Hello users,
I'm new to Adobe and I don't know much but I tried installing animate cc in order to learn some animations.
After opening the app, the loading screen appears but after the text "loading document templates" appears,
the apps in the desktop refreshes then a box appears saying adobe animate has stopped working followed
by "A problem caused the program to stop working correctly. Windows will close the program and notify you
if a solution is available." I tried to search for solutions and tried the ones I saw but it still doesn't work no
matter what i do. I am looking forward to animating objects but I can't at the moment. Any kind of help would
be so much helpful. Thank you.
*I'm using windows 10
Thank you for trying the solutions. If the last solution did not help, please send me your Adobe ID, location, and phone number over a private message. To send a private message, click my picture and use the Message button. We will get in touch with you for investigation. ^PK
reset your preferences -
http://helpx.adobe.com/flash/kb/re-create-preferences-flash-professional.html
(or remove Win: C:\Users\<username>\AppData\Local\Adobe\Animate CC <version>\ and
C\Users\<username>\AppData\Roaming\Adobe\Animate\<version>\
Mac: /Users/<username>/Library/Application Support/Adobe/<Animate CC version>/ and
/Users/<username>/Library/Preferences/Adobe/Animate/<version>/)
tried it, still gets stuck at 'loading document template' for a while then the dialogue box appears again
saying it stopped working
uninstall animate cc including preferences, https://helpx.adobe.com/creative-cloud/help/uninstall-remove-app.html
restart your computer (don't skip this)
use the desktop app to install animate cc
still doesn't work for me
using a browser that allows popups and cookies, contact adobe support during pst business hours by clicking here and, when available, click 'chat', http://helpx.adobe.com/x-productkb/global/service-ccm.html
i'll try, thanks for the help!!
you're welcome.
Do post your solution here after your issue has been resolved. It will help other users with a similar issue.
still not working, i've tried almost everything but it can't seem to work
could it be because of compatibility issues or maybe because of the other apps installed in my pc?
other apps, yes. you can test that by stating is safe mode.
same problem
