Everytime I export from Premiere to Media Encoder i get this:
[/Pr12.1/releases/2018.02/shared/adobe/MediaCore/Backend/Src/Content/AudioMediaContent.cpp-570]
what gives?
Thanks for the tip.
It did not solve the issue.
But I now assume it has something to with dynamic link to after effects. The timeline consisted almost exclusively of linked AE files.
I have now exported all linked clips natively in AE and replaced them in premiere - now the export to AME works fine again.
(plus other projects I tested worked fine too).
I guess it was something with this specific project related to the AE-link.
All good again š
Hi Scott at RLA,
Sorry for the issue. Please check if both the applications are updated to the same version or not.
Here are the steps: FAQ: How to find the exact version of Premiere Pro you're using?
There is a new update for Premiere Pro & Media Encoder 12.1.1. Update the apps & let us know the issue persists.
Vidya
Exporting to AME worked fine a couple of hours ago. Suddenly the same issue arose. Both Premiere and Encoder are 12.1.0
Unforatunately I'm in the middle of a project, I can't take the risk of updating my software.
Is there a way to workaround?
(has it something to do with audio?)
One thing to quick try ... in AME, Edit/Preferences, un-check "import sequences natviely" ... no clue what that does, but un-checking it solves a ton of odd issues.
Neil
Thanks for the tip. Unfortunately this does not solve the issue.
I have now also update both premiere and AME to the latest versions, but the issue persists.
clean media cache and project previews of both, there might be something stuck
try if this helps and let us know please
Thanks for the tip.
All good again š
Hi manuel BĆ¼chler,
As you mentioned, it is an issue with AE files. There is a known issue with Dynamic Link between Premiere Pro & After Effects.
Engineering is working on a fix. Hopefully, it will get fixed in the next update.
Vidya
