Hello,
Been using Photoshop from CC for several years now without fail. The last few times I've tried to use photoshop, it freezes on open, or as soon as I open a file and try to do anything, it freezes. I have tried downgrading to 19.0.1, and even back to 2017 and still doing it. No hardware has changed. I believe it is due to the Fall Creator's update but cannot find a workaround.
I've tried resetting preferences, booting into safe mode - STILL crashed, reinstall and uninstalled, re-registered DLLs and checked for driver updates on Intel's site.
FWIW - other adobe apps appear to be fine, InDesign is giving me no trouble.
System Info:
Adobe Photoshop Version: 19.1.2 20180302.r.277 2018/03/02: 1160083 x64
Number of Launches: 0
Operating System: Windows 10 64-bit
Version: 10 or greater 10.0.16299.15
System architecture: Intel CPU Family:6, Model:12, Stepping:3 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2
Physical processor count: 4
Processor speed: 3292 MHz
Built-in memory: 16303 MB
Free memory: 7974 MB
Memory available to Photoshop: 14387 MB
Memory used by Photoshop: 70 %
Alias Layers: Disabled.
Modifier Palette: Enabled.
Highbeam: Enabled.
Image tile size: 1024K
Image cache levels: 4
Font Preview: Medium
TextComposer: Latin
OpenCL crashed on 4/25/2018 at 9:47:14 AM (Initializing OpenCL and OpenCL enabled features)
Display: 1
Display Bounds: top=0, left=0, bottom=1200, right=1920
Display: 2
Display Bounds: top=0, left=1920, bottom=1024, right=3200
OpenGL Drawing: Enabled.
OpenGL Allow Old GPUs: Not Detected.
OpenGL Drawing Mode: Advanced
OpenGL Allow Normal Mode: True.
OpenGL Allow Advanced Mode: True.
AIFCoreInitialized=1
AIFOGLInitialized=1
OGLContextCreated=1
NumGLGPUs=1
NumCLGPUs=1
NumNativeGPUs=0
glgpu[0].GLVersion="4.1"
glgpu[0].IsIntegratedGLGPU=1
glgpu[0].GLMemoryMB=2048
glgpu[0].GLName="Intel(R) HD Graphics 4600"
glgpu[0].GLVendor="Intel"
glgpu[0].GLVendorID=32902
glgpu[0].GLDriverVersion="20.19.15.4835"
glgpu[0].GLRectTextureSize=16384
glgpu[0].GLRenderer="Intel(R) HD Graphics 4600"
glgpu[0].GLRendererID=1042
glgpu[0].HasGLNPOTSupport=1
glgpu[0].GLDriver="igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igd12umd64.dll"
glgpu[0].GLDriverDate="20171016000000.000000-000"
glgpu[0].CanCompileProgramGLSL=1
glgpu[0].GLFrameBufferOK=1
glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="1.30 - Build 20.19.15.4835"
glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[1447]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[64]
glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=0
clgpu[0].CLPlatformVersion="1.2 "
clgpu[0].CLDeviceVersion="1.2 "
clgpu[0].IsIntegratedCLGPU=1
clgpu[0].CLMemoryMB=1629
clgpu[0].CLName="Intel(R) HD Graphics 4600"
clgpu[0].CLVendor="Intel(R) Corporation"
clgpu[0].CLVendorID=32902
clgpu[0].CLDriverVersion="20.19.15.4835"
clgpu[0].CLBandwidth=1.94261e+10
clgpu[0].CLCompute=168.875
License Type: Subscription
Serial number: 90970337905472189263
GUIDBucket:
Application folder: C:\Program Files\Adobe\Adobe Photoshop CC 2018\
Temporary file path: C:\Users\marcv\AppData\Local\Temp\
Photoshop scratch has async I/O enabled
Scratch volume(s):
Startup, 465.0G, 199.6G free
Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\Plug-Ins\
Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2018\Plug-Ins\
Installed components:
A3DLIBS.dll A3DLIB Dynamic Link Library 9.2.0.112
ACE.dll ACE 2017/11/22-18:28:12 79.589342 79.589342
AdbePM.dll PatchMatch 2016/11/03:19:48:57 1.578146 1.578146
