3 Replies Latest reply on May 8, 2018 3:16 PM by MiloszSzatkowski
    Donwgrading UI script from PS CC to PS C6
    MiloszSzatkowski Level 1
      Hello everybody.
      I created kind of a big script that was working quite well without any dialog box on PS C6. I started implementing dialog box on a computer with PS CC. I was pleased with the result:
      But after going back to other computers with PS C6, I cannot run this altered script anymore.
      I mean - it runs, but prompts following error:
      After running Debugger, all I got was "Window layout failed".
      Yes - script just terminates on "w.show ();" statement.
      The portion of code responsible for UI goes here:
      //choosePref is an array containing objects with data, that I didn't include to make it shorter
      var w = new Window ('dialog {orientation: "row", alignChildren: [" ", "top"]}',
          "Brytowanie grafiki | Graphic division", undefined, {closeButton: false});
          w.alignChildren = "right";
          var tab = w.add ("tabbedpanel");
          tab.alignChildren = ["fill", "fill"];
          tab.preferredSize = [350,300];
          var panels = [];
          var options = [];
          var ToverlapWithGraphic = "Uzyj laczenia z grafiki | Create overlap from graphic:";
          var TaddScaffolding = "Uzyj znacznikow laczenia    Use merging markers:";
          var Toptimal = "Uzywaj mniejszych brytow, gdy to tylko mozliwe | Use smaller divisions whenever possible:";
          var Toverlap = "Szerokosc overlapu | Graphics' overlap:";
          var Tmerger = "Szerokosc zgrzewu | Width of weld:";
          var TmaximumDivision = "Maksymalna szerokosc brytu | Maximal division width:";
          var TminimumDivision = "Minimalna szerokosc brytu | Minimal division width:";
          var ToptimalDivision = "Szerokosc optymalna minimalnego brytu | Optimal width for leftovers' fixing:";
          var Tsuffix = "Suffix:";
          var Tlines_Distance = "Pionowa odleglosc pomiedzy liniami znacznikow | Vertical distance between markers:";
          var TlineWidth = "Grubosc znacznika | Width of marker:";
          var TlineLongitude = "Szerokosc znacznika | How long is a marker:";
          var Tframe = "Grubosc obrysowania | Width of framing:";
          for (var i = 0; i < choosePref.length; i++) {
            panels.push( tab.add ("tab", undefined, choosePref[i].name) );
            panels[i].compareName = choosePref[i].name;
            panels[i].alignChildren = "fill";
            options[i] = panels[i].add ("panel", undefined, "Opcje lokalne | Local options");
            options[i].alignChildren = ["fill", "fill"];
            options[i].add("statictext", undefined, Toverlap);
            options[i].overlap = options[i].add("edittext", undefined, choosePref[i].overlap);
            options[i].add("statictext", undefined, Tmerger);
            options[i].merger =             options[i].add("edittext", undefined, choosePref[i].merger);
            options[i].add("statictext", undefined, TmaximumDivision);
            options[i].maximumDivision =    options[i].add("edittext", undefined, choosePref[i].maximumDivision);
            options[i].add("statictext", undefined, TminimumDivision);
            options[i].minimumDivision =    options[i].add("edittext", undefined, choosePref[i].minimumDivision);
            options[i].add("statictext", undefined, ToptimalDivision);
            options[i].optimalDivision =    options[i].add("edittext", undefined, choosePref[i].optimalDivision);
            options[i].add("statictext", undefined, Tframe);
            options[i].frameSize =    options[i].add("edittext", undefined, choosePref[i].frameSize);
            options[i].optimal =            options[i].add("checkbox", undefined, Toptimal);
                                              options[i].optimal.value = choosePref[i].optimal;
                                              options[i].add("statictext", undefined, Tsuffix);
            options[i].suffix =             options[i].add("edittext", undefined, choosePref[i].suffix);
            options[i].overlapWithGraphic = options[i].add("checkbox", undefined, ToverlapWithGraphic);
            options[i].overlapWithGraphic.value = choosePref[i].overlapWithGraphic;
