4 Replies Latest reply on Apr 26, 2018 6:29 AM by Dave__M
    Simple bug with "Find"
    77173862
      This bug has existed across countless Acrobat versions!  If you do a Find, click Next until you're on the last item, and then click Previous, the software will say "no more matches were found".  It should instead find the previous match!
      It's beyond my comprehension how this simple bug has gone unfixed for so long.
        • 1. Re: Simple bug with "Find"
          Dave__M Adobe Community Professional
          Very curious... I just opened up a 13 page PDF, did a search for a fairly commonly used word, and clicked my way through to the last instance.  An additional click of Next jumped back to the very 1st instance on page 1.  When on that last one on page 13, I can hit Previous,  and successfully be brought to the previous instance.  So in my installation (Windows / Acrobat Pro DC v. 2018.011.20038), the bug is not apparent.  What exact version are you using, and OS?
          My best,
          Dave
          • 2. Re: Simple bug with "Find"
            AnandSri Adobe Employee (Admin)
            Hi Zz,
            We apologize for the inconvenience caused, as per the description above, when you use "Find" instead of finding the previous match, Acrobat says "no more matches were found", Is that correct?
            What is the dot version of Acrobat installed? To identify refer to Identify the product and its version for Acrobat and Reader DC
            Is it a Mac or Windows machine? Would you mind sharing a screenshot of the error/issue you are getting? To share a screenshot, please refer to https://forums.adobe.com/docs/DOC-7043#jive_content_id_How_do_I_attach_a_screenshot
            We would highly appreciate if you think this is a bug and need modifications, please use the URL to share your feedback to request new features or suggest modifications to existing features Feature Request/Bug Report Form
            Please share your findings.
            Regards,
            Anand Sri.
            • 3. Re: Simple bug with "Find"
              77173862 Level 1
              Anand, thanks for your reply.  I'm using Win10, Acrobat Pro 2017, 2017.008.30051.
              To replicate: hit Ctrl-F, type a word that appears multiple times in the PDF, and click Next until it reaches the last occurrence of the word.  Now if you click Next or Previous, a pop-up window will appear stating "Adobe Acrobat has finished searching the document. No more matches were found.".  The bug is that clicking Previous at that point should find the previous occurrence.
              Apparently Dave's software loops the find.
              • 4. Re: Simple bug with "Find"
                I would also wonder if it is document specific.  PDFs come from a million places, and are produced a million ways.  That said, does the problem happen with all PDF documents for you?  The document I used contained structural tags.  If you go to Document Properties (Ctrl-D), check to the lower left of the Description Tab.  A tagged PDF will be more precisely defined under the skin, and that might be why mine behaved the way it did, and yours didn't... purely speculation.
                My best,
                Dave
