In FireFox 60.0 64 bit add-ons manager Shockwave Flash reports NPSWF64_29.0.0.113.dll and NPSWF64_29.0.0.171.dll I believe this causing Adobe to try and update Shockwave flash constantly and fail each time. If this is correct how do I remove NPSWF64_29.0.0.113.dll Window 10 version 1803 build 17134.38 64 bit FireFox 60.0 64 bit
Please go to about:plugins, locate the Shockwave Flash entries and post the path to both versions.
Also, provide the FlashInstall log files saved at the following locations:
Upload the files to cloud.acrobat.com/send (see instructions at How to share a file using Adobe Document Cloud ) or some other file sharing service that doesn't require user login to access. Post the links to the uploaded files in your reply.
Thank you.
Maria
As you requested
Shockwave Flash
File: NPSWF64_29_0_0_113.dll,NPSWF64_29_0_0_171.dll
Path: C:\WINDOWS\system32\Macromed\Flash\NPSWF64_29_0_0_113.dll,
C:\WINDOWS\system32\Macromed\Flash\NPSWF64_29_0_0_171.dll
Version: 29.0.0.113
State: Enabled
Shockwave Flash 29.0 r0
MIME Type | Description | Suffixes |
application/x-shockwave-flash | Adobe Flash movie | swf |
application/futuresplash | FutureSplash movie | spl |
017-6-13+20-9-41.222 [error] 1226 1062
2017-6-12+20-45-12.232 [error] 1223 1053
=O====== M/26.0.0.126 2017-06-13+20-09-13.051 ========
0000
0001 00000010 FlashPlayerInstaller.exe -install -iv 11
0002 00000011 1
0003
0004
0005
0006
0007
0008
0009 00000014
0010 00000025 C:\WINDOWS\SysWOW64\Macromed\Flash\FlashUtil32_26_0_0_126_Plugin.exe
0011 00000015 C:\WINDOWS\SysWOW64\Macromed\Flash\FlashUtil32_26_0_0_126_Plugin.exe
0012 00000016 C:\WINDOWS\SysWOW64\Macromed\Flash\FlashUtil32_26_0_0_126_Plugin.dll
0013 00000024 C:\WINDOWS\SysWOW64\Macromed\Flash\plugin.vch
0014 00000017 C:\WINDOWS\SysWOW64\Macromed\Flash
0015 00000022 C:\WINDOWS\SysWOW64\Macromed\Flash\FlashPlayerPlugin_26_0_0_126.exe
0016 00000021 C:\WINDOWS\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
0017
0018
0019
0020 00000012
=X====== M/26.0.0.126 2017-06-13+20-09-41.288 ========
2017-6-16+22-9-51.956 [error] 1226 1062
=O====== M/26.0.0.131 2017-06-16+22-09-25.103 ========
0000
0002 00000011 1
0003
0004
0005
0006
0007
0008
0009 00000014
0010 00000025 C:\WINDOWS\SysWOW64\Macromed\Flash\FlashUtil32_26_0_0_131_Plugin.exe
0011 00000015 C:\WINDOWS\SysWOW64\Macromed\Flash\FlashUtil32_26_0_0_131_Plugin.exe
0012 00000016 C:\WINDOWS\SysWOW64\Macromed\Flash\FlashUtil32_26_0_0_131_Plugin.dll
0015 00000022 C:\WINDOWS\SysWOW64\Macromed\Flash\FlashPlayerPlugin_26_0_0_131.exe
0017
0018
0019
0020 00000026
0021
0022 00000012
=X====== M/26.0.0.131 2017-06-16+22-09-52.150 ========
2017-6-24+5-27-12.305 [error] 1223 1053
2017-7-12+2-9-47.367 [error] 1226 1062
=O====== M/26.0.0.137 2017-07-12+02-09-22.782 ========
0000
0002 00000011 1
0003
0004
0005
0006
0007
0008
0009
0010 00000014
0011 00000025 C:\WINDOWS\SysWOW64\Macromed\Flash\FlashUtil32_26_0_0_137_Plugin.exe
0012 00000015 C:\WINDOWS\SysWOW64\Macromed\Flash\FlashUtil32_26_0_0_137_Plugin.exe
0013 00000016 C:\WINDOWS\SysWOW64\Macromed\Flash\FlashUtil32_26_0_0_137_Plugin.dll
0014 00000024 C:\WINDOWS\SysWOW64\Macromed\Flash\plugin.vch
0015 00000017 C:\WINDOWS\SysWOW64\Macromed\Flash
