1 Reply Latest reply on Aug 29, 2008 2:05 AM by Newsgroup_User
    persist flashlog.txt
    josh_aries
      Hi All,
      I am using trace statements in my application.
      The trace works fine and the statements are available in the
      C:\Documents and Settings\Username\Application Data\Macromedia\Flash Player\Logs
      The flashlog.txt page is cleared whenever I close the app and run it again.
      Is there a way to persist the data even after the application is closed.
      Thanks in advance
        • 1. Re: persist flashlog.txt
          Level 7
          Adobe Newsbot hopes that the following resources helps you. NewsBot is experimental and any feedback (reply to this post) on its utility will be appreciated:
          Adobe - Flex 3:
          While Flex applications can be built using only the free Flex SDK, developers can use ... Alert This content requires Flash. Download Flash Player now
          Link: http://www.adobe.com/products/flex/
          Adobe Flex - Wikipedia, the free encyclopedia:
          Flash Player 9 incorporated a new and more robust virtual machine for running the new ActionScript 3. Flex was the first Macromedia product to be re-branded
          Link: http://en.wikipedia.org/wiki/Adobe_Flex
          Adobe - Developer Center : Flex 2: Enabling the Next Generation of:
          Flash Player 9 (until recently referred to as Flash Player 8.5) ships at the same time as the Flex 2 product line. Read more about it in Introducing Flash
          Link: http://www.adobe.com/devnet/flex/articles/flex2_intro.html
          Updated Debug Flash Player 7 for Flex 1.5 and Flex Builder 1.5:
          Solution. Uninstall Debug Flash Player 7 that shipped with Flex 1.5 or Flex Builder 1.5. Using the Macromedia Flash Player Uninstallers:
          Link: http://kb.adobe.com/selfservice/viewContent.do?externalId=3d2855d6
          Adobe Labs - Homepage:
          (Aug 13) An Eclipse plugin version of the Flex Builder software that you can use ... Adobe Flash Player 10 release cand. An opportunity for developers and
          Link: http://labs.adobe.com/
          Disclaimer: This response is generated automatically by the Adobe NewsBot based on Adobe Community Engine.
