I just tried it with a group of slides including a Quiz Results slide and it didn't work. When I excluded the Quiz Results slide, it worked.
You cannot copy and paste a Quiz Results slide from one project to another. You can only copy/paste the quiz slides or normal slides. You have to add the Quiz Results slide via the Quiz > Settings in the project itself.
Rod's answer is to the point (of course), but please, you did add this to a 10 years old thread. Can you start a new thread next time? You probably are not using Captivate 4, which was the case when this thread was started.
I was posting a solution, not a question. I googled my problem and this is the thread I found. I figured out the problem on my own and decided to help the next person that may google a similar problem. I never find threads on here that address my exact problem with Captivate 2017. I even brought this up to Adobe Support and they told me, "most of it is the same in previous versions."
Now that I know you all are wonderful at answering so quickly, I will start posting original threads though.
Welcome, we look forward to your contributions. The Search functionality of these forums is not very well designed. Often you'll get better results with Google.
