5 Replies Latest reply on Apr 26, 2018 12:44 PM by SuperMerlin
    C# resize image and save
    marcinz51839902
      Hello!
      I look for a sample code that`s resize the image to lower and save it with the 12 (the highest) level quality.
      I want the sample to be in .NET C#.
      I was searching over the Adobe group and I didn`t find any sample.
      Can you help me?
      Can you paste me some C# sample?
      Thank you in advance
      Marcin
        • 1. Re: C# resize image and save
          SuperMerlin Level 5
          using System;
          namespace PSexample
              class Program
                  static void Main(string[] args)
                      dynamic app = Activator.CreateInstance(Type.GetTypeFromProgID("Photoshop.Application"));
                      if (app.Documents.Count == 0) return;
                      app.Preferences.RulerUnits = 1; //pixels
                      //resize to a width of 1000 pixels with constraint
                      app.ActiveDocument.ResizeImage(1000 /*width*/, null/*height*/, 300/*resolution*/,5/* ResampleMethod.BICUBICSHARPER*/);
                      string saveFile = @"c:/utils/test.jpg";
                      dynamic jpgOpts = Activator.CreateInstance(Type.GetTypeFromProgID("Photoshop.JPEGSaveOptions"));
                      jpgOpts.embedColorProfile = true;
                      jpgOpts.formatOptions = 1 /* FormatOptions.STANDARDBASELINE*/;
                      jpgOpts.matte = 1 /*MatteType.NONE*/;
                      jpgOpts.quality = 12; //1-12
                      app.ActiveDocument.SaveAs(saveFile, jpgOpts, true, 2); //2= lowercase
                      app.ActiveDocument.Close(2); /* Close document */
          Late binding example.
          • 2. Re: C# resize image and save
            marcinz51839902 Level 1
            Ok. Thank you. I really apprieciate it.
            But how can I open a jpg image from C# code in Adobe Photoshop.
            I would like to:
            a) have the filelist array of jpg files in Visual Studio Software
            b) open the image file (based on the array of a) ) in Photoshop, resize it and save it to output resized jpg file.
            Can you help me with opening jpg file in Photoshop based on C# filelist array ?
            Thank you again.
            Regards
            Marcin
            • 3. Re: C# resize image and save
              SuperMerlin Level 5
              using System;
              using System.IO;
              using System.Linq;
              using System.Text.RegularExpressions;
              namespace PSexample
                  class Program
                          Regex reg = new Regex(@"(?i)\.(jpg|jpeg)$"); //select jpg files only
                          //change folder to suit
                              var files = Directory.GetFiles(@"d:/a test", "*.*").Where(path => reg.IsMatch(path)).ToList();
                          foreach (string file in files)
                              app.open(file);
                              string Name = app.ActiveDocument.Name;
                              //resize to a width of 300 pixels with constraint
                              app.ActiveDocument.ResizeImage(300 /*width*/, null/*height*/, 300/*resolution*/, 5/* ResampleMethod.BICUBICSHARPER*/);
                              string saveFile = @"c:/utils/"+ Name;
              • 4. Re: C# resize image and save
                Thank you I had to change the Identity from "The launching user" to "The interactive user" on the properties pane for Component services/My computer/DCOM Config/Photoshop ActionReference, because I got DCOM error.
                But I have one more question to you.
                How to keep aspect ration while resizing?
                Regards
                Marcin
                • 5. Re: C# resize image and save
                  SuperMerlin Level 5
                  You only supply the width or the height NOT BOTH!
                  As you see in this case the height has been set to null.
