I am developing an extension for Premiere Pro.I need to import .mogrt into sequence and am able to do that using the API importMoGRT provided by Premiere Pro.
API
var newTrackItem = activeSeq.importMGT( mogrtToImport.fsName, targetTime.ticks, vidTrackOffset, audTrackOffset);
In the API i am able to change the targetTime.ticks which sets the starting time of the track item.But where do i set the end time/duration of the trackitem
Alternate option
I tried to use the attributes of the trackitem namely start, end, inPoint, outPoint (In the API documentation it is given as read/write attribute).But i am not able to change any of these attributes.
How do i set the start, end, duration of the trackitem?
In the posted sample code, if you add this line right after "if (newTrackItem)", you can set the duration of the new track item.
newTrackItem.end.seconds = newTrackItem.start.seconds + 7.000;
