Hey everyone,
I'm not sure exactly what changed recently, but I've been having issues exporting an After Effects Composition through Media Encoder. I've used it for 20 projects with no issue until recently and I can't figure out what's happening.
The timecode is different every single time and always results in an Error Code: 1609629695. I've tried switching the render to software only and have uninstalled the graphics driver with DDU and reinstalled them, but nothing has worked. It seems to work if I restart the computer and immediately start the render shortly after. So it may be a cache thing. Here are the details.
- Encoding Time: 00:07:40
05/07/2018 11:55:01 AM : Encoding Failed
Export Error
Error compiling movie.
Render Error
Render returned error.
Writing with exporter: H.264
Writing to file: \\?\A:\FT-048-Deadpool2-PP_v1 Linked Comp 01_2.mp4
Writing file type: H264
Around timecode: 00;02;29;59 - 00;02;30;15
Rendering at offset: 150.000 seconds
Component: H.264 of type Exporter
Selector: 9
Error code: -1609629695
Computer Specs
Operating System
Windows 10 Pro 64-bit
CPU
Intel Core i7 6700K @ 4.00GHz
Skylake 14nm Technology
RAM
32.0GB Dual-Channel Unknown @ 1200MHz (16-16-16-39)
Motherboard
MSI Z170A GAMING M5 (MS-7977) (U3E1)
Graphics
BenQ EW3270U (3840x2160@60Hz)
ASUS VS239 (1920x1080@60Hz)
BenQ EW277HDR (1920x1080@60Hz)
4095MB NVIDIA GeForce GTX 970 (EVGA)
Storage
465GB Crucial_CT500MX200SSD1 (SSD)
2794GB Western Digital WDC WD30EFRX-68EUZN0 (SATA)
1863GB Western Digital WDC WD20EADS-00R6B0 (SATA)
489GB Crucial_CT525MX300SSD1 (SSD)
Hi jonn12375336,
Sorry for the trouble. Have you updated the GPU drivers to the latest version?
Just for a test, change the renderer in Media Encoder Queue panel & check the issue.
Vidya
In the last few weeks Media Encoder has started failing to render approximately every 6th video. I will often have 20 videos or more in a queue and as soon as one fails the following ones will too.
The other computer I use seems to have no issues with the same projects and processes.
I`ve tried updating the graphics drivers to no avail.
I'm one of several in my community with this problem, any help would be much appreciated!!
- Source File: C:\Users\SKYDIV~1\AppData\Local\Temp\ScenicAir Video Template 2016 Full HD 1080p - 1.prproj
- Output File: D:\Editing\2016\11. November\1.mp4
- Preset Used: Skydive 1080 50fps
- Video: 1920x1080 (1.0), 50 fps, Progressive, 00:07:45:20
- Audio: AAC, 320 kbps, 48 kHz, Stereo
- Bitrate: VBR, 1 pass, Target 5.00 Mbps, Max 8.00 Mbps
- Encoding Time: 00:00:25
11/23/2016 11:03:23 AM : Encoding Failed
The Operation was interrupted by user
