Expand my Community achievements bar.
Join us for an upcoming in-person Adobe Target Skill Builders event ~~> We're hosting these live learning opportunities to equip you with the knowledge and skills to leverage Target successfully. Learn more to see if we'll be coming to a city near you!
SOLVED
Is there a way to export target's metric data with daily granularity?
Avatar
Level 3
I am looking for a way to export activity's metric data with daily granularity. I have gone through the target API documentation and it does not mention anything about granularity or date range. It only has the performance report section which does not give the option to set granularity or select a date range.
Please suggest, how can I use the API to get the granular data or suggest an alternate way to get the granular data. Thanks.
1 Accepted Solution
Avatar
Correct answer by
Community Advisor
Hi Kartik, I know its not clearly stated it in Adobe documentation but I found my way to get report for specific interval using reportInterval parameter which looks like one below:
reportInterval": "2017-03-14T05:00Z/2017-07-10T07:00Z
Here's how your API URL will look like:
"https://mc.adobe.io/" & strTenant & "/target/activities/" & strActivityType & "/" & strActivityId & "/report/performance/?reportInterval=" & strReportingInterval
Hope this helps,
Rajneesh
View solution in original post
Avatar
Correct answer by
Community Advisor
Hope this helps,
Rajneesh
Avatar
Level 3
Thanks Rajneesh for the response. It looks like your method will definitely work. I am currently not able to verify this since I am stuck at authentication part of the API, don't know what am I doing wrong. Anyways, I will give it a try once I am through the Authentication step.
Avatar
Employee
kartikbhatia​ Here's a help document which has detailed steps to generate the authentication token and might help you to get through the authentication steps.
https://helpx-internal.corp.adobe.com/content/help/en/marketing-cloud-core/kb/adobe-io-authenticatio...
