2 Replies Latest reply on Jan 10, 2009 12:32 PM by heathrowe
    Experiencing Numerous Errors with Fireworks CS4 Exporting CSS
    MrTank
      Hello,
      Was very excited about the new export css & images feature in Fireworks, however it has caused me nothing but frustration whilst trying to use it.
      I get numerous diff errors whilst trying to export my web designs. I have read and completed all the tutorials I can find and most went without a glitch. However I have been currently trying to export CSS & Images for my own custom design. However I constantly get the error message when exporting:
      " Object 'border middle' & 'border bottom' overlap, switching to absolute positioning mode "
      Here I am trying to export a simple webpage that has a custom border I made, the border is a flattened image, and I have sliced it using the 3 slice technique with a top, background repeating middle and bottom. (another thing to note is that flattened images; bitmaps, won't repeat as a backround image, only vector images such as drawn rectangles etc will. I found that you have to put a blank box around the bitmap to use it as a repeating background - which I have done in this case).
      However when I go to export I get the error:
      Even though I am sure nothing is overlapping!! I don't understand why it gives me this error all the time, which in turn causes the entire page to be exported 'left' aligned even though I select 'centre' in export options. This is very annoying as I'm sure I'm doing nothing wrong.
      Also sometimes when exporting I get another error where it simply seems to ignore my slices and exports the entire page as a single flattened image!! which is named layer1. This can only be solved by restarting my PC.
      I have updated the CSS Export Script & HTML components with this:
      http://www.adobe.com/devnet/fireworks/articles/standards_compliant_design.html
      But I wouldn't have thought that would be causing my problems.
      ANY HELP WOULD BE GREATLY APPRICIATED. As this would be a very handy feature if only I could get it to work properly :-(
      I am running Vista 32 bit on a high end PC.
        • 1. Re: Experiencing Numerous Errors with Fireworks CS4   Exporting CSS
          Level 7
          MrTank wrote:
          > Hello,
          > positioning mode "
          > done in this case).
          > positioning mode "
          Can you share the PNG with us, please?
          Jim Babbage - .:Community MX:. & .:Adobe Community Expert:.
          http://www.communityMX.com/
          CommunityMX - Free Resources:
          http://www.communitymx.com/free.cfm
          .:Adobe Community Expert for Fireworks:.
          http://tinyurl.com/2a7dyp
          .:Author:.
          Lynda.com - http://movielibrary.lynda.com/authors/author/?aid=188
          Peachpit Press -
          http://www.peachpit.com/authors/bio.aspx?a=d98ed798-5ef0-45a8-a70d-4b35fa14c9a4
          Layers Magazine - http://www.layersmagazine.com/author/jim-babbage
          • 2. Re: Experiencing Numerous Errors with Fireworks CS4 Exporting CSS
            heathrowe Most Valuable Participant
            HIT CTRL/Command + A and you should see which objects overlap.
            Pay close attention to the object outlines that appear too close/overlap and 'nudge' them away from each other.
            h
