• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
red dot in links (invisible character)
Explorer ,
May 01, 2018 May 01, 2018
Since the last update (I believe as this started recently), if I rename a file in Dreamweaver interface, or retype the link inside html code, sometimes, a red dot appears in front of the link, like this:
If I copy/paste it, red dot will not show up, but using arrows will show I need to hit it twice to pass that spot, so the character is there, whatever that is. It's only visible in the form of that dot.
Why does this happen?
I use iMac, latest High Sierra.
Thank you
Views
4.1K
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
Do you see this in Dreamweaver or in a browser?
I am sorry, this is very confusing. May I ask that you show us your code (HTML and CSS) so that we get a better understanding of the problem. A link to your site is the best way forward.
Wappler, the only real Dreamweaver alternative.
Votes
Translate
Translate
Report
Report
Explorer ,
It's in the code in Dreamweaver. Seeing code in browser shows nothing visual.
I'll try to put it simpler:
I rename a file under Dreamweaver's "Files," and red dot shows up in the code as per screenshot.
In the example above, there is an invisible character in front of "l" letter (links.php). If I put the cursor in front of "l" and press delete, no visual change, second press deletes the letter "l."
There is definitely some sort of character that is not showing to my eyes.
Votes
Translate
Translate
Report
Report
Community Expert ,
I have tried to replicate the problem by following your instructions, no go.
All I can say is that you may try Deleting a corrupted cache file​. Quite often that fixes problems when Dreamweaver goes quirky.
Votes
Translate
Translate
Report
Report
Explorer ,
May 02, 2018 May 02, 2018
Thanks for the hint. Unfortunately, deleting cache did not help. I'll try with reinstalling everything with using Adobe cleaner prior new installation.
Anyway, latest Dreamweaver, macOS High Sierra 10.13.4, renaming a file in DW's file tree causes this red dot to appear. I just tried it again and it happened.
Votes
Translate
Translate
Report
Report
LEGEND ,
I wonder if that is DW telling you that the link checker is noticing that the file (since it's renamed) no longer exists?  Perhaps by changing the filename in your code will make it go away?
Just a thought.
^ _ ^
Votes
Translate
Translate
Report
Report
Explorer ,
As i rename a file, all references to it are renamed, so DW has no reason to tell me file no longer exists.
As I said previously, after the red dot appears, if I try to rename the file again by placing the cursor in front, after hitting delete, nothing happens, yet red dot disappears in the code. That tells me it's some sort of invisible character.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
May 04, 2018 May 04, 2018
Am checking with the team to see if they have seen something like this, stay tuned.
Votes
Translate
Translate
Report
Report
Participant ,
May 07, 2018 May 07, 2018
Hi Rod,
We are unable to recreate this issue at out end.
Is it possible to share a video or a gif of the issue? Also, are you seeing this issue in all your sites or pages or some specific ones?
Divya B C
Adobe Dreamweaver Team
Votes
Translate
Translate
Report
Report
New Here ,
Aug 13, 2018 Aug 13, 2018
Can't help you on the why, but I can tell you what that is.
That red dot is a no-width unicode character. For me it is usually unicode 200B, 200C or 200D. I get this issue a lot when cleaning up the garbage from line areas to make the content publishable.
Zero-width space - Wikipedia
Can't help you as to why you would get it while typing (not a Mac person any more). You might want to check your keyboard bindings as you might have it bound to a specific key stroke.
Addendum:This is what the above code looks like in word with show hidden characters turned on.
Votes
Translate
Translate
Report
Report
New Here ,
Aug 31, 2018 Aug 31, 2018
Same thing here, but I use two Macs for work, one with High Sierra, I believe the other, an iMac, has Sierra (not accessible at this moment, as the office is under construction, I'm WAH for the period it lasts). Both have the problem. It took me a while to figure what was happening, as the red dot is not visible in DW and it causes links to not work, they get the path to the file prepended to the actual link on browsers. What I do is copy the link to TextEdit, select only the link and copy it back, that removes the extra character, but still, it shouldn't be happening.
Votes
Translate
Translate
Report
Report
Adobe Employee ,
Sep 04, 2018 Sep 04, 2018
For those of you that are still facing this issue, please contact the support team for further investigation.
Contact Customer Care
If they are able to reproduce the issue, they can log a bug on your behalf.
Preran
Votes
Translate
Translate
Report
Report
New Here ,
Feb 25, 2020 Feb 25, 2020
Hello and greetings from Holland.
Has this probleem been solved?
I can reproduce it on my iMac as well as on my MacBook Pro.
Kind regards,
Eric Lambermon
Votes
Translate
Translate
Report
Report
New Here ,
Nov 16, 2023 Nov 16, 2023
Hi all
Here's a snippet I took from Dreamweaver when I copied some text in from MS Word
Sorry it's so small.
Votes
Translate
Translate
Report
Report
Community Expert ,
Nov 17, 2023 Nov 17, 2023
LATEST
MS Word contains unwanted junk code that should be removed before pasting into HTML.
For best results, use Edit > Paste Special and select Text Only or Text with Structure and no formatting.
Check code with Validation tool and fix reported errors.
Window > Results > Validation...
Nancy O'Shea— Product User, Community Expert & Moderator
Alt-Web Design & Publishing ~ Web : Print : Graphics : Media
Votes
Translate
Translate
Report
Report