AdobeLinguistic.dll Adobe Linguisitc Library 10.0.0
AdobeOwl.dll Adobe Owl 5.2.11
AdobePDFL.dll PDFL 2017/10/31-06:12:59 79.250229 79.250229
AdobePIP.dll Adobe Product Improvement Program 7.4.1.109.46827
AdobeSVGAGM.dll AdobeSVGAGM 79.588619 79.588619
AdobeXMP.dll Adobe XMP Core 2017/07/13-01:06:39 79.160924 79.160924
AdobeXMPFiles.dll Adobe XMP Files 2017/07/13-01:06:39 79.160924 79.160924
AdobeXMPScript.dll Adobe XMP Script 2017/07/13-01:06:39 79.160924 79.160924
adobe_caps.dll Adobe CAPS 10,0,0,6
AGM.dll AGM 2017/11/22-18:28:12 79.589342 79.589342
ahclient.dll AdobeHelp Dynamic Link Library 3.0.0.6
AIDE.dll AIDE 2016/05/27-01:08:49 79.574279 79.574279
amtlib.dll AMTLib (64 Bit) 10.0.0.221 BuildVersion: 10.0; BuildDate: Tue Aug 1 2017 8:28:8) 1.000000
ARE.dll ARE 2017/11/22-18:28:12 79.589342 79.589342
AXE8SharedExpat.dll AXE8SharedExpat 2015/03/13-23:40:54 79.562390 79.562390
AXEDOMCore.dll AXEDOMCore 2015/03/13-23:40:54 79.562390 79.562390
Bib.dll BIB 2017/11/22-18:28:12 79.589342 79.589342
BIBUtils.dll BIBUtils 2017/11/22-18:28:12 79.589342 79.589342
boost_date_time.dll photoshopdva 11.1.0
boost_filesystem.dll photoshopdva 11.1.0
boost_signals.dll photoshopdva 11.1.0
boost_system.dll photoshopdva 11.1.0
boost_threads.dll photoshopdva 11.1.0
cg.dll NVIDIA Cg Runtime 3.0.00007
cgGL.dll NVIDIA Cg Runtime 3.0.00007
CITThreading.dll Adobe CITThreading 2.1.0.1 2.1.0.1
CoolType.dll CoolType 2017/11/22-18:28:12 79.589342 79.589342
CRClient.dll Adobe Crash Reporter Client DLL 1.6.3.0
dnssd.dll Bonjour 3,0,0,2
dvaaudiodevice.dll photoshopdva 11.1.0
dvacore.dll photoshopdva 11.1.0
dvacrashhandler.dll Adobe Audition CC 2017 10.0.0
dvamarshal.dll photoshopdva 11.1.0
dvamediatypes.dll photoshopdva 11.1.0
dvametadata.dll photoshopdva 11.1.0
dvametadataapi.dll photoshopdva 11.1.0
dvametadataui.dll photoshopdva 11.1.0
dvaplayer.dll photoshopdva 11.1.0
dvatransport.dll photoshopdva 11.1.0
dvaui.dll photoshopdva 11.1.0
dvaunittesting.dll photoshopdva 11.1.0
dynamiclink.dll photoshopdva 11.1.0
ExtendScript.dll ExtendScript 2017/08/31-12:13:14 81.1150526 81.1150526
icucnv40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339
icudt40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339
icuuc40.dll International Components for Unicode 2014/10/31-16:52:45 Build gtlib_6.0.21339
igestep30.dll IGES Reader 9.3.0.113
imslib.dll IMSLib DLL 10.0.0.22
JP2KLib.dll JP2KLib 2017/10/31-01:22:04 79.268591 79.268591
libifcoremd.dll Intel(r) Visual Fortran Compiler 10.0 (Update A)
libiomp5md.dll Intel(R) OpenMP* Runtime Library 5.0
libmmd.dll Intel(R) C/C++/Fortran Compiler 17.0.0
LogSession.dll LogSession 7.4.1.109.46827
mediacoreif.dll photoshopdva 11.1.0
MPS.dll MPS 2017/10/31-01:22:04 79.588396 79.588396
pdfsettings.dll Adobe PDFSettings 1.04
Photoshop.dll Adobe Photoshop CC 2018 19.1.2
Plugin.dll Adobe Photoshop CC 2018 19.1.2
PlugPlugExternalObject.dll Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit) 8.5.0
PlugPlugOwl.dll Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit) 8.5.0.87
PSArt.dll Adobe Photoshop CC 2018 19.1.2
PSCloud.dll 1.0.0.1
PSViews.dll Adobe Photoshop CC 2018 19.1.2
SCCore.dll ScCore 2017/08/31-12:13:14 81.1150526 81.1150526
SVGRE.dll SVGRE 79.586793 79.586793
svml_dispmd.dll Intel(R) C/C++/Fortran Compiler 17.0.0
tbb.dll Intel(R) Threading Building Blocks for Windows 2017, 0, 2017, 0118
tbbmalloc.dll Intel(R) Threading Building Blocks for Windows 2017, 0, 2017, 0118
TfFontMgr.dll FontMgr 9.3.0.113
TfKernel.dll Kernel 9.3.0.113
