Ciao a tutti, spero che qualcuno possa aiutarmi!
Su un portatile HP Envy x360, sia con il dito che con la sua penna dedicata per il touch, Photoshop CC in modo del tutto casuale mi riconosce il tocco come strumento mano, anche se ho selezionato uno strumento pennello!
Problema che ovviamente se uso un banale mouse non si presenta!
AIUTOOO!
Try either one of these
1. Use notepad to create a text file and type in :
# Use WinTab
UseSystemStylus 0
2. Save the file as PSUserConfig.txt in the following location
C: > Users > Username > AppData > Roaming > Adobe > Adobe Photoshop CC 2018 > Adobe Photoshop CC 2018 Settings
3. Go to the Wacom tablet properties and for Photoshop under Mapping uncheck "Use Windows Ink"
Or
1 Select everything inside the quotes here (don't include the quotes): “reg add HKEY_CURRENT_USER\Software\Microsoft\Windows\Curr
...Copy link to clipboard
# Use WinTab
UseSystemStylus 0
Or
1 Select everything inside the quotes here (don't include the quotes): “reg add HKEY_CURRENT_USER\Software\Microsoft\Windows\CurrentVersion\Pen /v LegacyPenInteractionModel /t REG_DWORD /d 1 /f”
2 Copy it with Ctrl + C on the keyboard.
3 Type Windows Key + X (together), a menu will appear
4 Then type "A" on the keyboard. That will give you an elevated administrator PowerShell command prompt.
5 Paste the command you copied into that window with Ctrl + V
6 Hit "Enter" on the keyboard
7 Reboot
If you go for the first option you may need to enable hidden items in file explorer
