4 Replies Latest reply on Apr 23, 2018 11:17 PM by jvknowles
    Swap out puppet "clothes" while maintaining existing animation?
    jvknowles Level 1
      Quick #AdobeCharacterAnimator question for the hive mind: if I already have an animation synced to a performance but I want to "change clothes" (alter the puppet's body in Photoshop), can I swap out the puppet file and keep the animation already in place? Or do I need to redo it?
      FYI this is a variation on the Clay puppet, so all I'm doing is altering the body layers which don't have any animation assigned to them (other than staying with the head as it swivels).
      TIA,
      JVK
        • 1. Re: Swap out puppet "clothes" while maintaining existing animation?
          alank99101739 Level 4
          I don’t know the exact rules, but you can certainly make some changes. The latest release has more features I have not tried yet around copy / pasting between puppets so you could try creating a new puppet and copy/paste things over to be safe.
          otherwise select the scene and duplicate it as a form of backup before you start fiddling.
          i have also opened Puppet in CH and AI, made changes, stuffed things up, then undid changes in Ch then Ai then hit the sync button in the scene. I have not lost a project yet that I could not recover... but I still make backups first! just be aware if you change the artwork file and CH forgets details, doing undo in AI is not enough. You need to undo CH to get back to before the last refresh to recover lost rigging
          in the rigging window you can type control-E to bring up the editing tool on the right copy of the artwork.  Things go wrong the most when you change the layer structure too much. Little changes are generally fine
          • 2. Re: Swap out puppet "clothes" while maintaining existing animation?
            IanD101 Level 1
            How I do it is to place the new clothing layer directly below the original and repeat for each layer.
            Then create a Trigger or Swap Set to change the clothes either independently or all together.
            How that works.
            • 4. Re: Swap out puppet "clothes" while maintaining existing animation?
              jvknowles Level 1
              Thanks for the responses everyone!
              What I wound up doing was going into the Puppet panel and changing the puppet file it was pointing to, swapping it for the one modified with the new clothes. That kept the animation we had originally synced to performance.
              I should note that we're still on the previous version of CA18, which does not have the ability to copy and paste animations between puppets in a scene (like "Paste Attributes" in Premiere). Hopefully that's in the new version or else a future version.
              JVK
