3 Replies Latest reply on May 8, 2018 7:25 AM by сергейз48634810
    Transform effect error
    сергейз48634810 Level 2
      Scaling any photo up to 307% works great and renders in seconds using GPU. Scaling 308% and more turns clip into red with half an hour render time.
        • 1. Re: Transform effect error
          Dean Utian Adobe Community Professional
          How big is your image to start?
          Could you give a screenshot to show what happens in this clip goes red when scaled up to much?
          • 2. Re: Transform effect error
            davidarbor Adobe Community Professional
            You've likely found the limit of your GPU memory for your frame size. There's very specific math involved how much memory it takes to process frames at specific resolutions, but I can't remember how that works. If you're getting a red bar then it's probably falling back to CPU processing. What kind of GPU do you have, and how much VRAM does it have? As a test to confirm this, have you switch to CPU-processing to se if it also takes as long? You don't have to do the full test, probably just a fraction of time so it doesn't take 30 minutes.
            • 3. Re: Transform effect error
              The pic is very small 230*450.
              GTX 1060 6 GB.
              What kind of screenshot? Drag the pic to the timeline, drag transform effect on it. Change the scale in the transform effect to 307% - everything is fine. Hit 308% - it is red.
              It is definitely a PP bug.
