hi, i am using photoshop variables to import csv file into photoshop.
the csv file contains three type of text lines.
1. 50 letter text line
2. 75 letter text line
3. 100 letter text line
i dont no anything about scripting. so i need help
i want a script that do following things.
for example, if text line contains "50 letters" set font size to "140 px".
if text line contains "75 letters" set font size to "110 px"
if text line contains "100 letters" set font size to "80 px"
This should keep the visibility the same:
...#target photoshop
var doc = activeDocument;
var txtLayer1 = doc.layers.getByName('Text1');
var txtLayer2 = doc.layers.getByName('Text2');
var txtLayer3 = doc.layers.getByName('Text3');
setSize (txtLayer1)
setSize (txtLayer2)
setSize (txtLayer2)
function setSize(layer){
var vis = layer.visible
doc.activeLayer = layer;
try{
if(layer.textItem.contents.length<51){layer.textItem.size = 140}
else if(layer.textItem.contents.length<76){layer.textIt
You give no information about the Photoshop document. Canvas size pixel wide pixel high print resolution, Text also has a font all are not the same size characters vary in size in some and are fixed size in other. Text is very complex. Fully expand some actions that add text and look at the expended text steps.
i have excel file
& i am using photoshop variables feature to import this data.
I am using variables visibility feature to switch between this three layer
I am exporting this files via "Data sets as files" feature, which creates 200+ psd files.
for example, if contains "25 to 50 letters" set font size to "140 px".
if contains "51 to 75 letters" set font size to "110 px"
if contains "76 to 100 letters" set font size to "80 px"
then i will create an action like this one.
& apply them to all 200+ psd files via batch function.
You need to import your cvs file into a string variable and break it into lines using the split command:
var cvsLines = myCVSstring.split('\n');
for(var i=0;i<cvsLines.length;i++){
//put code here to make a text layer
var txtLayer = doc.activeLayer;//need code to create this text layer.
if(cvsLines.length<60){txtLayer.size = 140}
else if(cvsLines.length<85){txtLayer.size = 110}
else{txtLayer.size = 80}
thank you for a script sir,
i have save your code as jsx file.
but when i load your script, it gives me following error
one again, thanks for your help
My code is incomplete. It just shows how to split the text in a CVS string into lines and get their length, and then apply a size to an existing text layer. You still need to write the code to open the cvs file, and put its contents into a string. You also need to write the code to create the text layers, if they don't already exist.
Will have to look at your files later, when I'm at my computer.
Try this after you import your data sets.
#target photoshop
setSize (txtLayer1)
setSize (txtLayer2)
setSize (txtLayer2)
try{
else if(layer.textItem.contents.length<76){layer.textItem.size = 110}
else{layer.textItem.size = 80}
catch(e){}
Thank you so much, your code work perfectly.
However their is one problem
When i export files via "Data sets as files", it creates 200+ files
Each file will have 1 active text layer & 2 hidden text layers.
For example, the 3rd dataset file have
Text1 & Text2 layer are hidden &
Text3 layer is visible
This script working fine but it is making all three layers visible
#target photoshop
setSize (txtLayer1)
setSize (txtLayer2)
setSize (txtLayer2)
try{
catch(e){}
layer.visible = vis
All problems are solved, thnx you one again.
You made my day, god bless you
hi, i got one more problem after using your script.
The problem is with "Line Spacing"
if line contains only few words, above problem occurs.
so if u can change your script to do following things, it will very helpfull
for example, if Line contains "25 to 50 letters" set font size to "140 px".& Set Line Spacing to "250"
if Line contains "51 to 75 letters" set font size to "110 px" & Set Line Spacing to "170"
if Line contains "76 to 100 letters" set font size to "80 px" & Set Line Spacing to "130"
& if can you do following thing with your script
align Text layer center to the canvas
You can try this:
#target photoshop
setSize (txtLayer1)
setSize (txtLayer2)
setSize (txtLayer2)
try{
layer.textItem.leading = 140
alignLayer ();
layer.textItem.leading = 110
alignLayer ();
else{
layer.textItem.leading = 80
alignLayer ();
catch(e){}
layer.visible = vis
function alignLayer(){
var idslct = charIDToTypeID( "slct" );
var desc2 = new ActionDescriptor();
var idnull = charIDToTypeID( "null" );
var ref1 = new ActionReference();
var idLyr = charIDToTypeID( "Lyr " );
ref1.putName( idLyr, "Background" );
desc2.putReference( idnull, ref1 );
var idselectionModifier = stringIDToTypeID( "selectionModifier" );
var idselectionModifierType = stringIDToTypeID( "selectionModifierType" );
var idaddToSelection = stringIDToTypeID( "addToSelection" );
desc2.putEnumerated( idselectionModifier, idselectionModifierType, idaddToSelection );
var idMkVs = charIDToTypeID( "MkVs" );
desc2.putBoolean( idMkVs, false );
var idLyrI = charIDToTypeID( "LyrI" );
var list1 = new ActionList();
list1.putInteger( 1 );
list1.putInteger( 2 );
desc2.putList( idLyrI, list1 );
executeAction( idslct, desc2, DialogModes.NO );
var idAlgn = charIDToTypeID( "Algn" );
var desc4 = new ActionDescriptor();
var ref2 = new ActionReference();
var idOrdn = charIDToTypeID( "Ordn" );
var idTrgt = charIDToTypeID( "Trgt" );
ref2.putEnumerated( idLyr, idOrdn, idTrgt );
desc4.putReference( idnull, ref2 );
var idUsng = charIDToTypeID( "Usng" );
var idADSt = charIDToTypeID( "ADSt" );
var idAdCH = charIDToTypeID( "AdCH" );
desc4.putEnumerated( idUsng, idADSt, idAdCH );
executeAction( idAlgn, desc4, DialogModes.NO );
hi, thank you for your response.
