14 Replies Latest reply on May 31, 2018 11:52 AM by stefanocps
    reorganizing subtitle track
    stefanocps Level 1
      hello i have my movie , 36 minute long, with a subtitle track spletted in several part
      that s becuase after i finisged to subbing, i need to rearrange the clps, and the dfast way to keep the subtitle in sync was to create new pieces
      so now i have several pieces of it
      I planning to make a good restyling of mu movie, make it longer, 5.10 minutes longer, so i will need to move again all these parts, and it will get a difficult matter
      is there a way to organize the part to make them at least a unique one, or i don't know...other suggestion?
      I have realized that fromn this point of view subbing in premiere is bad, as it doesn't rearrange the sub when rearranging clips
      thanks a lot
        • 1. Re: reorganizing subtitle track
          Brandon Loshe Adobe Community Professional
          Hi stefanocps,
          Maybe a screenshot of your clips and the subtitle track(s) would illustrate your question more. Let me first ask for a little more clarification so that I better understand this. Are your subtitles all one imported clip from outside software? Or are you using Premiere Pro's built-in titles to function as subtitles?
          When you say "to organize the part to make them at least a unique one," what does that mean? I'm not clear one what you are referring to by "the part" and what you mean by "a unique one."
          While I await your response, I'll add a little information if by chance this answers your question. I apologize if I'm totally missing the mark here. 1.) You can use the Track Select Forward Tool to move all of your parts at once.
          2.) Or you can simply drag a selection box to highlight everything that you need to move all at once. 3.) Or you can right click on your sequence in your project bin, select "Duplicate," and then work in a duplicated sequence, where you can copy and paste the pieces from your original sequence to fit your longer one.
          I'm not sure if any of this is relevant to what you are trying to do, but I'll look forward to your response for additional information on your project.
          -Brandon Loshe
          • 2. Re: reorganizing subtitle track
            stefanocps Level 1
            the subtile track is the one surrounded by the red circle
            as you see there are several pieces
            and i would like to have  for order pourpouse all in the same unique track, and have if possible from it
            a correct list of
            minutes dialogues (may be exporting?)
            That said, i am going to extend some part of clips and i just feel unconfortable to move pieces and sometimes loosing the sync
            all the sub was made within premiere pro
            • 3. Re: reorganizing subtitle track
              Gotcha okay, I think I understand now. So if you move several clips around, you want to make sure that the subtitles stay with them, correct? Also, you want the freedom to extend any clip without losing sync. 2 options that come to mind:
              1.) Group multiple clips together: This would involve using the Razor Tool to your subtitle clip. You'll have to make the edit so that it aligns perfectly with your video edit. Then highlight all of the clips with the subtitle track, right click Group. This will lock all of the highlighted clips together so that they will not lose sync. This way you can trim them or extend any clip as need. And if you move a clip, then the whole group will move together. Later on, if you want them separate again, just right click ➡ Ungroup.
              2.) Nest multiple clips into a pre-composed sequence: This would also involve using the Razor Tool to your subtitle clip. Just like before, you'll have to make the edit so that it aligns perfectly with your video edit. Then highlight all of the clips with the subtitle track, and go to Clip Nest. This will put everything highlighted into another sequence. This will consolidate everything into another sequence with the same settings. In case you are wondering, even when you export with subtitles/close-captions in a nested sequence, they can still be exported as a sidecar file or burned into the video.
              I would do option #1, but maybe you'll find option #2 to work better for you.
              • 4. Re: reorganizing subtitle track
                stefanocps Level 1
                i group all the sub parts and in someway that makes me feel more confortable
                is there a way to have converted in a text list all of the sub?
                • 5. Re: reorganizing subtitle track
                  stefanocps Level 1
                  now if i want to  edit the sub i need to ungroup, well this is not a real problem
                  what is a problem and this is why i have all those small part fot the sub
                  is if i want to rearrange the clip
                  let's say i want to extend a clip (don t know in english, but the operation you do using the keyboarc command B tool)
                  1 i need to cut the sub part at the point where the clip end
                  2 i extend the clip
                  3 a blank space is created where i made the cut
                  Now if i want to add some sub for that portion, i need to create a new subtrack and put it where the blank space is
                  i find all this procedure quite complicated, not fluent
                  i don t know if i do wrong or if it is just a premiere pro limitation
                  • 6. Re: reorganizing subtitle track
                    You are right that it can get complicated quickly. Been there, done that. To be honest, I don't know how to create close-captions in Premiere from scratch the way you have it. I do all of my subtitles and close-captions outside of Premiere Pro in a Telestream app called MacCaption.
