• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Importing ipad or Sony EX3 (mp4s) only getting audio after import.
New Here ,
Apr 25, 2018 Apr 25, 2018
Ok, just updated to the newest Premiere 12.1.1 and when I import/drag/pull from browser, any ipad(mov) or Sony ex3(mp4) footage..it only imports the audio with no video. Older version- works just fine.
Anybody having this issue? and any work arounds, besides converting to another format..(which will take to much time)
Views
777
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
I have no problems with EX1R, PMW320 files imported using Media Browser on a Win10 machine
Votes
Translate
Translate
Report
Report
New Here ,
I am on a mac pro..even when I open the adobe browser, it does not even see the files.
Votes
Translate
Translate
Report
Report
Community Expert ,
How are you transferring the files from the sxs card?
Votes
Translate
Translate
Report
Report
New Here ,
No..I moved them to an external thunderbolt drive. I also tried from the desktop..same issue. It only seems to happen with the 12.1.1 ver. any older version of the software works fine. I can also see the files fine in the Sony XDCAM browser.
Votes
Translate
Translate
Report
Report
Community Expert ,
in this case, same routine I guess :
uninstall
run cc cleaner
reinstall
Votes
Translate
Translate
Report
Report
Explorer ,
We've run onto this in our systems as well. I've found that deleting the Media Cache folder (/Users/fcp/Library/Application Support/Adobe/Common) and Media Cache Files folder and then importing the footage into a blank project works. It's a little more involved if you've already started editing with that footage.
Let me know if that works on your system, too. This problem has been driving us crazy.
Votes
Translate
Translate
Report
Report
Community Beginner ,
Was having similar problem - except with Sony A7III .mov files. Initial import works fine. But when I re-opened project - 1/2 of all the camera files were offline. Re-linking them replaced the file with audio only.
My solution was to select the files that were audio only and use the "Make Offline.." drop down selection and then with the same clips highlighted use the "Link Media..." selection. Then the clip reverted to it's original format - video and audio.
Why do we need to do this Adobe? Fix this soon please!
Votes
Translate
Translate
Report
Report
New Here ,
Thanks! I will give it a try and let you all know...
Votes
Translate
Translate
Report
Report
Well my previously mentioned work-around worked a few times. Was missing one clip in my last edit and tried it and it didn't work.
Not sure what to try next except go back to 12.1. ?
What am I paying ADOBE for each month?
Votes
Translate
Translate
Report
Report
Tried one more thing - made a duplicate of the clip in finder and changed it's extension from .mp4 to .mov, imported it and that worked. Why all the other mp4 clips come in fine I'm not sure. All files were shot on the same camera, same set up - just different takes.
Votes
Translate
Translate
Report
Report
Explorer ,
We've also found that renaming the containing folder and importing that usually works.
I think it must have something to do with Premiere creating bad cache files, and then when you import the renamed file or the file from a renamed folder it creates a new, correct, cache file for it. But that's just a guess.
Votes
Translate
Translate
Report
Report
So - I wonder what happens if we clean the cache files?  I'm not going to try it on this project but I may create a test project and try it there.
Votes
Translate
Translate
Report
Report
Explorer ,
That's worked some of the time on our systems - but I have cleared the cache and seen media still get messed up when opening a problematic project.
The workaround was to start a blank project and import the media into that. Then import that project into the problematic project.
It's ... insane.
I've been clearing the cache on the finder level which I think is more reliable - but removes the cache files for every project. So then I've found that if I go and open an old project that had been behaving just fine previously, it'll corrupt clips that had previously been fine.
To us it seems to happen most frequently on .MOVs from DSLRs, but we've seen it with EX1/EX3 .mp4s as well.
Votes
Translate
Translate
Report
Report
New Here ,
Apr 26, 2018 Apr 26, 2018
Well thanks for all your inputs...I tried the clearing the cache, reimporting, deleting and importing..like one of you said half the files come in correct and other half still coming in audio only (Relinking did not work)..I must say..I can not believe Adobe let this thru without testing properly..I will just have to go down a version and wait..seems like the old Avid days..wait 6months then update.
Anyway thanks again all!!
Votes
Translate
Translate
Report
Report
Explorer ,
Apr 27, 2018 Apr 27, 2018
I see a lot of posts with this issue and many with no response from Adobe.
I found with Mac OS 10.11 and the latest CC version that move mp4 files imported from one location but not from a backup location and vice versa. The last remaining file imported properly when moved it up  and out of a sub-folder. Just some observations and maybe not a solution but options...until Adobe addresses it.
Votes
Translate
Translate
Report
Report
Community Expert ,
Apr 28, 2018 Apr 28, 2018
anyone tried deleting your old 'video previews' and 'audio previews' ?
please do not confuse that with clearing media cache ... most crashes
occur because of old video previews not behaving properly with a new
version of the software ... try deleting them even if that will require rendering again
and let me know what happens please
Votes
Translate
Translate
Report
Report
Explorer ,
Tried deleting preview files and media cache. The problem is also with files previously edited into a sequence now displaying as offline. This is a serious problem. Premiere no longer recognizes them as video files. Bad news when trying to finish a project.
Votes
Translate
Translate
Report
Report
Community Expert ,
did you update mac os to latest ?
Votes
Translate
Translate
Report
Report
Explorer ,
May 08, 2018 May 08, 2018
LATEST
I can't update the OS since I'm on a Mac Pro 4.1. There are complicated ways but I just need to finish my project. Adobe throwing monkey wrenches in the works doesn't help with productivity. I went back to Premiere version 12.0 and my files came back online. The major reason for switching to Premiere was because it could handle any format. So much for that.
Votes
Translate
Translate
Report
Report
Community Expert ,
try also deleting your preview videos and audio previews in the 'Document' folder - Adobe
Votes
Translate
Translate
Report
Report
