I am trying to capture text from a form field using Adobe Launch. See form code below...
How should I configure launch to capture the text from my form field?
<input id="ticker1" type="text" class="idc-form2 etfLookup ui-autocomplete-input" data-bind="event: { keydown: changed }" autocomplete="off" role="textbox" aria-autocomplete="list" aria-haspopup="true">
Solved! Go to Solution.
I'd first start by trying to create a data element that pulls the value from the from field when called. You can try something similar to what I've put below. Keep in mind, I can't see the rest of your page so you'd definitely need to test this.
Once you get the data element pulling the correct value, you'll need to decide when you are going to trigger the rule. For example, do you want to capture the value each time it's changed or just when the form is submitted? Once you've decided that, you can create a rule using the Core extension to trigger based on one of the form events. Once this is set, go ahead and test again to ensure this triggers when the expected action is completed.
Once the rule is firing, you should add conditions to limit it to a specific page or whatever criteria you might need.
Finally, create the action section of the rule to set your variables and fire the required beacons. You can reference the value in your form by referencing the data element we created.
This worked! Once again thank you for the help!
Views
Total Likes