TFKGEOM.dll Kernel Geom 9.3.0.113
TFUGEOM.dll Adobe, UGeom© 9.3.0.113
updaternotifications.dll Adobe Updater Notifications Library 10.0.0.1 (BuildVersion: 1.0; BuildDate: BUILDDATETIME) 10.0.0.1
VulcanControl.dll Vulcan Application Control Library 5.3.0.16
VulcanMessage5.dll Vulcan Message Library 5.3.0.16
WinRTSupport.dll Adobe Photoshop Windows RT Support 19.0.0.0
WRServices.dll WRServices Thu June 21 2017 12:26:24 Build 0.22473 0.22473
wu3d.dll U3D Writer 9.3.0.113
Required plug-ins:
3D Studio 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “U3D.8bi”
Accented Edges 19.1.2 - from the file “Filter Gallery.8bf”
Adaptive Wide Angle 19.1.2 - from the file “Adaptive Wide Angle.8bf”
Angled Strokes 19.1.2 - from the file “Filter Gallery.8bf”
Average 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “Average.8bf”
Bas Relief 19.1.2 - from the file “Filter Gallery.8bf”
BMP 19.1.2 - from the file “Standard MultiPlugin.8bf”
Camera Raw 10.3 - from the file “Camera Raw.8bi”
Camera Raw Filter 10.3 - from the file “Camera Raw.8bi”
Chalk && Charcoal 19.1.2 - from the file “Filter Gallery.8bf”
Chrome 19.1.2 - from the file “Filter Gallery.8bf”
Cineon 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “Cineon.8bi”
Clouds 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “Clouds.8bf”
Collada 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “U3D.8bi”
Color Halftone 19.1.2 - from the file “Standard MultiPlugin.8bf”
Colored Pencil 19.1.2 - from the file “Filter Gallery.8bf”
CompuServe GIF 19.1.2 - from the file “Standard MultiPlugin.8bf”
Conté Crayon 19.1.2 - from the file “Filter Gallery.8bf”
Craquelure 19.1.2 - from the file “Filter Gallery.8bf”
Crop and Straighten Photos 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “CropPhotosAuto.8li”
Crop and Straighten Photos Filter 19.1.2 - from the file “Standard MultiPlugin.8bf”
Crosshatch 19.1.2 - from the file “Filter Gallery.8bf”
Crystallize 19.1.2 - from the file “Standard MultiPlugin.8bf”
Cutout 19.1.2 - from the file “Filter Gallery.8bf”
Dark Strokes 19.1.2 - from the file “Filter Gallery.8bf”
De-Interlace 19.1.2 - from the file “Standard MultiPlugin.8bf”
Dicom 19.1.2 - from the file “Dicom.8bi”
Difference Clouds 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “Clouds.8bf”
Diffuse Glow 19.1.2 - from the file “Filter Gallery.8bf”
Displace 19.1.2 - from the file “Standard MultiPlugin.8bf”
Dry Brush 19.1.2 - from the file “Filter Gallery.8bf”
Eazel Acquire 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “EazelAcquire.8ba”
Entropy 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “statistics.8ba”
Export Color Lookup Tables 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “Export3DLUT.8be”
Extrude 19.1.2 - from the file “Standard MultiPlugin.8bf”
FastCore Routines 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “FastCore.8bx”
Fibers 19.1.2 - from the file “Standard MultiPlugin.8bf”
Film Grain 19.1.2 - from the file “Filter Gallery.8bf”
Filter Gallery 19.1.2 - from the file “Filter Gallery.8bf”
Flash 3D 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “U3D.8bi”
Fresco 19.1.2 - from the file “Filter Gallery.8bf”
Glass 19.1.2 - from the file “Filter Gallery.8bf”
Glowing Edges 19.1.2 - from the file “Filter Gallery.8bf”
Google Earth 4 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “U3D.8bi”
Graphic Pen 19.1.2 - from the file “Filter Gallery.8bf”
Halftone Pattern 19.1.2 - from the file “Filter Gallery.8bf”
Halide Bottlenecks 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “HalideBottlenecks.8bx”