0016 00000022 C:\WINDOWS\SysWOW64\Macromed\Flash\FlashPlayerPlugin_26_0_0_137.exe
0017 00000021 C:\WINDOWS\SysWOW64\Macromed\Flash\FlashPlayerUpdateService.exe
0018
0019
0020
0021 00000026
0022
0023 00000012
=X====== M/26.0.0.137 2017-07-12+02-09-47.667 ========
O====== M/26.0.0.126 2017-06-13+20-09-25.966 ========
0000
0001 00000010 "C:\WINDOWS\system32\Macromed\Temp\{D438ADA1-9A23-45DD-8AE7-3BF41E669707}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012 00000014
0013 00000025 C:\WINDOWS\system32\Macromed\Flash\FlashUtil64_26_0_0_126_Plugin.exe
0014 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil64_26_0_0_126_Plugin.exe
0015 00000016 C:\WINDOWS\system32\Macromed\Flash\FlashUtil64_26_0_0_126_Plugin.dll
0016 00000024 C:\WINDOWS\system32\Macromed\Flash\plugin.vch
0017 00000012
=X====== M/26.0.0.126 2017-06-13+20-09-29.707 ========
=O====== M/26.0.0.131 2017-06-16+22-09-32.832 ========
0000
0001 00000010 "C:\WINDOWS\system32\Macromed\Temp\{2E3A14DA-1863-4A1C-A165-494B0F1C2D8A}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012 00000014
0013 00000025 C:\WINDOWS\system32\Macromed\Flash\FlashUtil64_26_0_0_131_Plugin.exe
0014 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil64_26_0_0_131_Plugin.exe
0015 00000016 C:\WINDOWS\system32\Macromed\Flash\FlashUtil64_26_0_0_131_Plugin.dll
0017 00000012
=X====== M/26.0.0.131 2017-06-16+22-09-39.117 ========
=O====== M/26.0.0.137 2017-07-12+02-09-31.192 ========
0000
0001 00000010 "C:\WINDOWS\system32\Macromed\Temp\{0E17CACF-89A3-4DE4-9819-5CDB562B5229}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013 00000014
0014 00000025 C:\WINDOWS\system32\Macromed\Flash\FlashUtil64_26_0_0_137_Plugin.exe
0015 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil64_26_0_0_137_Plugin.exe
0016 00000016 C:\WINDOWS\system32\Macromed\Flash\FlashUtil64_26_0_0_137_Plugin.dll
0017 00000024 C:\WINDOWS\system32\Macromed\Flash\plugin.vch
0018 00000012
=X====== M/26.0.0.137 2017-07-12+02-09-35.315 ========
=O====== M/26.0.0.151 2017-08-08+20-09-58.978 ========
0000
0001 00000010 "C:\WINDOWS\system32\Macromed\Temp\{DEDDD6E0-E3AC-4739-8456-DD9A3DAFE1DC}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013 00000014
0014 00000025 C:\WINDOWS\system32\Macromed\Flash\FlashUtil64_26_0_0_151_Plugin.exe
0015 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil64_26_0_0_151_Plugin.exe
0016 00000016 C:\WINDOWS\system32\Macromed\Flash\FlashUtil64_26_0_0_151_Plugin.dll
0018 00000012
=X====== M/26.0.0.151 2017-08-08+20-10-06.274 ========
=O====== M/27.0.0.130 2017-09-13+02-09-34.580 ========
0000
0001 00000010 "C:\WINDOWS\system32\Macromed\Temp\{40651BEA-4316-414B-BE5F-FB8D801A75DC}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013 00000014
0014 00000025 C:\WINDOWS\system32\Macromed\Flash\FlashUtil64_27_0_0_130_Plugin.exe
0015 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil64_27_0_0_130_Plugin.exe
0016 00000016 C:\WINDOWS\system32\Macromed\Flash\FlashUtil64_27_0_0_130_Plugin.dll
0018 00000012
=X====== M/27.0.0.130 2017-09-13+02-09-38.165 ========
=O====== M/27.0.0.159 2017-10-10+21-09-35.395 ========
0000
0001 00000010 "C:\WINDOWS\system32\Macromed\Temp\{D5505367-5F89-4117-8238-2549470B7BB6}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013 00000014
