• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
AFDKO
New Here ,
Apr 23, 2018 Apr 23, 2018
I'm having a problem installing this open source font kit.  Please someone help.  My Mac says “FinishInstallOSX” can’t be opened because it is from an unidentified developer.  Your security preferences allow installation of only apps from the App Store and identified developers.  Safari downloaded this file today at 1:51 PM from www.adobe.com.  I called Adobe.  They told me to come here.
Views
760
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
Apr 24, 2018 Apr 24, 2018
You are likely seeing this message because of security setting on your mac. This may be helpful: macOS Sierra: Open an app from an unidentified developer
Votes
Translate
Translate
Report
Report
New Here ,
LATEST
I got this:
Last login: Tue Apr 24 12:59:58 on ttys000
CanadyCorps-Air:~ tylancanady$ /Users/tylancanady/Desktop/FDK/FinishInstallOSX ; exit;
Adding a symbolic link from '/Users/tylancanady/bin' to the FDK directory /Users/tylancanady/Desktop/FDK.
Adding a command to your login file that will append the FDK path to the $PATH environment variable...
   I added some lines to the  startup file /Users/tylancanady/.login for the tcsh/csh versions of the Terminal program, in order to add the 'FDK/Tools/osx' directory to your PATH environment variable.
   I added some lines to the  startup file /Users/tylancanady/.profile for the bash/sh/zsh versions of the Terminal program,  in order to add the 'FDK/Tools/osx' directory to your PATH environment variable.
Changed to file /Users/tylancanady/.profile
   I added some lines to the  startup file /Users/tylancanady/.bash_profile for the bash/sh/zsh versions of the Terminal program,  in order to add the 'FDK/Tools/osx' directory to your PATH environment variable.
Changed to file /Users/tylancanady/.bash_profile
   I added some lines to the  startup file /Users/tylancanady/.zprofile for the bash/sh/zsh versions of the Terminal program,  in order to add the 'FDK/Tools/osx' directory to your PATH environment variable.
Changed to file /Users/tylancanady/.zprofile
If you cannot run the FDK tools by name from the command-line after closing this window, then your
Terminal program may be using a different login file than the ones I modified.
If so, you will need to identify your login file, and then add the same two lines to that file.
You must close the current Terminal windows.
The update to your PATH environment variable will take effect only when a new terminal window is opened.
The FDK will then be ready to use.
logout
Saving session...
...copying shared history...
...saving history...truncating history files...
...completed.
[Process completed]
But the install never completed.
Votes
Translate
Translate
Report
Report
