First of all. Im sorry asking this question knowing that i am beginner.
I created a photo design as pic 1
as you can see. It has 3 items,
-the glowing smoke at the back,
-text : nswa
-text : production
Now i don't remember the steps how i make the glowing smokes. what i can remember is . It is a layer with white and gold gradient overlay and a couple clicks of smoke brush
and when when i tried to recreate it, it's come different ( refer pic 2 )
i have no idea how i made the center glowing bright like pic 1.
please help.
Thanks in advance.
Here's another approach
I've used a cloud brush and stamped it down one on a new layer. I've set up some guides so I can repeat things in the same place.
I want to get a more circular pattern, so I am going to rotate the brush in the Brush Settings panel, and stamp it down again in the same place.
I'll repeat that a few times with different brush angles.
That gives me a roughly circular texture, but I am left with too much fully white in the centre, which means it will be flat and uninteresting
So I
...Copy link to clipboard
Hi. Hopefully, this video will help.
Photoshop Using Radial Gradient to Transparency - YouTube
So I reduced the brush size a bit, and reduced its opacity to 20% and stamped down with black.
Now we have texture throughout.
Make a new layer and select the colour you'd like to use. If you get it wrong first time, you can keep changing and trying again, because this step is non destructive.
Select the gradient tool, and from the from the drop-down, select the second option which is Foreground to Transparent
Set the type to Radial Gradient and drag a gradient from the center of the canvas to the outside. The great thing about using Foreground to Transparent, is that you can build it up, But lay down your first gradient, and then move to the next step after the screenshots.
You can see that the gradient is covering the texture in the centre, which is not what we want.
So set the gradient layer's blend mode to Color and the texture will show through.
Lay down more and long gradients to get the effect you want.
Reduce the layer opacity a bit if it better suits your intended end effect.
Now we still have some full blown white pixels which don't take the colour well, so I have added a Curves Adjustment Layer
above the white clouds layer, and dropped the White Point ever so slightly from 255 to 240. In fact that might be a touch too
much, but it's fully adjustable and nondestructive.
If that is too much texture, then use Gaussian Blur to reduce the detail.
I'm sorry, but I don't recognise the script font.