- Source File: C:\Users\SKYDIV~1\AppData\Local\Temp\15.03.2017 - 1200_8.prproj
- Output File: D:\Editing\2017\03. March\15.03.2017\Export\Yaya Wang_1.mp4
- Video: 1920x1080 (1.0), 50 fps, Progressive, 00:06:06:19
- Encoding Time: 00:00:18
03/22/2017 09:38:03 AM : Encoding Failed
- Source File: C:\Users\SKYDIV~1\AppData\Local\Temp\21.03.2017 - 1200.prproj
- Output File: D:\Editing\2017\03. March\21.03.2017\Export\Wootak Oh.mp4
- Video: 1920x1080 (1.0), 50 fps, Progressive, 00:06:10:40
- Encoding Time: 00:00:05
03/22/2017 09:38:16 AM : Encoding Failed
- Source File: C:\Users\SKYDIV~1\AppData\Local\Temp\27.03.2017 - 1200_1.prproj
- Output File: D:\Editing\2017\03. March\27.03.2017\1200\Export\Thenuga Raveendran.mp4
- Video: 1920x1080 (1.0), 50 fps, Progressive, 00:07:29:42
- Encoding Time: 00:04:49
03/28/2017 11:13:12 AM : Encoding Failed
- Source File: C:\Users\SKYDIV~1\AppData\Local\Temp\11062017_1200_5.prproj
- Output File: D:\Editing\2017\06. June\11.06.2017\1200\EXPORT\Chao Wen.mp4
- Video: 1920x1080 (1.0), 50 fps, Progressive, 00:06:45:49
- Encoding Time: 00:08:50
06/12/2017 10:50:37 AM : Encoding Failed
- Source File: C:\Users\SKYDIV~1\AppData\Local\Temp\11062017_1200_11.prproj
- Output File: D:\Editing\2017\06. June\11.06.2017\1200\EXPORT\Natalie Freiburghaus.mp4
- Video: 1920x1080 (1.0), 50 fps, Progressive, 00:07:13:26
- Encoding Time: 00:00:37
06/12/2017 01:25:33 PM : Encoding Failed
- Source File: C:\Users\SKYDIV~1\AppData\Local\Temp\19.06.2017 - 1530_1.prproj
- Output File: D:\Editing\2017\06. June\19.06.2017\Export\Yi Yang.mp4
- Video: 1920x1080 (1.0), 50 fps, Progressive, 00:07:02:00
- Encoding Time: 00:04:25
06/20/2017 09:52:07 AM : Encoding Failed
- Source File: C:\Users\SKYDIV~1\AppData\Local\Temp\0830_20062017_12.prproj
- Output File: D:\Editing\2017\06. June\20.06.2017\0830\Export\Brian Bell.mp4
- Video: 1920x1080 (1.0), 50 fps, Progressive, 00:07:13:36
- Encoding Time: 00:17:02
06/21/2017 09:49:46 AM : Encoding Failed
- Source File: C:\Users\SKYDIV~1\AppData\Local\Temp\0830_20062017_11.prproj
- Output File: D:\Editing\2017\06. June\20.06.2017\0830\Export\Ryan Baumgartner_1.mp4
- Video: 1920x1080 (1.0), 50 fps, Progressive, 00:07:04:29
- Encoding Time: 00:00:07
06/21/2017 09:51:56 AM : Encoding Failed
- Source File: C:\Users\SKYDIV~1\AppData\Local\Temp\0000_05072017.prproj
- Output File: D:\Editing\2017\07. July\05.07\0000\Export\Seung Hyun Cha.mp4
- Video: 1920x1080 (1.0), 50 fps, Progressive, 00:05:20:32
- Encoding Time: 00:00:32
07/05/2017 08:39:46 PM : Encoding Failed
- Encoding Time: 00:03:05
07/15/2017 09:19:42 PM : Encoding Failed
Export Error
Frame Creation Error
Bad allocation while creating disk aligned video frame.
