go to zero. Then press that button once again, this time while holding the Alt-key. That allows you to update your camera default to the current settings (and these are the Adobe settings now).
