3 Replies Latest reply on May 23, 2018 4:59 PM by Kevin-Monahan
    Sony footage imports as audio only
    Jjepp01
      Hello,
      I just updated my Adobe Premiere to the latest version yesterday, and now when I import the MP4 footage from my Sony PMW-200 it comes in as audio only. The footage looks fine in After Effects and I'm able to convert it in Media Encoder. The interesting part is, I can still import footage from older projects (recorded with the same camera) and it's fine. And, I was able to look at this footage in Premiere before I updated it. Has anyone else experienced this?
      Jeff
        • 1. Re: Sony footage imports as audio only
          Jjepp01 Level 1
          I have an update. I did a little more experimenting and this is what I found: the footage coming from an external hard drive is importing as audio only. If I copy the footage to my computer's hard drive, it imports fine. I also shot a new piece of footage and placed it on the external hard drive. It imports just fine. Older footage from the external hard drive imports fine. The only difference I can find between the problem footage and the working footage is I transferred the problem footage directly from the camera, where I typically use a Sony card reader to transfer footage. Typically, this wonldn't be a problem except that I have 175 gigs of footage to edit and my computer's internal drive wont store that much. Any thoughts how to fix this problem?
          Jeff
          • 2. Re: Sony footage imports as audio only
            sveinungg Level 1
            I "solved" the problem by importing the missing files from the internal HD and then re-link it with the fils on the external HD.
            • 3. Re: Sony footage imports as audio only
              Kevin-Monahan Adobe Employee
              Jeff,
              Add your voice to this issue: Fix mp4 Importing – Adobe video & audio apps
              Hope we can get a fix out to you soon. In the mean time, you may have use a previous version.
              Kevin
