I cannot enter the login section of creative cloud. What's the problem in it?
install the cc desktop app from here https://creative.adobe.com/products/creative-cloud and use it to install your adobe subscription and trial programs.
if that's what you're using:
1. check your account to verify your subscription is what you expect and to verify your adobe id, https://accounts.adobe.com
2. sign out and then back in to your cc desktop application using the same adobe id used to verify your subscription: http://helpx.adobe.com/creative-cloud/kb/sign-in-out-creative-cloud-desktop-app.html
what exact problem are you seeing?
if you try to login and can't connect to adobe's servers, start here: http://helpx.adobe.com/x-productkb/policy-pricing/activation-network-issues.html
But i can't see any login bar or places
Also, the apps down after i can't see any login id bars
THIS DOES NOT WORK. If you Google this problem it is all over the internet and there are no solutions provided. Uninstall, reinstall, you name - nothing works. I want to cancel my order.
If you had already installed Adobe Creative Cloud desktop application , follow below mentioned steps:
Close all Adobe apps if running including Adobe Creative Cloud desktop app.
Windows :
Press Windows button (located between Ctrl and Alt buttons) along with R button together at a time , you will get a run command window.
Type in below command and hit 'Enter' key.
Appdata
It will open Appdata folder.
Then navigate to Local>Adobe>OOBE. Open OOBE folder and delete " Opm.db" file.
Mac:
1) Right click on Finder icon and select "Go-To" Folder option.
2) You will get a text box, type-in below command and then hit 'Return' key.( " Do not miss ~ symbol " )
~/library
It will open User Library folder.
3)Then navigate to Application Support>Adobe>OOBE. Open OOBE folder and trash Opm.db file.
Once you had deleted Opm.db file , relaunch Adobe Creative Cloud desktop app and check.
Note :
If you need further assistance , please mentioned operating system and its version . Also the screenshot of Adobe Creative Cloud app where login option is not available will be helpful.
Been there. Done that. Nothing has worked. We had someone on chat earlier today - completely unsuccessful What shocks me is a company as big as Adobe and internationally present cannot have a simple solution for paying customers. I pretty much have no option at this point but to cancel my contract. I will of course be posting my lack of success on their Facebook and social networks as well as on the two blogs I own. This is completely unacceptable. In any case, thank you for the time you took to respond.
I have been told there are other online solutions for far less trouble and cost. Regards to all.
If possible ,please post screenshot of Adobe Creative Cloud app.