0014 00000025 C:\WINDOWS\system32\Macromed\Flash\FlashUtil64_27_0_0_159_Plugin.exe
0015 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil64_27_0_0_159_Plugin.exe
0016 00000016 C:\WINDOWS\system32\Macromed\Flash\FlashUtil64_27_0_0_159_Plugin.dll
0018 00000012
=X====== M/27.0.0.159 2017-10-10+21-09-40.524 ========
=O====== M/27.0.0.170 2017-10-17+02-09-31.282 ========
0000
0001 00000010 "C:\WINDOWS\system32\Macromed\Temp\{FBA33280-32D2-4AA8-A144-D5EFDC9858B5}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013 00000014
0014 00000025 C:\WINDOWS\system32\Macromed\Flash\FlashUtil64_27_0_0_170_Plugin.exe
0015 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil64_27_0_0_170_Plugin.exe
0016 00000016 C:\WINDOWS\system32\Macromed\Flash\FlashUtil64_27_0_0_170_Plugin.dll
0018 00000012
=X====== M/27.0.0.170 2017-10-17+02-09-39.972 ========
=O====== M/27.0.0.183 2017-10-25+10-09-26.913 ========
0000
0001 00000010 "C:\WINDOWS\system32\Macromed\Temp\{92C2D9FD-D47B-4D82-B626-F4BFEF1985E0}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013 00000014
0014 00000025 C:\WINDOWS\system32\Macromed\Flash\FlashUtil64_27_0_0_183_Plugin.exe
0015 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil64_27_0_0_183_Plugin.exe
0016 00000016 C:\WINDOWS\system32\Macromed\Flash\FlashUtil64_27_0_0_183_Plugin.dll
0018 00000012
=X====== M/27.0.0.183 2017-10-25+10-09-39.031 ========
=O====== M/27.0.0.187 2017-11-15+01-09-32.211 ========
0000
0001 00000010 "C:\WINDOWS\system32\Macromed\Temp\{53D4F7EB-489A-4B3A-95C0-344DEB2136D0}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013 00000014
0014 00000025 C:\WINDOWS\system32\Macromed\Flash\FlashUtil64_27_0_0_187_Plugin.exe
0015 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil64_27_0_0_187_Plugin.exe
0016 00000016 C:\WINDOWS\system32\Macromed\Flash\FlashUtil64_27_0_0_187_Plugin.dll
0018 00000012
=X====== M/27.0.0.187 2017-11-15+01-09-36.622 ========
=O====== M/28.0.0.126 2017-12-12+15-09-38.805 ========
0000
0001 00000010 "C:\WINDOWS\system32\Macromed\Temp\{AF8700E1-C74B-435C-9CA4-42874BCC3792}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013 00000014
0014 00000025 C:\WINDOWS\system32\Macromed\Flash\FlashUtil64_28_0_0_126_Plugin.exe
0015 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil64_28_0_0_126_Plugin.exe
0016 00000016 C:\WINDOWS\system32\Macromed\Flash\FlashUtil64_28_0_0_126_Plugin.dll
0018 00000012
=X====== M/28.0.0.126 2017-12-12+15-09-46.523 ========
=O====== M/28.0.0.137 2018-01-10+00-09-35.879 ========
0000
0001 00000010 "C:\WINDOWS\system32\Macromed\Temp\{51CCF4D8-E8D0-48D0-88BA-EB13D3C37DF6}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013
0014
0015 00000014
0016 00000025 C:\WINDOWS\system32\Macromed\Flash\FlashUtil64_28_0_0_137_Plugin.exe
0017 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil64_28_0_0_137_Plugin.exe
0018 00000016 C:\WINDOWS\system32\Macromed\Flash\FlashUtil64_28_0_0_137_Plugin.dll
0019 00000024 C:\WINDOWS\system32\Macromed\Flash\plugin.vch
0020 00000012
=X====== M/28.0.0.137 2018-01-10+00-09-43.946 ========
=O====== M/28.0.0.161 2018-02-06+20-42-35.057 ========
0000
