Want to make selection along the path. In between selection looses the path. what can be the reason ?
One more try …
Is the curve one continuous path?
Can you provide a file with the path for testing?
Curve is repeated path.
If the paths are not connected they will not select as a single element. Connect the paths to solve this problem.
Paths connected but still continuous with same issue.
As Bob_Hallam stated the subPathItems need to be connected.
This may be a bit inconvenient if the endpoints of the open subPathItems basically lie on top of one another but it can be achieved with some work-arounds.
Paths connected but it still continuous with same issue. How can i send .psd file to you ?
This Forum won’t accept psd but a jpg with the Path should work, use the Insert Image-button:
It only allows to insert image and not .psd file. Plz provide your mail id
Please post a jpg with the Path.
jpgs can contain Paths so that should not be a problem.
Actually it is happening coz one anchor point is over the another. Two anchor point at same place. It can only be solved when two anchor points are merged.
That would effectively be what has been mentioned in several posts already but you claimed the paths were connected.
Plz suggest the solutio.
Solution
One more try …
Very helpful. I have lower version of photoshop "merge shape components" is not available then too i will check and try.
Thank you !
Connect the subPathItems already.
If you need more instruction please post the image containing the Path I have requested.
Dis you duplicate the curve element without connecting the subsequently existing two subPathItems?
