1 Reply Latest reply on Aug 16, 2008 2:07 PM by Shandy Elliott
    My Flash Site looks very low in quality (I'm viewing in High Quality)
    NiallASD
      Hi all,
      I am wondering why this Flash site I've designed is so rough looking (indecipherable text, pixellated edges etc.).
      Because I was working with content already created in Illustrator (10), I copied them over to Flash (CS3) as vectors and resized them. I'm guessing this method may be a big factor but even text I added myself doesn't look as good as it should (namely the buttons and text in the 'Lotus' section); I added my own text using Flash.
      Here are two examples of the site (only the Lotus and Portfolio buttons work, clicking the Change and Grow icon takes you back to the home page):
      800x550 Resolution
      Scales according to window size
      Also, if you go here you will see a simple jpeg.
      I'd prefer to keep the site at 800x550 resolution without rescaling but as you can see that isn't a good idea.
      [L=This site]http://ti.arc.nasa.gov/destination/iss/flash/index.html{/L] uses very small text (in the case of the menu on a black background) yet looks fine.
      Also, the thumbnail on the Portfolio page looks very bad even though it wasn't resized in any way using Flash (I reduced the size of the original image in Photoshop and changed the DPI from 200 to 72, then imported it into Flash as a jpeg.
      Any help at all is very much appreciated!
      Niall
      PS. I changed the text to bold to make it a little clearer though I'd prefer to keep it regular.
        • 1. Re: My Flash Site looks very low in quality (I'm viewing in High Quality)
          Shandy Elliott Level 1
          "I copied them over to Flash (CS3) as vectors and resized them" - what do you mean you copied over to Flash? Do you mean import?
          "text I added myself doesn't look as good as it should" - check your anti-aliasing in Flash
          "I'd prefer to keep the site at 800x550 resolution without rescaling but as you can see that isn't a good idea." - no, actually that is a good idea - not to rescale - any time you resize a flash document with rastered graphics, you will get distortion
          'uses very small text (in the case of the menu on a black background) yet looks fine." - they are using pixel fonts
          "Also, the thumbnail on the Portfolio page looks very bad even though it wasn't resized in any way using Flash (I reduced the size of the original image in Photoshop and changed the DPI from 200 to 72, then imported it into Flash as a jpeg." - looks fine to me (on the unscaled version), but I don't have anything else to compare it to - check your image compression settings in flash (both under Publish Settings/flash tab and when you double click the bitmap in the library you can control compression settings. What level of compression are you using when saving from Photoshop?
          The word "graphic design" looks better here http://www.lotusgraphicdesign.net/ then here http://www.lotusgraphicdesign.net/small.html , but they are different sizes. Which is the original size?
          Another note: "Because I was working with content already created in Illustrator (10), I copied them over to Flash (CS3) as vectors and resized them." if you actually imported an ai file into flash, I know it also imports clipping masks and things of that nature. When you resize an imported ai file, you may be getting weird results from also resizing the clipping masks, too. When I import an ai file, I break up everything as much as possible. Depending on how you import your ai file, bitmaps will be created, so make sure you stay away from bitmaps when possible when resizing any symbol.
          That's all I can really think of.
