I am using AE 2018 version 15.1.0 (Build 166) on Windows 10 and I have had an issue with importing some of my videos taken with my GH5 4K 25fps 10-bit 4:2:2, When I try to import most of my videos they will import with no issues, but some just cause AE to freeze on import and crash. They are all videos taken with the same camera and same codec, so I don't know why some won't import. All the videos play back fine in programs like VLC and Media Player Classic and there is no issues with corrupted videos. I tried importing some footage I recorded yesterday and out of the 12 videos, several would not import and cause AE to freeze.
Can anyone help?
My PC specs:
Microsoft Windows 10 Home
Version 10.0.16299 Build 16299
System Type x64-based PC
Processor Intel(R) Core(TM) i7-7700 CPU @ 3.60GHz, 3601 Mhz, 4 Core(s), 8 Logical Processor(s)
BIOS Version/Date American Megatrends Inc. 3016, 27/12/2016
Installed Physical Memory (RAM) 32.0 GB
Total Physical Memory 31.9 GB
Available Physical Memory 26.9 GB
Total Virtual Memory 39.7 GB
Available Virtual Memory 32.4 GB
Page File Space 7.75 GB
Graphics Card: Nvidia GTX 970 4GB
Soundcard: Creative Soundblaster AE-5 (Set to 384khz 32-bit)
Video codec information:
Format : MPEG-4
Format profile: QuickTime
Codec ID : qt 2011.07 (qt /pana)
File size : 4.39 GiB
Duration : 1 min 33 s
Overall bit rate mode : Variable
Overall bit rate : 403 Mb/s
Encoded date : UTC 2018-04-27 16:48:07
Tagged date : UTC 2018-04-27 16:48:07
Video
Format : AVC
Format/Info : Advanced Video Codec
Format profile : High 4:2:2 Intra@L5.1
Format settings, CABAC : No
Format settings, GOP: N=1
Codec ID : avc1
Codec ID/Info : Advanced Video Coding
Duration: 1 min 33 s
Bit rate mode : Variable
Bit rate: 400 Mb/s
Width: 3 840 pixels
Height : 2 160 pixels
Display aspect ratio: 16:9
Frame rate mode: Constant
Frame rate : 25.000 FPS
Standard: Component
Color space: YUV
Chroma subsampling: 4:2:2
Bit depth : 10 bits
Scan type : Progressive
Bits/(Pixel*Frame): 1.929
Stream size : 4.36 GiB (99%)
Color range : Full
Color primaries : BT.709
Transfer characteristics: BT.709
Matrix coefficients: BT.709
Audio
Format: PCM
Format settings : Big / Signed
Format settings, Endianness: Big
Format settings, Sign : Signed
Codec ID : twos
Bit rate mode : Constant
Bit rate : 1 536 kb/s
Channel(s) : 2 channels
Channel positions : Front: L R
Sampling rate : 48.0 kHz
Bit depth: 16 bits
Stream size: 17.1 MiB (0%)
Tagged date: UTC 2018-04-27 16:48:07
Other
Type : Time code
Format: QuickTime TC
Time code of first frame : 13:23:17:20
Time code, striped : Yes
Bit rate mode CBR
I found out the issue was my SD card was corrupting some of my videos and didn't realise, got new cards and have no issues.