Writing to file: \\?\D:\Editing\2017\07. July\15.07\0830\Export\Mansour AlNuaimi.mp4
Around timecode: 00:02:41:11 - 00:02:41:12
Rendering at offset: 161.040 seconds
Selector: 9
Error code: -1610219517
- Source File: C:\Users\SKYDIV~1\AppData\Local\Temp\2108 - 1_1.prproj
- Output File: D:\Editing\2017\08. Aug\21.08\0830\Export\Elisabeth Jaroslawicz.mp4
- Video: 1920x1080 (1.0), 50 fps, Progressive, 00:05:38:30
- Encoding Time: 00:44:53
08/21/2017 06:32:48 PM : Encoding Failed
- Source File: C:\Users\SKYDIV~1\AppData\Local\Temp\13.10.2017 - heli.prproj
- Output File: D:\Editing\2017\10. Oktober\13.10\Export\Marina Lanz.mp4
- Video: 1920x1080 (1.0), 50 fps, Progressive, 00:07:25:16
- Encoding Time: 00:07:19
10/13/2017 03:35:08 PM : Encoding Failed
- Source File: C:\Users\SKYDIV~1\AppData\Local\Temp\21.10.2017 - 0830.prproj
- Output File: D:\Editing\2017\10. Oktober\21.10\0830\Export\André Wasmer.mp4
- Video: 1920x1080 (1.0), 50 fps, Progressive, 00:07:10:21
- Encoding Time: 00:07:14
10/21/2017 02:03:15 PM : Encoding Failed
- Source File: C:\Users\SKYDIV~1\AppData\Local\Temp\25.10.2017 - 1200_8.prproj
- Output File: D:\Editing\2017\10. Oktober\25.10\Export\Joseph Calleja.mp4
- Video: 1920x1080 (1.0), 50 fps, Progressive, 00:06:04:04
- Encoding Time: 00:00:36
10/25/2017 08:54:38 PM : Encoding Failed
- Source File: C:\Users\SKYDIV~1\AppData\Local\Temp\1200_301017_5.prproj
- Output File: D:\Editing\2017\10. Oktober\30.10\1200\Export\Seon Yeol Kim.mp4
- Video: 1920x1080 (1.0), 50 fps, Progressive, 00:06:40:18
- Encoding Time: 00:00:29
10/30/2017 05:58:12 PM : Encoding Failed
- Source File: C:\Users\SKYDIV~1\AppData\Local\Temp\0830_1200_19042018_10.prproj
- Output File: D:\Editing\2018\04. April\19.04\Export\Abhishek Shukla.mpeg
- Preset Used:
- Video: 1920x1080 (1.0), 50 fps, Progressive, Quality 50, 00:05:26:43
- Audio: 48000 Hz, Stereo, 16 bit
- Bitrate:
- Encoding Time: 00:09:39
04/19/2018 07:12:50 PM : Encoding Failed
- Source File: C:\Users\SKYDIV~1\AppData\Local\Temp\0830_1200_19042018_11.prproj
- Output File: D:\Editing\2018\04. April\19.04\Export\Abhishek Shukla.mp4
- Video: 1920x1080 (1.0), 50 fps, Progressive, 00:05:26:43
- Encoding Time: 00:01:47
04/19/2018 07:46:04 PM : Encoding Failed
- Source File: C:\Users\SKYDIV~1\AppData\Local\Temp\0800_18052018_8.prproj
- Output File: D:\Editing\2018\05. May\18.05\0800\Export\SeungJoo Kim.mp4
- Video: 1920x1080 (1.0), 50 fps, Progressive, 00:06:16:02
- Encoding Time: 00:17:26
05/18/2018 04:38:11 PM : Encoding Failed
- Source File: C:\Users\SKYDIV~1\AppData\Local\Temp\0800P1_21052018_2.prproj
- Output File: D:\Editing\2018\05. May\21.05\0800 PART1\Export\Nikita Malhotra.mp4
- Video: 1920x1080 (1.0), 50 fps, Progressive, 00:06:14:00
- Encoding Time: 00:07:06
05/21/2018 11:49:07 AM : Encoding Failed
- Source File: C:\Users\SKYDIV~1\AppData\Local\Temp\1200_09062018.prproj
- Output File: D:\Editing\2018\06. June\09.06\1200\Export\Alexia Romney.mp4
- Video: 1920x1080 (1.0), 50 fps, Progressive, 00:06:00:14
- Encoding Time: 00:07:17
06/09/2018 08:24:26 PM : Encoding Failed
- Encoding Time: 00:03:01
06/18/2018 11:36:03 AM : Encoding Failed
Export Error
Render Error
Writing to file: \\?\D:\Editing\2018\06. June\16.06\Export\Rrahman Shabani.mp4