            options[i].add("panel");
            options[i].addScaffolding =     options[i].add("checkbox", undefined, TaddScaffolding);
            options[i].addScaffolding.value = choosePref[i].addScaffolding;
            options[i].add("statictext", undefined, Tlines_Distance);
            options[i].lines_Distance =
            options[i].add("edittext", undefined, choosePref[i].lines_Distance);
            options[i].add("statictext", undefined, TlineWidth);
            options[i].lineWidth =          options[i].add("edittext", undefined, choosePref[i].lineWidth);
            options[i].add("statictext", undefined, TlineLongitude);
            options[i].lineLongitude =      options[i].add("edittext", undefined, choosePref[i].lineLongitude);
          var tab2 = w.add ("tabbedpanel");
          tab2.alignChildren = ['fill','fill'];
          tab2.preferredSize = [300,700];
          var options2 = tab2.add ("panel", undefined, "Opcje globalne | Global options");
          options2.alignChildren = ['fill','fill'];
          // options2.closing = options2.add("checkbox", undefined, "Zamknij plik po brytowaniu | Close file after division");
          var buttonColor = options2.add ("button", undefined, "Wybierz kolor znacznikow | Choose marker color");
          var colorPanel = options2.add("panel {preferredSize: [500, 10]}", undefined, "Pole koloru");
          colorPanel.graphics.backgroundColor = w.graphics.newBrush (w.graphics.BrushType.SOLID_COLOR, [0.3, 0.3, 0.3]);
          var l_color = greyColorObj;
          buttonColor.onClick = function (){
            app.showColorPicker();
            l_color = app.foregroundColor.cmyk;
            colorPanel.graphics.backgroundColor = colorPanel.graphics.newBrush (w.graphics.BrushType.SOLID_COLOR, [
              mapRGB(app.foregroundColor.rgb.red,0,255,0,1), mapRGB(app.foregroundColor.rgb.green,0,255,0,1),
              mapRGB(app.foregroundColor.rgb.blue,0,255,0,1)]);
          function mapRGB (num, in_min, in_max, out_min, out_max) {
            return (num - in_min) * (out_max - out_min) / (in_max - in_min) + out_min;
          var okButton = options2.add ("iconbutton", undefined, ScriptUI.newImage (File(new File((new File($.fileName)).parent +"/img.png"))));
          var cancelButton = options2.add ("button", undefined, "Anuluj ☕ Cancel", {name: "cancel"});
      var appStarted = false;
      var pref;
      okButton.onClick = function (){
          ///// -- !!!!!!!!!!! pass values to algorithm !!!!!!!!!!! -- /////
            if (tab.selection.compareName.toString() == choosePref[i].name.toString()) {
              var tempIndex = i;
              pref = {};
                pref.compareName = tab.selection.compareName;
                pref.overlapWithGraphic = options[tempIndex].overlapWithGraphic.value;
                pref.addScaffolding = options[tempIndex].addScaffolding.value;
                pref.overlap = parseFloat(options[tempIndex].overlap.text);
                pref.merger = parseFloat(options[tempIndex].merger.text);
                pref.frameSize = parseFloat(options[tempIndex].frameSize.text);
                pref.maximumDivision = parseFloat(options[tempIndex].maximumDivision.text);
                pref.minimumDivision = parseFloat(options[tempIndex].minimumDivision.text);
                pref.optimalDivision = parseFloat(options[tempIndex].optimalDivision.text);
                pref.optimal = options[tempIndex].optimal.value;
                pref.suffix = options[tempIndex].suffix.text;
                pref.lines_Distance = parseFloat(options[tempIndex].lines_Distance.text);
                pref.lineWidth = parseFloat(options[tempIndex].lineWidth.text);
                pref.lineLongitude = parseFloat(options[tempIndex].lineLongitude.text);
                // pref.closing = options2.closing.value;
                appStarted = true;
                w.close();
      cancelButton.onClick = function (){
        appStarted = false;
        w.close();
      w.show ();
      If anyone wants to run full script - GitHub - MiloszSzatkowski/Graphic-division-plugin-photoshop
      The script divides graphics for printing.
      Does anyone have any clue ?
      Thank You for ANY help