0001 00000010 "C:\WINDOWS\system32\Macromed\Temp\{4B61980A-0658-4E80-918B-607414804C74}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013 00000014
0014 00000025 C:\WINDOWS\system32\Macromed\Flash\FlashUtil64_28_0_0_161_Plugin.exe
0015 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil64_28_0_0_161_Plugin.exe
0016 00000016 C:\WINDOWS\system32\Macromed\Flash\FlashUtil64_28_0_0_161_Plugin.dll
0018 00000012
=X====== M/28.0.0.161 2018-02-06+20-42-39.588 ========
=O====== M/29.0.0.113 2018-03-13+22-09-20.939 ========
0000
0001 00000010 "C:\WINDOWS\system32\Macromed\Temp\{4149273A-DD34-4525-BA80-569051B0A647}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 11 -au 4294967295
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013 00000014
0014 00000025 C:\WINDOWS\system32\Macromed\Flash\FlashUtil64_29_0_0_113_Plugin.exe
0015 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil64_29_0_0_113_Plugin.exe
0016 00000016 C:\WINDOWS\system32\Macromed\Flash\FlashUtil64_29_0_0_113_Plugin.dll
0018 00000012
=X====== M/29.0.0.113 2018-03-13+22-09-24.597 ========
=O====== M/29.0.0.171 2018-05-09+22-30-17.154 ========
0000
0001 00000010 "C:\WINDOWS\system32\Macromed\Temp\{ECBC7209-75F9-4A14-A076-28FB7A501D50}\InstallFlashPlayer.exe" -install -skipARPEntry -iv 1 -au 4294967295
0002
0003
0004
0005
0006
0007
0008
0009
0010
0011
0012
0013
0014
0015 00000014
0016 00000015 C:\WINDOWS\system32\Macromed\Flash\FlashUtil64_29_0_0_171_Plugin.exe
0017 00000016 C:\WINDOWS\system32\Macromed\Flash\FlashUtil64_29_0_0_171_Plugin.dll
0018 00000024 C:\WINDOWS\system32\Macromed\Flash\plugin.vch
=X====== M/29.0.0.171 2018-05-09+22-30-23.391 ========
Thank you. It looks like at least one of the version 29.0.0.113 files was unable to be deleted when Flash Player was upgraded to 29.0.0.171, resulting in Firefox showing both versions and loading the previous version. Please try the following:
If there are errors deleting files in step 6 or step 7, post a screenshot of the errors.
Followed all of the step, no NPSWF or PLUGIN found in syswow64\macromed\flash or system32\macromed\flash
downloaded and ran installer
the installer hangs on the Installation will begin shortly (gave it over an hour and a half)
Followed by ADOBE Flash Player could not be installed
checked both syswow64\macromed\flash or system32\macromed\flash no NPSWF or Plugin
Turned off Norton Security Suit and Malwarebytes and retried, same results
Is there a binary file I can download and install, bypassing the installer?
The offline installer is posted at the bottom of the Installation problems | Flash Player | Windows 7 and earlier page, in the 'Still having problems' section.
The online installer shouldn't hang that long. I'd like to review the online installer log files saved at C:\Users\<YourUserID>\AppData\Local\Temp\Adobe_ADMLogs. Please upload the 2 files to cloud.acrobat.com/send (see How to share a file using Adobe Document Cloud ) and post the link to the uploaded files in your reply. Please upload the files, instead of posting them in your reply. Thank you.
Maria
Thank you for providing the files. I don't see a clear error in them and will forward them to the team that handles the online installer.
Maria
