9 Replies Latest reply on May 1, 2018 9:23 AM by hatstead
    Gold certificate seal?
    aislinm53205080
      I have barely amy ps experience. We have pse 12 at the office.   I need to create a gold certificate seal with our company name and logo on it ASAP. Can anyone please provide some direction on the quickest way to achieve this?
        • 1. Re: Gold certificate seal?
          hatstead Adobe Community Professional
          1. Google Gold Seal photos and you will get several hits for royalty free gold seal images.
          2. Select one that is appropriate for your purpose, save it, and then open it in PSE
          3. Activate the type tool to type the company name
          4. Copy/paste the logo.
          • 2. Re: Gold certificate seal?
            aislinm53205080 Level 1
            How would I get the name and logo embossed into the seal? So it's all the same color
            • 3. Re: Gold certificate seal?
              The type tool uses the color of the foreground chip, so you would have to set up the color picker accordingly.
              As for the logo, that may be more challenging. If you are so inclined, post the logo here on the forum page and I will have a look at it and try to provide directions.
              Are you at all familiar with the software, i.e. what can be done with the tools?
              Which version of PSE do you have?
              • 4. Re: Gold certificate seal?
                Mark Sand Level 4
                There are many online tutorials on how to create a gold seal. Google for "gold seal photoshop elements" or similar.
                Or as Hatstead suggested you can Google to find a gold seal image to download, as I have done in the following example.
                Add the logo as a separate layer. Add a Color Fill adjustment layer above the logo layer and select a gold color. Group the 2 layers.
                If you want to preserve the various colors of the logo but in shades of gold, change the Fill Layer's Opacity to Color.
                If the result is too lark or tool light you can adjust it with a Levels adjustment.
                For the text, simply use the Text Tool with a gold color.
                However, it might be more interesting to have the text embossed or recessed. I don't know if PSE12 has this capability built into the Text tool. My PSE2 doesn't so I use this method:
                Add a Low Inner Shadow layer style to the text layer.
                Click the "f" icon in the text layer to bring up the Style Settings menu, and play around with the settings to get the embossed or recessed look.  Note that your Style Settings might look different than my version.
                Here is embossed:
                And here is recessed.
                Checking/unchecking the Use Global Light box will switch from embossed to recessed as I have done.
                • 5. Re: Gold certificate seal?
                  I have pse 12
                  • 6. Re: Gold certificate seal?
                    You can post the seal here via the "Insert Image" icon at the top of the reply box here on the forum page. However, you can not do it in an e-mail reply.
                    • 7. Re: Gold certificate seal?
                      I'm not sure that I can upload the company logo without permission. The
                      trouble I have been coming across is I have only found tutorials for gold
                      coins, which is fine, but also they are in just ps not pse 12. So we have
                      different features. So there ends up being too much I can't do to follow
                      the tutorial correctly. And searching for certificate seal images I find
                      royalty Free ones but you have to pay for them and that's not something I
                      can do either.  Blargh.
                      • 8. Re: Gold certificate seal?
                        Thanks everyone for your input! With all that info iwas able to put the
                        seal together.  Your the bomb! I was able to use the overlay for.the text
                        and image, as that was on a clear background.
                        On Mon, Apr 30, 2018, 9:51 AM Shemakescoolstuff, <addie.murphy1@gmail.com>
                        • 9. Re: Gold certificate seal?
                          You're welcome. Glad to help.
