Hi Steven,
The issue you are facing has nothing to do with Presenter
Reporting. The problem here is with the display of the report which
is being done by the LMS, in this case Adobe Connect. If you check
the reports for a particular individual in the 'Reports' section,
you will see that all the reports are generated correctly which
means that Presenter is 'reporting' correctly but Connect is not
'showing' the reports as you want it to.
Now coming to your actual problem. Do you just want to be
able to 'view' reports or do you want to download them as well? If
you just want to view reports then Connect does a good job at that.
But the amount of information you can view in the reports depends
upon your 'Role' in Connect.
For instance, if you are an 'Administrator' or 'Training
Manager', then you can view all results of all students (in Connect
7, there is a separate Reporting Wizard that shows reports for each
student who has taken that course, the reports include questions,
their answers, score etc; this exactly meets your requirement).
If you are only a 'Learner' then you can only view your own
report and this report includes the Question and the score and
nothing else (answers are not shown).
If you want to download results, then only Admin/Training
Manager can download results. Someone who has only 'Learner' rights
cannot. You can download results at various levels- By Slides, By
Users, By Questions, By Answers but these reports do not meet your
requirement and they have lot of additional data like sco-id,
principal-id that you may not require. The downloaded result is
available in .csv format. If you view it in Microsoft Excel then
the representation of data will be better. You can also download
reports from the Reporting Wizard. But none of these reports match
your requirement, that is displaying answers to questions for a
particular user. What you can get is score and status corresponding
to each test-taker (from Reporting Wizard on C7 and Reports->By
Users on C6 & C7).
You should put your query on 'Connect Training Module' on
ConnectUsers.com as it is an issue with that module. Someone there
might be able to suggest some solution or workaround. Here is the
link :
http://www.connectusers.com/forums/cucbb/viewforum.php?id=36
