I am trying to write equations using javascript in illustrator.
Equations might be having superscript and subscript. When I run the script, I need a prompt where, I will write some inputs like
a^{2}+b^{2}=c^{2}_{2}
And after hitting enter, I need the equation to be like
a2+b2=c22
I had tried something, but its not working properly.
if(documents.length >0){ //if document is open
if(app.activeDocument.selection[0]){ //if a line is selected
var doc = app.activeDocument; //getting the active document
var line = doc.pathItems[0]; //getting path items from the active document
var firstPoint = line.pathPoints[0].anchor; // [x, y]
var lastPoint = line.pathPoints[line.pathPoints.length - 1].anchor; // [x, y]
var graphValues = (prompt("Enter something", "", "")); //getting the values to write
var newPowerValue="";
var ii=1;
var items=[];
if(graphValues.indexOf("^")>0){
PoweredValues=graphValues.split("^");
BaseValue=PoweredValues[0]; //getting base value from the array
PowerValue=PoweredValues[1]; //getting power value from the array
for( i=0; i<PowerValue.length; i++){
if(i>0 && i+1!=PowerValue.length){
newPowerValue=newPowerValue+PowerValue;
ii= doc.textFrames.add(); //adding text
ii.textRange.characterAttributes.size = 8; //character size for text
ii.textRange.characterAttributes.textFont = app.textFonts.getByName("Times-Roman"); //for changing the font to times-roman
ii.textRange.justification = Justification.CENTER; //for aligning the content to center
ii.top = firstPoint[1]; //x coordinate for the new value
ii.left = firstPoint[0]; //y coordinate for the new value
finalContent = BaseValue+""+(Number(newPowerValue));
finalContent=finalContent.toString();
var finalContentcheck=Number(finalContent.indexOf("-"));
if(finalContentcheck>=0){
finalContent=finalContent.replace(/-/g,"–");
ii.contents=(finalContent);
var t = doc.textFrames[0]; // adding text
thisChar = t.characters[BaseValue.length]; //writing base value
supStop=newPowerValue.length+BaseValue.length;
for(var j=BaseValue.length;j<=supStop-1;j++){
; //writing base value thisChar.characterAttributes.baselineShift = +3; //making superscript
thisChar.characterAttributes.size = 6; //adjusting size of superscript
I am new in this scripting. Thanks in advance for the help.
Try this
...var aSample = "a^{2}+b^{2}=c^{2}_{2}";
var aDoc = app.activeDocument;
var aTF = aDoc.textFrames.add();
aTF.position = [10, -2];
aTF.contents = aSample;
aTF.textRange.size = 8;
aTF.textRange.characterAttributes.textFont = app.textFonts.getByName("TimesNewRomanPSMT"); //depends on your Illu version and installed font
var res, idx;
var reg = /\^\{/g;
while (res = reg.exec(aTF.contents)) {
idx = res.index;
aTF.textRange.characters[idx].remove();
aTF
Your code doesn't make any sense. You are not manipulating arrays, you are merely incrementing values. Perhaps you should start by reading up on how arrays in JavaScript actually work and which methods can be used to manipulate them?
Mylenium
Here I just made the equation
a2
from a^{2}
I couldn't get any idea to make the equation like I said in the question.
Use the property of characterAttributes
FontBaselineOption.SUBSCRIPT and
FontBaselineOption.SUPERSCRIPT
Have fun
What happens?
Try this
var res, idx;
var reg = /\^\{/g;
idx = res.index;
aTF.textRange.characters[idx].baselinePosition = FontBaselineOption.SUPERSCRIPT;
aTF.textRange.characters[idx+1].remove();
var reg = /_\{/g;
idx = res.index;
aTF.textRange.characters[idx].baselinePosition = FontBaselineOption.SUBSCRIPT;
aTF.textRange.characters[idx-1].tracking = -480; // TimesNewRomanPSMT
Have fun
