Hi! What are options to smooth the edges of a rounded photoshop layer? My graphic (of a ring) has pixelated edges. It is not a 3D layer. Thank you!
How much are you scaling it up? You can't do that without getting the jaggies, you know.
Is the comp window at more than 100% Is the resolution not set at Full?
Could be any kind of Operator Error.......
Hi Dave!
I'm not scaling whatsoever. The graphics were made to 1920 x 1280. And when I export with HD settings, they still have some pixelation.
Can you make a grab of your entire AE user interface? But before you do, please hit the "u" key twice to reveal any modified properties on the layer in question AND highlight the layer in question in the project pane.
Once you have the grab, you should be able to just drag it into your post.
Nevermind... think I'm good here. How do you change the wipe center of the clock wipe effect? It keeps resetting.
I'd check for an unintended Wipe Center keyframe. If you highlight the effect in the Effect Controls pane, you can drag the center anywhere you want.