HDRMergeUI 19.1.2 - from the file “HDRMergeUI.8bf”
HSB/HSL 19.1.2 - from the file “Standard MultiPlugin.8bf”
IFF Format 19.1.2 - from the file “Standard MultiPlugin.8bf”
IGES 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “U3D.8bi”
Ink Outlines 19.1.2 - from the file “Filter Gallery.8bf”
JPEG 2000 19.1.2 - from the file “JPEG2000.8bi”
Kurtosis 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “statistics.8ba”
Lens Blur 19.1.2 - from the file “Lens Blur.8bf”
Lens Correction 19.1.2 - from the file “Lens Correction.8bf”
Lens Flare 19.1.2 - from the file “Standard MultiPlugin.8bf”
Liquify 19.1.2 - from the file “Liquify.8bf”
Matlab Operation 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “ChannelPort.8bf”
Maximum 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “statistics.8ba”
Mean 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “statistics.8ba”
Measurement Core 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “MeasurementCore.8me”
Median 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “statistics.8ba”
Mezzotint 19.1.2 - from the file “Standard MultiPlugin.8bf”
Minimum 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “statistics.8ba”
MMXCore Routines 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “MMXCore.8bx”
Mosaic Tiles 19.1.2 - from the file “Filter Gallery.8bf”
Multiprocessor Support 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “MultiProcessor Support.8bx”
Neon Glow 19.1.2 - from the file “Filter Gallery.8bf”
Note Paper 19.1.2 - from the file “Filter Gallery.8bf”
NTSC Colors 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “NTSC Colors.8bf”
Ocean Ripple 19.1.2 - from the file “Filter Gallery.8bf”
OpenEXR 19.1.2 - from the file “Standard MultiPlugin.8bf”
Paint Daubs 19.1.2 - from the file “Filter Gallery.8bf”
Palette Knife 19.1.2 - from the file “Filter Gallery.8bf”
Patchwork 19.1.2 - from the file “Filter Gallery.8bf”
Paths to Illustrator 19.1.2 - from the file “Standard MultiPlugin.8bf”
PCX 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “PCX.8bi”
Photocopy 19.1.2 - from the file “Filter Gallery.8bf”
Photoshop 3D Engine 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “Photoshop3DEngine.8bi”
Photoshop Touch 19.0 - from the file “PSDX.8bi”
Picture Package Filter 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “ChannelPort.8bf”
Pinch 19.1.2 - from the file “Standard MultiPlugin.8bf”
Pixar 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “Pixar.8bi”
Plaster 19.1.2 - from the file “Filter Gallery.8bf”
Plastic Wrap 19.1.2 - from the file “Filter Gallery.8bf”
PLY 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “U3D.8bi”
Pointillize 19.1.2 - from the file “Standard MultiPlugin.8bf”
Polar Coordinates 19.1.2 - from the file “Standard MultiPlugin.8bf”
Portable Bit Map 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “PBM.8bi”
Poster Edges 19.1.2 - from the file “Filter Gallery.8bf”
PRC 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “U3D.8bi”
Radial Blur 19.1.2 - from the file “Standard MultiPlugin.8bf”
Radiance 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “Radiance.8bi”
Range 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “statistics.8ba”
Render Color Lookup Grid 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “Export3DLUT.8be”
Reticulation 19.1.2 - from the file “Filter Gallery.8bf”
Ripple 19.1.2 - from the file “Standard MultiPlugin.8bf”
Rough Pastels 19.1.2 - from the file “Filter Gallery.8bf”
