I use the Flex add-in for Eclipse. When I let it create my PHP file I didn't specify a port and was able to connect in design mode. When I ran it however, I got the "channel disconnected" error. After I edited the PHP file to specify port 3306, the error went away.
Thank you so much, Jim!
I fixed it also by putting the port "3306" in the generated code. Been looking all over the place and tried a many things with no success.
Like you said there was no port needed to connect from FLEX, but running from either Flash or Air... I was getting the "channel disconnected".
Hope this post and yours will help others also.
Same issue but nothing in the application.cfc and I am using coldfusion as backend on an IIS server.
This error happens between 5 and 50 times a day (depends on the traffic)
Aubry
