Hi
I am using Flex3 with flash player 9.0.28 and BlazeDS for
Remoting and Java at the server side code. I was able to access my
java classes using Remoting but suddenly I am getting error today
and I am unable to fix it. I captured the exact problem by using
Flex debugging
Note: I am able to do file uploading the same application in
the same server using FileReference but for remoting the error is
NetConnection.failed.
Please find the error description below:
[RPC Fault faultString="Send failed"
faultCode="Client.Error.MessageSend"
faultDetail="Channel.Connect.Failed error
NetConnection.Call.Failed: HTTP: Status 404: url: '
http://localhost:8180/reclassification/messagebroker/amf'" at mx.rpc::AbstractInvoker/
http://www.adobe.com/2006/flex/mx/internal::faultHandler()[E:\dev\3.0.x\frameworks\projects\rpc\src\... at
mx.rpc::Responder/fault()[E:\dev\3.0.x\frameworks\projects\rpc\src\mx\rpc\Responder.as:49]
at
mx.rpc::AsyncRequest/fault()[E:\dev\3.0.x\frameworks\projects\rpc\src\mx\rpc\AsyncRequest.as:103]
at
mx.messaging::ChannelSet/faultPendingSends()[E:\dev\3.0.x\frameworks\projects\rpc\src\mx\messaging\ChannelSet.as:1399]
at
mx.messaging::ChannelSet/channelFaultHandler()[E:\dev\3.0.x\frameworks\projects\rpc\src\mx\messaging\ChannelSet.as:935]
at flash.events::EventDispatcher/dispatchEventFunction()
at flash.events::EventDispatcher/dispatchEvent()
at
mx.messaging::Channel/connectFailed()[E:\dev\3.0.x\frameworks\projects\rpc\src\mx\messaging\Channel.as:997]
at
mx.messaging.channels::PollingChannel/connectFailed()[E:\dev\3.0.x\frameworks\projects\rpc\src\mx\messaging\channels\PollingChannel.as:354]
at
mx.messaging.channels::AMFChannel/statusHandler()[E:\dev\3.0.x\frameworks\projects\rpc\src\mx\messaging\channels\AMFChannel.as:369]
thanks in advance..
phani.