Save for Web 19.1.2 - from the file “Save for Web.8be”
ScriptingSupport 19.1.2 - from the file “ScriptingSupport.8li”
Shake Reduction 19.1.2 - from the file “Shake Reduction.8bf”
Shear 19.1.2 - from the file “Standard MultiPlugin.8bf”
Skewness 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “statistics.8ba”
Smart Blur 19.1.2 - from the file “Standard MultiPlugin.8bf”
Smudge Stick 19.1.2 - from the file “Filter Gallery.8bf”
Solarize 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “Solarize.8bf”
Spaces 19.1.2 - from the file “Spaces.8li”
Spatter 19.1.2 - from the file “Filter Gallery.8bf”
Spherize 19.1.2 - from the file “Standard MultiPlugin.8bf”
Sponge 19.1.2 - from the file “Filter Gallery.8bf”
Sprayed Strokes 19.1.2 - from the file “Filter Gallery.8bf”
Stained Glass 19.1.2 - from the file “Filter Gallery.8bf”
Stamp 19.1.2 - from the file “Filter Gallery.8bf”
Standard Deviation 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “statistics.8ba”
STL 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “U3D.8bi”
Sumi-e 19.1.2 - from the file “Filter Gallery.8bf”
Summation 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “statistics.8ba”
Targa 19.1.2 - from the file “Standard MultiPlugin.8bf”
Texturizer 19.1.2 - from the file “Filter Gallery.8bf”
Tiles 19.1.2 - from the file “Standard MultiPlugin.8bf”
Torn Edges 19.1.2 - from the file “Filter Gallery.8bf”
Twirl 19.1.2 - from the file “Standard MultiPlugin.8bf”
U3D 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “U3D.8bi”
Underpainting 19.1.2 - from the file “Filter Gallery.8bf”
Vanishing Point 19.1.2 - from the file “VanishingPoint.8bf”
Variance 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “statistics.8ba”
Virtual Reality Modeling Language | VRML 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “U3D.8bi”
Water Paper 19.1.2 - from the file “Filter Gallery.8bf”
Watercolor 19.1.2 - from the file “Filter Gallery.8bf”
Wave 19.1.2 - from the file “Standard MultiPlugin.8bf”
Wavefront|OBJ 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “U3D.8bi”
WIA Support 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “WIASupport.8li”
Wind 19.1.2 - from the file “Standard MultiPlugin.8bf”
Wireless Bitmap 19.1.2 (20180302.r.277 2018/03/02: 1160083) - from the file “WBMP.8bi”
ZigZag 19.1.2 - from the file “Standard MultiPlugin.8bf”
Optional and third party plug-ins: NONE
Duplicate and Disabled plug-ins: NONE
Plug-ins that failed to load: NONE
Extensions:
com.adobe.Butler.backend 2.0.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.Butler.backend\index.html”
com.adobe.inapp.purchase 2.11.27 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_2_11_27\purchase.html”
New Document 2.1.1 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_CMDN_EXTENSION_2_1_1_004\fnft.html”
Libraries 2.11.27 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_2_11_27\index.html”
Start 2.1.1 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CCX_START_EXTENSION_2_1_1_076\index.html”
Adobe Color Themes 6.1.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.KulerPanel.html\index.html”
Export As 3.1.2 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.photoshop.crema\PSPanel\dialog.html”
Installed TWAIN devices: NONE
General System Info
Windows 10 Pro 1709
Core i5-4590 3.30 ghz
Hard drive is SSD
Memory 16GB
Intel HD Graphics 4600
Hi KenHutchinson,
Sorry that Photoshop 19.1.2 is freezing/crashing as soon as you open a file. Thanks for providing a detailed information.
