I need this manual to learn the script, but why can't I find the relevant script manual?
I want to learn to create a script that is about importing, creating a sequence, inserting an import file into a sequence, and adding preset effects to some of these commands. Those who want to know can tell me how to find these commands. . .
Thank you!
There is documentation here: Welcome to the Premiere Scripting Guide! — Premiere Pro Scripting Guide 1.0 documentation
This should give you the information to do everything you would like to do, except adding preset effects.
Thank you!Very Thank you!
I found a command to insert the video into the timeline: Track.overwriteClip, but there are some questions I would like to ask about.
If you know, hope to see my question below
I am a bit confused about the two parameters of this method, can you write an example?
The first parameter of this command is the video returned using the Premiere Item. Which method should be used?
The second parameter Time, I tried to directly fill in 0, but not, this is a variable of type Time or is it a time type such as "00:00" like this?
Thank you!My friend!
Working sample code: Samples/Premiere.jsx at master · Adobe-CEP/Samples · GitHub