Around timecode: 00:01:01:39 - 00:01:01:48
Rendering at offset: 61.780 seconds
Selector: 9
- Encoding Time: 00:01:05
06/18/2018 11:50:34 AM : Encoding Failed
Export Error
Render Error
Writing to file: \\?\D:\Editing\2018\06. June\16.06\Export\Marco Perdigao.mp4
Around timecode: 00:00:32:11 - 00:00:32:20
Rendering at offset: 32.220 seconds
Selector: 9
- Encoding Time: 00:01:09
06/18/2018 11:51:44 AM : Encoding Failed
Export Error
Render Error
Writing to file: \\?\D:\Editing\2018\06. June\16.06\Export\Rrahman Shabani_1.mp4
Around timecode: 00:00:35:30 - 00:00:35:39
Rendering at offset: 35.600 seconds
Selector: 9
- Encoding Time: 00:01:01
06/18/2018 01:41:10 PM : Encoding Failed
Export Error
Render Error
Around timecode: 00:00:29:04 - 00:00:29:13
Rendering at offset: 29.080 seconds
Selector: 9
- Encoding Time: 00:00:57
06/18/2018 01:42:08 PM : Encoding Failed
Export Error
Render Error
Around timecode: 00:00:29:05 - 00:00:29:14
Rendering at offset: 29.100 seconds
Selector: 9
- Encoding Time: 00:02:24
06/19/2018 04:16:52 PM : Encoding Failed
Export Error
Render Error
Writing to file: \\?\D:\Editing\2018\06. June\18.06\Export\John Sample.mp4
Around timecode: 00:01:30:49 - 00:01:31:03
Rendering at offset: 90.860 seconds
Selector: 9
- Encoding Time: 00:00:54
06/19/2018 05:19:16 PM : Encoding Failed
Export Error
Render Error
Writing to file: \\?\D:\Editing\2018\06. June\18.06\Export\John Sample_1.mp4
Around timecode: 00:00:30:05 - 00:00:30:14
Rendering at offset: 30.100 seconds
Selector: 9
- Encoding Time: 00:09:21
06/20/2018 07:15:59 PM : Encoding Failed
Export Error
Render Error
Writing to file: \\?\D:\Editing\2018\06. June\19.06\1200\Export\Jeehyun Kim.mp4
Around timecode: 00:05:36:36 - 00:05:36:45
Rendering at offset: 336.720 seconds
Selector: 9
- Encoding Time: 00:09:42
06/20/2018 07:25:45 PM : Encoding Failed
Export Error
Render Error
Writing to file: \\?\D:\Editing\2018\06. June\19.06\1200\Export\Jieui Park.mp4
Around timecode: 00:05:57:25 - 00:05:57:34
Rendering at offset: 357.500 seconds
Selector: 9
- Source File: C:\Users\SKYDIV~1\AppData\Local\Temp\1200_19062018_8.prproj
- Output File: D:\Editing\2018\06. June\19.06\1200\Export\Katy Allen.mp4
- Video: 1920x1080 (1.0), 50 fps, Progressive, Software Only, 00:06:28:14
- Encoding Time: 00:00:17
06/20/2018 07:26:03 PM : Encoding Failed
- Encoding Time: 00:09:50
06/20/2018 07:36:36 PM : Encoding Failed
Export Error
Render Error
Around timecode: 00:05:21:31 - 00:05:21:40
Rendering at offset: 321.620 seconds
Selector: 9
- Encoding Time: 00:08:41
06/22/2018 03:42:55 PM : Encoding Failed
Export Error
Render Error
Writing to file: \\?\D:\Editing\2018\06. June\20.06\Export\Joshua Callaway.mp4
Around timecode: 00:04:49:31 - 00:04:49:40
Rendering at offset: 289.620 seconds
Selector: 9
- Encoding Time: 00:06:07
06/22/2018 04:56:51 PM : Encoding Failed
Export Error
Render Error
Writing to file: \\?\D:\Editing\2018\06. June\20.06\Export\Priya Ramani.mp4
Around timecode: 00:04:52:23 - 00:04:52:32
Rendering at offset: 292.460 seconds
Selector: 9
- Source File: C:\Users\SKYDIV~1\AppData\Local\Temp\200618_14.prproj
- Output File: D:\Editing\2018\06. June\20.06\Export\Vishal Thakker.mp4
- Video: 1920x1080 (1.0), 50 fps, Progressive, Software Only, 00:06:11:35
- Encoding Time: 00:02:37