I see that you are not using the latest version of Photoshop which is 19.1.3. Please update to the latest version and let us know if that helps. Refer Keeping Photoshop Up-To-Date
Regards,
Akash
https://forums.adobe.com/people/Ken+Hutchinson wrote
Hello,
Adobe Photoshop Version: Should be 19.1.3
DELL
Thanks, I had done the update in CC but it seemed to stick at .2, I just updated to .3 and will look up that newer driver on Dell. I tried the one from the intel site and it wouldn't run, saying I already have a newer version.
I'll report back - thanks!
I am getting this error for the Dell driver as well as the Intel package:
I would recommend that you contact the GPU manufacturer and get the correct/updated drivers installed. Did the update to Ps 19.1.3 helped fixing the freezing problem?
Let us know how it goes.
~Akash
My main issue is that this has been working fine and it seems to tie back to fall creator update as nothing else was changed. Sadly it's past the 10 day rollback so I am stuck doing a reinstall if I need to.
I did update to 19.1.3 and that didn't help. I do not understand how the GPU driver changed anything since nothing was updated or changed to the PC. I will reinstall windows and prevent the fall update as that seems to be the only fix.
Reinstalled Windows 10 Pro, installed adobe only so far, and it hasn't crashed.
system info seems to show all the same driver info minus the opengl crash.
Adobe Photoshop Version: 19.1.3 20180323.r.293 2018/03/23: 1163761 x64
Free memory: 7127 MB
Highbeam: Enabled.
TextComposer: Latin
Display: 1
Display: 2
AIFOGLInitialized=1
OGLContextCreated=1
NumGLGPUs=1
NumCLGPUs=1
NumNativeGPUs=0
clgpu[0].CLBandwidth=2.08177e+10
clgpu[0].CLCompute=167.201
GUIDBucket:
Scratch volume(s):
Startup, 185.8G, 153.6G free
Photoshop.dll Adobe Photoshop CC 2018 19.1.3
Plugin.dll Adobe Photoshop CC 2018 19.1.3
PSArt.dll Adobe Photoshop CC 2018 19.1.3
PSCloud.dll 1.0.0.1
PSViews.dll Adobe Photoshop CC 2018 19.1.3
Required plug-ins:
3D Studio 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “U3D.8bi”
Accented Edges 19.1.3 - from the file “Filter Gallery.8bf”
Adaptive Wide Angle 19.1.3 - from the file “Adaptive Wide Angle.8bf”
Angled Strokes 19.1.3 - from the file “Filter Gallery.8bf”
Average 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “Average.8bf”
Bas Relief 19.1.3 - from the file “Filter Gallery.8bf”
BMP 19.1.3 - from the file “Standard MultiPlugin.8bf”
Chalk && Charcoal 19.1.3 - from the file “Filter Gallery.8bf”
Chrome 19.1.3 - from the file “Filter Gallery.8bf”
Cineon 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “Cineon.8bi”
Clouds 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “Clouds.8bf”
Collada 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “U3D.8bi”
Color Halftone 19.1.3 - from the file “Standard MultiPlugin.8bf”
Colored Pencil 19.1.3 - from the file “Filter Gallery.8bf”
CompuServe GIF 19.1.3 - from the file “Standard MultiPlugin.8bf”
Conté Crayon 19.1.3 - from the file “Filter Gallery.8bf”
Craquelure 19.1.3 - from the file “Filter Gallery.8bf”
Crop and Straighten Photos 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “CropPhotosAuto.8li”
Crop and Straighten Photos Filter 19.1.3 - from the file “Standard MultiPlugin.8bf”
Crosshatch 19.1.3 - from the file “Filter Gallery.8bf”
Crystallize 19.1.3 - from the file “Standard MultiPlugin.8bf”
Cutout 19.1.3 - from the file “Filter Gallery.8bf”
Dark Strokes 19.1.3 - from the file “Filter Gallery.8bf”
De-Interlace 19.1.3 - from the file “Standard MultiPlugin.8bf”
Dicom 19.1.3 - from the file “Dicom.8bi”
Difference Clouds 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “Clouds.8bf”
Diffuse Glow 19.1.3 - from the file “Filter Gallery.8bf”
Displace 19.1.3 - from the file “Standard MultiPlugin.8bf”
Dry Brush 19.1.3 - from the file “Filter Gallery.8bf”
Eazel Acquire 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “EazelAcquire.8ba”