your script works very well.
however their is one problem with align.
the script is aligning, Text layer center to the canvas horizontally not vertically.
i mean script is centering textlayer horizontally, but it is not centering textlayer vertically.
thank you ones again for your help
Do you want it to center both horizontally and vertically? Or just vertically?
This script will align in both directions.
#target photoshop
setSize (txtLayer1)
setSize (txtLayer2)
setSize (txtLayer2)
try{
alignLayer ();
alignLayer ();
else{
alignLayer ();
catch(e){}
layer.visible = vis
var idAlgn = charIDToTypeID( "Algn" ); //Align Horizontally
var idAlgn = charIDToTypeID( "Algn" ); //Align Vertically
var desc3 = new ActionDescriptor();
ref1.putEnumerated( idLyr, idOrdn, idTrgt );
desc3.putReference( idnull, ref1 );
var idAdCV = charIDToTypeID( "AdCV" );
desc3.putEnumerated( idUsng, idADSt, idAdCV );
executeAction( idAlgn, desc3, DialogModes.NO );
thank you so so much.
hello Chuck Uebele,
i got one problem,
as you can see in above picture, some paragraph fit perfectly in textbox
& some does't,
i want the above image should look like this.
i want a script that can do following things :
if paragraph have 5 lines (like 1st image) then its ok ,do nothing , but
if paragraph have 4 lines (like 2nd image) then change layer's vertical location (Y: position)
ex. if layer's position are like this =
x: 900px
y: 500px
change its y: position to 520px.
so, 4 line paragraph look like 3rd image.
note: i have tried to center text layer both horizontally & vertically. it is not working. i mean i am not able to get result like 3rd image.
hope! you can help me.
That's a hard one, as if you use a text box, I don't know of anyway to center just the text within the box. I've always used hard returns for new lines, when I need to center text like that.
https://forums.adobe.com/people/Chuck+Uebele
To fully align the text in textbox, you can try this script
// Horizontal alignment
activeDocument.activeLayer.textItem.justification = Justification.CENTER;
// Vertical alignment
var r = new ActionReference();
r.putProperty(stringIDToTypeID("property"), stringIDToTypeID("textKey"));
r.putEnumerated(stringIDToTypeID("layer"), stringIDToTypeID("ordinal"), stringIDToTypeID("targetEnum"));
var yy = 1;
try { yy = executeActionGet(r).getObjectValue(stringIDToTypeID("textKey")).getObjectValue(stringIDToTypeID("transform")).getDouble(stringIDToTypeID("yy")); } catch(e) {}
var box_height = executeActionGet(r).getObjectValue(stringIDToTypeID("textKey")).getList(stringIDToTypeID("textShape")).getObjectValue(0).getObjectValue(stringIDToTypeID("bounds")).getDouble(stringIDToTypeID("bottom"));
box_height = box_height*yy;
app.preferences.rulerUnits = Units.POINTS;
var shift = (box_height - (activeDocument.activeLayer.bounds[3].value - activeDocument.activeLayer.bounds[1].value))/2;
activeDocument.activeLayer.textItem.baselineShift = -shift;
thanx for your reply,
your script works. for 4line paragraph
but it didn't work for 5line paragraph
any idea ! what to do?
Give please a simple file with an example of text that is not aligning
here are sample files
https://drive.google.com/open?id=1tIkPQhrSm7UI4q_jFoCMthZ_6x_1yZMS
OK. Your file is not compatible with CS6, but nevertheless here's a new script that works in CC2018.
var yy = 1;
var d = executeActionGet(r).getObjectValue(stringIDToTypeID("textKey")).getList(stringIDToTypeID("textShape")).getObjectValue(0).getObjectValue(stringIDToTypeID("bounds"));
var box_height = d.getDouble(stringIDToTypeID("bottom")) - d.getDouble(stringIDToTypeID("top"));
