• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Printed Documents crash in RH6
New Here ,
Aug 19, 2008 Aug 19, 2008
In RH 6 - opened a Printed Documentation layout. Set the settings to generate a Word document, create one book, retain hyperlinks, and use conditional text exclusions.
RH crashed while compiling at the updating stage with a message of "RoboHelp HTML Application has encountered a problem and needs to close. We are sorry for the inconvenience".
Deleted the loose files that had been copied to the SSL folder, deleted the Printed documentation layout, and recreated another one, with the same settings. Same problem occurred.
Checked the macro settings in Word to make sure Adobe was a trusted site. All OK.
Eventually started playing with my layout settings, and discovered that if in the Conditional Build Expression box, I select "None", the Word doc generates.
I need to use my Conditional Builds, anyone know why this might be causing RH to crash?
Views
433
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
Welcome to the forum.
I suspect you have a table with merged cells in the right hand column.
See Snippets on my site. There is a fix.
Votes
Translate
Translate
Report
Report
New Here ,
Aug 21, 2008 Aug 21, 2008
Thank you Peter,
The posted fix in your Snippet solved the problem.
Tannis
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
Glad it helped.
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