Entropy 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “statistics.8ba”
Export Color Lookup Tables 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “Export3DLUT.8be”
Extrude 19.1.3 - from the file “Standard MultiPlugin.8bf”
FastCore Routines 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “FastCore.8bx”
Fibers 19.1.3 - from the file “Standard MultiPlugin.8bf”
Film Grain 19.1.3 - from the file “Filter Gallery.8bf”
Filter Gallery 19.1.3 - from the file “Filter Gallery.8bf”
Flash 3D 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “U3D.8bi”
Fresco 19.1.3 - from the file “Filter Gallery.8bf”
Glass 19.1.3 - from the file “Filter Gallery.8bf”
Glowing Edges 19.1.3 - from the file “Filter Gallery.8bf”
Google Earth 4 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “U3D.8bi”
Graphic Pen 19.1.3 - from the file “Filter Gallery.8bf”
Halftone Pattern 19.1.3 - from the file “Filter Gallery.8bf”
Halide Bottlenecks 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “HalideBottlenecks.8bx”
HDRMergeUI 19.1.3 - from the file “HDRMergeUI.8bf”
HSB/HSL 19.1.3 - from the file “Standard MultiPlugin.8bf”
IFF Format 19.1.3 - from the file “Standard MultiPlugin.8bf”
IGES 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “U3D.8bi”
Ink Outlines 19.1.3 - from the file “Filter Gallery.8bf”
JPEG 2000 19.1.3 - from the file “JPEG2000.8bi”
Kurtosis 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “statistics.8ba”
Lens Blur 19.1.3 - from the file “Lens Blur.8bf”
Lens Correction 19.1.3 - from the file “Lens Correction.8bf”
Lens Flare 19.1.3 - from the file “Standard MultiPlugin.8bf”
Liquify 19.1.3 - from the file “Liquify.8bf”
Matlab Operation 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “ChannelPort.8bf”
Maximum 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “statistics.8ba”
Mean 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “statistics.8ba”
Measurement Core 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “MeasurementCore.8me”
Median 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “statistics.8ba”
Mezzotint 19.1.3 - from the file “Standard MultiPlugin.8bf”
Minimum 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “statistics.8ba”
MMXCore Routines 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “MMXCore.8bx”
Mosaic Tiles 19.1.3 - from the file “Filter Gallery.8bf”
Multiprocessor Support 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “MultiProcessor Support.8bx”
Neon Glow 19.1.3 - from the file “Filter Gallery.8bf”
Note Paper 19.1.3 - from the file “Filter Gallery.8bf”
NTSC Colors 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “NTSC Colors.8bf”
Ocean Ripple 19.1.3 - from the file “Filter Gallery.8bf”
OpenEXR 19.1.3 - from the file “Standard MultiPlugin.8bf”
Paint Daubs 19.1.3 - from the file “Filter Gallery.8bf”
Palette Knife 19.1.3 - from the file “Filter Gallery.8bf”
Patchwork 19.1.3 - from the file “Filter Gallery.8bf”
Paths to Illustrator 19.1.3 - from the file “Standard MultiPlugin.8bf”
PCX 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “PCX.8bi”
Photocopy 19.1.3 - from the file “Filter Gallery.8bf”
Photoshop 3D Engine 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “Photoshop3DEngine.8bi”
Picture Package Filter 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “ChannelPort.8bf”
Pinch 19.1.3 - from the file “Standard MultiPlugin.8bf”
Pixar 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “Pixar.8bi”
Plaster 19.1.3 - from the file “Filter Gallery.8bf”
Plastic Wrap 19.1.3 - from the file “Filter Gallery.8bf”
PLY 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “U3D.8bi”
Pointillize 19.1.3 - from the file “Standard MultiPlugin.8bf”
Polar Coordinates 19.1.3 - from the file “Standard MultiPlugin.8bf”
Portable Bit Map 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “PBM.8bi”
Poster Edges 19.1.3 - from the file “Filter Gallery.8bf”
