• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Wildcard question please
Explorer ,
Apr 24, 2018 Apr 24, 2018
I have a bunch of footnotes that appear in the the text and source code as and [iv] and [xxiii], etc.   I don't need them to link anywhere.
But I do want to superscript them.
So I need a way to search the source code for [anything] and replace it with <sup>[anything]</sup>.
So any time my code contains left-bracket, any character(s), right bracket...that code stays the same except for <sup> before it and </sup> after it.
I am getting confusing with my syntax involving the brackets.   thanks !
Views
570
Translate
Translate
Report
Report
Community guidelines
community guidelines
LEGEND , Apr 24, 2018 Apr 24, 2018
Ah, I did misunderstand your request.
In FIND: (<\s*p[^>]*>[^<]*)(\[\w+\]\s*)(<\s*\/\s*p\s*>)
In REPLACE: $1<sup>$2</sup>$3
HTH,
^ _ ^
Votes
Translate
Translate
LEGEND ,
Will the content always be between the same tags, every time?  <div> or <span> or <blockquote>?  Which?
I'm sure a RegEx would be perfect for what you want to do.
V/r,
^ _ ^
Votes
Translate
Translate
Report
Report
Explorer ,
The content is always part of normal text paragraphs.  The only tags around them are <p></p>.
RegEx does seem to be the way to go, but I can't quite get the context right on what to search for and replace with.
Votes
Translate
Translate
Report
Report
LEGEND ,
Lemme do some research.  I've got a RegEx that looks for HTML tags and strip them out without removing the content in between opening and closing tags.  I might be able to modify it for this purpose, but I need to look into something to see if it will work.
V/r,
^ _ ^
Votes
Translate
Translate
Report
Report
LEGEND ,
Okay.. I have not tested this, but give it a shot.
Highlight the block of code that contains the <p> tags.  Open Find/Replace.
Make sure the checkbox for "Use Regular Expression" is checked.
In the Find area, enter:
(<\s*p[^>]*>([^<]*)<\s*\/\s*p\s*>)
In the Replace area, enter:
<sup>$1</sup>
Don't initially hit "Replace All", try just one or two and if it works THEN hit "Replace All".
This should work.  AS LONG AS THERE ARE NO 'LESS THAN' (<) CHARACTERS IN BETWEEN  OPENING AND CLOSING TAGS.
V/r,
^ _ ^
Votes
Translate
Translate
Report
Report
Explorer ,
Wow, thanks so much.   That was close, but it's putting the sup tags around the whole P tags, but I only need it around the bracketed info.
So my code is like this:
<p>This is a sentence[vii] </p>
What I want is:
<p>This is a sentence<sup>[vii]</sup> </p>
And yours did this:
<sup><p>This is a sentence[vii] </p><sup>
Votes
Translate
Translate
Report
Report
LEGEND ,
HTH,
^ _ ^
Votes
Translate
Translate
Report
Report
LEGEND ,
Apr 25, 2018 Apr 25, 2018
I had to scoot, quickly, after posting my correction.  Just following up.  Did my correction work, for you?
V/r,
^ _ ^
Votes
Translate
Translate
Report
Report
Explorer ,
Wolf, Thanks so much for your continued help and following up.
The RegEx you sent wasn't working for me.   So I started playing around with yours and I got closer.
For Find, I am using this:   (\[.*\])
For Replace, I use this:  <sup>$1</sup>
The simplified Find works in many cases, except for one complication that is killing me!!
If a footnote appears as the only footnote in a paragraph, my Find and Replace work perfectly.
Example:   <p>This is a sentence[vii] </p>
That works great.  When I click "Find" it highlights the proper text (in bold below).  This is exactly what I want!  So far, so good:
But, if two or more footnotes appear in the same <p> tag, then my Find syntax isn't working.
Example:
<p>This is sentence one.[vii]  This is another sentence within the same p-tag. [viii]  This is another sentence within the same p-tag. [ix]</p>
I want the FIND part to find [vii] and [viii] and [ix] as three separate finds.
Instead my find yields this:
I'm trying to end the "Find" part immediately after each ], but it's only working when there's one footnote in a p-tag.
Votes
Translate
Translate
Report
Report
Explorer ,
Got it !     For Find, I had to adjust it to this:
Thanks so much Wolf.  Couldn't have done it without you.   I have about 40 documents with dozens and dozens of footniotes each, so that why I didn't give up to easily !
Votes
Translate
Translate
Report
Report
LEGEND ,
Glad you got that fixed.  Didn't even think that there would be more than one footnote in a paragraph.  I get tunnel-vision, sometimes.
V/r,
^ _ ^
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
probably that you already know and use it, but one have a wonderfull tool on line that can be really helfull to adjust the expression
https://regex101.com/
Votes
Translate
Translate
Report
Report
LEGEND ,
I just tested it.  It works in DW CC 2016.
V/r,
^ _ ^
Votes
Translate
Translate
Report
Report