06/22/2018 04:59:30 PM : Encoding Failed
06/23/2018 04:12:56 PM : Encoding Failed
Export Error
Render Error
Writing to file: \\?\D:\Editing\2018\06. June\21.06\Export\Poonman Bhati.mp4
Around timecode: 00:05:17:37 - 00:05:17:46
Rendering at offset: 317.740 seconds
Selector: 9
- Encoding Time: 00:08:07
06/23/2018 04:21:04 PM : Encoding Failed
Export Error
Render Error
Writing to file: \\?\D:\Editing\2018\06. June\21.06\Export\Chris Gardner.mp4
Around timecode: 00:05:03:16 - 00:05:03:25
Rendering at offset: 303.320 seconds
Selector: 9
- Source File: C:\Users\SKYDIV~1\AppData\Local\Temp\210618_6.prproj
- Output File: D:\Editing\2018\06. June\21.06\Export\Mijin Seon.mp4
- Video: 1920x1080 (1.0), 50 fps, Progressive, Software Only, 00:05:52:45
- Encoding Time: 00:00:20
06/23/2018 04:21:24 PM : Encoding Failed
- Encoding Time: 00:08:02
06/23/2018 05:14:12 PM : Encoding Failed
Export Error
Render Error
Writing to file: \\?\D:\Editing\2018\06. June\21.06\Export\Shital Kohmaria.mp4
Around timecode: 00:05:03:03 - 00:05:03:11
Rendering at offset: 303.020 seconds
Selector: 9
- Encoding Time: 00:07:36
06/23/2018 07:33:55 PM : Encoding Failed
Export Error
Render Error
Writing to file: \\?\D:\Editing\2018\06. June\21.06\Export\Ho-Sung Jung.mp4
Around timecode: 00:05:27:14 - 00:05:27:23
Rendering at offset: 327.280 seconds
Selector: 9
- Encoding Time: 00:00:58
06/24/2018 03:25:41 PM : Encoding Failed
Export Error
Render Error
Writing to file: \\?\D:\Editing\2018\06. June\21.06\Export\Luke Gall.mp4
Selector: 9
- Encoding Time: 00:00:48
06/24/2018 03:43:08 PM : Encoding Failed
Export Error
Render Error
Writing to file: \\?\D:\Editing\2018\06. June\21.06\Export\Mina Beshir.mp4
Around timecode: 00:00:29:09 - 00:00:29:18
Rendering at offset: 29.180 seconds
Selector: 9
- Encoding Time: 00:01:24
06/24/2018 04:50:52 PM : Encoding Failed
Export Error
Render Error
Writing to file: \\?\D:\Editing\2018\06. June\23.06\Export\Tanja Klopfenstein.mp4
Around timecode: 00:00:36:13 - 00:00:36:25
Rendering at offset: 36.260 seconds
Selector: 9
- Encoding Time: 00:01:03
06/24/2018 04:51:56 PM : Encoding Failed
Export Error
Render Error
Writing to file: \\?\D:\Editing\2018\06. June\23.06\Export\Vlora Sopi.mp4
Around timecode: 00:00:29:10 - 00:00:29:19
Rendering at offset: 29.200 seconds
Selector: 9
- Encoding Time: 00:00:47
06/24/2018 04:56:14 PM : Encoding Failed
Export Error
Render Error
Writing to file: \\?\D:\Editing\2018\06. June\23.06\Export\Tanja Klopfenstein_1.mp4
Selector: 9
- Encoding Time: 00:00:45
06/24/2018 04:56:59 PM : Encoding Failed
Export Error
Render Error
Writing to file: \\?\D:\Editing\2018\06. June\23.06\Export\Vlora Sopi_1.mp4
Selector: 9
- Encoding Time: 00:03:26
06/24/2018 05:00:26 PM : Encoding Failed
Export Error
Render Error
Writing to file: \\?\D:\Editing\2018\06. June\23.06\Export\Will Dukes.mp4
Around timecode: 00:02:00:01 - 00:02:00:10
Rendering at offset: 120.020 seconds
Selector: 9
- Encoding Time: 00:02:18
06/26/2018 01:09:24 PM : Encoding Failed
Export Error
Render Error
Writing to file: \\?\D:\Editing\2018\06. June\25.06\HELI 330\Export\Katie Haas.mp4
Around timecode: 00:01:26:21 - 00:01:27:05
Rendering at offset: 86.840 seconds
Selector: 9
- Encoding Time: 00:17:07
06/26/2018 01:41:50 PM : Encoding Failed
