I have a Huion Pro610-2048 drawing tablet and the brush tool isn't working. For some reason it acts as a move tool, making it impossible to draw while zoomed in. I've tried ejecting the tablet, restarting Photoshop, restarting my computer 3 times, uninstalling the drivers to the tablet and reinstalling them, and tried a different driver altogether. Nothing worked to fix the issue.
See this thread for the answer:
The update that that thread is referring to isn't the update I'm on. From my update history, I've actually never downloaded that update. Right now I'm on windows update KB4093110.
There's another answer there about deselecting Windows Ink. Does that work?
Hi
Try either one of these
1. Use notepad to create a text file and type in :
UseSystemStylus 0
2. Save the file as PSUserConfig.txt in the following location
C: > Users > Username > AppData > Roaming > Adobe > Adobe Photoshop CC 2018 > Adobe Photoshop CC 2018 Settings
3. Go to the Wacom tablet properties and for Photoshop under Mapping uncheck "Use Windows Ink"
Or
1 Select everything inside the quotes here (don't include the quotes): “reg add HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Pen /v LegacyPenInteractionModel /t REG_DWORD /d 1 /f”
2 Copy it with Ctrl + C on the keyboard.
3 Type Windows Key + X (together), a menu will appear
4 Then type "A" on the keyboard. That will give you an elevated administrator PowerShell command prompt.
5 Paste the command you copied into that window with Ctrl + V
6 Hit "Enter" on the keyboard
7 Reboot
If you go for the first option you may need to enable hidden items in file explorer
Please if you find a solution share it. I'm having thesame problem i use huion new 1060 plus. I even restored windows lost all my softwares reinstalled photoshop and the problem is still there. Also can't find the Microsoft update most people uninstall
Try the new update: Cannot paint with stylus when zoomed in on image | Windows 10