PRC 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “U3D.8bi”
Radial Blur 19.1.3 - from the file “Standard MultiPlugin.8bf”
Radiance 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “Radiance.8bi”
Range 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “statistics.8ba”
Render Color Lookup Grid 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “Export3DLUT.8be”
Reticulation 19.1.3 - from the file “Filter Gallery.8bf”
Ripple 19.1.3 - from the file “Standard MultiPlugin.8bf”
Rough Pastels 19.1.3 - from the file “Filter Gallery.8bf”
Save for Web 19.1.3 - from the file “Save for Web.8be”
ScriptingSupport 19.1.3 - from the file “ScriptingSupport.8li”
Shake Reduction 19.1.3 - from the file “Shake Reduction.8bf”
Shear 19.1.3 - from the file “Standard MultiPlugin.8bf”
Skewness 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “statistics.8ba”
Smart Blur 19.1.3 - from the file “Standard MultiPlugin.8bf”
Smudge Stick 19.1.3 - from the file “Filter Gallery.8bf”
Solarize 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “Solarize.8bf”
Spaces 19.1.3 - from the file “Spaces.8li”
Spatter 19.1.3 - from the file “Filter Gallery.8bf”
Spherize 19.1.3 - from the file “Standard MultiPlugin.8bf”
Sponge 19.1.3 - from the file “Filter Gallery.8bf”
Sprayed Strokes 19.1.3 - from the file “Filter Gallery.8bf”
Stained Glass 19.1.3 - from the file “Filter Gallery.8bf”
Stamp 19.1.3 - from the file “Filter Gallery.8bf”
Standard Deviation 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “statistics.8ba”
STL 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “U3D.8bi”
Sumi-e 19.1.3 - from the file “Filter Gallery.8bf”
Summation 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “statistics.8ba”
Targa 19.1.3 - from the file “Standard MultiPlugin.8bf”
Texturizer 19.1.3 - from the file “Filter Gallery.8bf”
Tiles 19.1.3 - from the file “Standard MultiPlugin.8bf”
Torn Edges 19.1.3 - from the file “Filter Gallery.8bf”
Twirl 19.1.3 - from the file “Standard MultiPlugin.8bf”
U3D 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “U3D.8bi”
Underpainting 19.1.3 - from the file “Filter Gallery.8bf”
Vanishing Point 19.1.3 - from the file “VanishingPoint.8bf”
Variance 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “statistics.8ba”
Virtual Reality Modeling Language | VRML 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “U3D.8bi”
Water Paper 19.1.3 - from the file “Filter Gallery.8bf”
Watercolor 19.1.3 - from the file “Filter Gallery.8bf”
Wave 19.1.3 - from the file “Standard MultiPlugin.8bf”
Wavefront|OBJ 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “U3D.8bi”
WIA Support 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “WIASupport.8li”
Wind 19.1.3 - from the file “Standard MultiPlugin.8bf”
Wireless Bitmap 19.1.3 (20180323.r.293 2018/03/23: 1163761) - from the file “WBMP.8bi”
ZigZag 19.1.3 - from the file “Standard MultiPlugin.8bf”
Extensions:
com.adobe.inapp.purchase 2.13.141 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_2_13_141\purchaseStock.html”
Libraries 2.13.141 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_2_13_141\index.html”
com.adobe.inapp.typekit.purchase 1.0.0 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_2_13_141\purchaseTypekit.html”
Going to do all the windows updates, reboot and see if it still resumes working.
Thanks for the update. Let us know how it keeps up for the next few days.
~Akash
The update doesn't explain why it isn't working though. I reinstalled all my programs, did updates, and rebooted and it's working fine. What would cause it to suddenly stop working like it did? It's very frustrating because now I have to resetup the entire computer.
OS updates often affect the API's of applications that causes crash/freeze and other unexpected issues,
Since you have installed the OS and have updated it, that might've improved/resolve the issue.
~Akash