Export Error
Render Error
Around timecode: 00:05:14:21 - 00:05:15:00
Rendering at offset: 314.560 seconds
Selector: 9
- Encoding Time: 00:02:30
06/26/2018 01:44:22 PM : Encoding Failed
Export Error
Render Error
Writing to file: \\?\D:\Editing\2018\06. June\25.06\HELI 330\Export\Kelly Alexiov.mp4
Around timecode: 00:02:07:12 - 00:02:07:21
Rendering at offset: 127.480 seconds
Selector: 9
- Source File: C:\Users\SKYDIV~1\AppData\Local\Temp\HELI_25062018_4.prproj
- Output File: D:\Editing\2018\Kelly Alexiov.mp4
- Preset Used: Skydive_2018_1080_29.97fps
- Video: 1920x1080 (1.0), 25 fps, Progressive, Software Only, 00:04:58:04
- Encoding Time: 00:38:32
06/26/2018 03:25:44 PM : Encoding Failed
- Source File: C:\Users\SKYDIV~1\AppData\Local\Temp\HELI_26062018_1.prproj
- Output File: D:\Editing\2018\06. June\25.06\HELI 330\Export\Claire Miller.mp4
- Video: 1920x1080 (1.0), 29.97 fps, Progressive, Software Only, 00;05;28;12
- Encoding Time: 00:04:03
06/27/2018 02:00:38 PM : Encoding Failed
- Encoding Time: 00:00:15
06/27/2018 02:05:58 PM : Encoding Failed
Export Error
Render Error
Writing to file: \\?\D:\Editing\2018\06. June\26.06\HELI 0330\Export\Claire Miller.mp4
Around timecode: 00;00;00;09
Rendering at offset: 0.000 seconds
Selector: 9
- Encoding Time: 00:09:10
06/28/2018 04:00:58 PM : Encoding Failed
Export Error
Render Error
Writing to file: \\?\D:\Editing\2018\06. June\27.06\Export\Bhavana Gidwani.mp4
Around timecode: 00;05;11;23 - 00;05;12;02
Rendering at offset: 311.745 seconds
Selector: 9
- Encoding Time: 00:06:14
06/28/2018 04:22:41 PM : Encoding Failed
Export Error
Render Error
Around timecode: 00;05;10;01
Rendering at offset: 309.442 seconds
Selector: 9
- Encoding Time: 00:08:22
06/30/2018 04:02:26 PM : Encoding Failed
Export Error
Render Error
Writing to file: \\?\D:\Editing\2018\06. June\29.06\0800\Export\Matthew Arblaster.mp4
Around timecode: 00:05:11:04 - 00:05:11:13
Rendering at offset: 311.080 seconds
Selector: 9
- Encoding Time: 00:01:56
06/30/2018 04:56:12 PM : Encoding Failed
Export Error
Render Error
Writing to file: \\?\D:\Editing\2018\06. June\29.06\0800\Export\Wai Yi Sin.mp4
Around timecode: 00:01:06:39 - 00:01:06:46
Rendering at offset: 66.640 seconds
Selector: 9
Did you fix the issue? I have been having this issue for a few months too, but I think I figured it out. What the problem was is with AE's, PR's and AME's latest updates breaking GPU accelerated rendering for certain older cards. For instance, I have an EVGA GTX 950 SC, and what I noticed in the logs was very peculiar. I noticed that renders were returning errors and frames weren't being rendered. What I decided to try was to go into my AE project (works for Premiere Pro too) and go to my project settings and set it to software only opposed to Cuda accelerated. Then I brought the project over to AME and did the same by changing it to software only also. Then I rendered that same project and voila! Problem solved!! I have had this issue for months and it had set me back so far, but finally. The renders might take a little bit longer, but at least they will render. I really hope Adobe jumps on this problem since it is pretty widespread.
This just did the trick for me too - thank you so much for sharing!