                    If you are going to be rearranging your clips drastically, then I would recommend finalizing your edit first. After your edit is done, then you can add the subtitles. It looks like you are trying to do it while editing. When I catch a mistake in my video or have to change the timing, I have to go back to MacCaption, export my subtitles/close-captions from MacCaption, import the subtitles/close-caption into Premiere Pro, and replace the track. In a perfect world, once your edit is finished, it's done for good; and then you just timestamp your subtitles to match the audio/video once.
                    • 7. Re: reorganizing subtitle track
                      It's been a couple days since I last responded. Just wanted to check in and see if you had luck getting this stuff figured out?
                      • 8. Re: reorganizing subtitle track
                        stefanocps Level 1
                        i am stopped now..wating to work at it
                        actually it is not that i do subtitle while editing.
                        it happens that sometimes i need to go adn reedit the movie, even if i thought was finished
                        for what i have seen there are not much things to do then work at it.no shortcut
                        only thing i would like to export as listed text the whole sub...and this is still somehting cant t do!
                        • 9. Re: reorganizing subtitle track
                          What do you mean by export as "listed text?" What does "listed text" mean?
                          • 10. Re: reorganizing subtitle track
                            stefanocps Level 1
                            i mean this
                            00 00 01    00 05 00  Hello what is your name
                            00 05 00    00 09 00  Hi my name is Paul
                            etc
                            • 11. Re: reorganizing subtitle track
                              Ok, gotcha. I don't know of a way to do it with Premiere Pro. If you export with a format that supports close-captions/subtitles, under the Captions tab in your export settings, you can set it to "Create Sidecar File." Select "Scenarist Closed Caption File (.scc) or "MacCaption VANC File (.mcc)." Then you can import either the .scc file or the .mcc file into software that can read .scc and .mcc files.
                              I think I'm onto something here. I just tested this on my own project, and got it to work using MacCaption. Just to confirm this for your case, are you able to export your video and then upload just the .scc file to this forum? Just for a quick export, you can just use the MPEG2-DVD format and uncheck "Export Video." Leave "Export Audio" checked because Premiere requires you to at least have one selected. Under the Captions tab, select "Create Sidecar File" as the export option and "Scenarist Closed Caption File (.scc)" as the file format. This will export audio and a .scc file, but all we care about at the moment is the .scc file.
                              If you are able to upload the .scc file, then I can see if it will open and convert to a list.
                              • 12. Re: reorganizing subtitle track
                                Any luck getting things figured out? I was thinking more about this today. You could open the captions panel and take screenshots of the list of close-captions/subtitles and their time stamps. I don't recall if there is a way to get the close-captions/subtitles out of there, though.
                                • 13. Re: reorganizing subtitle track
                                  In case you're still interested, I figured this out. I'll attach an example. With your caption selected in your Project Panel, go to File > Export > Captions... Select the XML Format. You can then open up that XML code in TextEdit or Microsoft Word. You can delete the extra code if you want. Just keep the timecode after "<p begin=" and the text after "<span>." I noticed that if your captions/subtitles are more than one line, then the timecode is listed again with the second line (see example below). I know this method isn't ideal either, but it'll work.
                                  Example:
                                  <p begin="00:00:01:12" end="00:00:03:25" region="pop1" style="basic" tts:origin="10% 74%">
                                          <style/>
                                          <span>ON BEHALF OF THE MINISTRY,
                                            <style tts:backgroundColor="#000000FF" tts:fontFamily="monospaceSansSerif" tts:fontSize="20px" tts:fontWeight="bold"/>
                                          </span>
                                        </p>
                                        <p begin="00:00:01:12" end="00:00:03:25" region="pop1" style="basic" tts:origin="10% 79.333333333333343%">
                                          <style/>
                                          <span>I WANT TO THANK YOU
                                          </span>
                                        </p>
                                        <p begin="00:00:01:12" end="00:00:03:25" region="pop1" style="basic" tts:origin="10% 84.666666666666671%">
                                          <style/>
                                          <span>FOR JOINING US IN WORSHIP.
                                  <p begin="00:00:03:26" end="00:00:06:13" region="pop1" style="basic" tts:origin="10% 10%">
                                          <style/>
                                          <span>WE HAVE BEEN PRIVILEDGED
                                          </span>
                                        </p>
                                        <p begin="00:00:03:26" end="00:00:06:13" region="pop1" style="basic" tts:origin="10% 15.333333333333332%">
                                          <style/>
                                          <span>TO SHARE GOD'S WORD WITH YOU
                                  FYI, yes, I know that PRIVILEGED is misspelled in my example lol.
                                  • 14. Re: reorganizing subtitle track
                                    stefanocps Level 1
                                    hello brandon
                                    thanks, yes i am interested, i will yty all these when i 'll have some time for it...busy in other duty these days!
