I need the DLL files I mentioned below should be x32 would you please make them a package and send it to me? Please all "x32" not x64 or x86..
My error;
Why? If they are missing, uninstall and reinstall Creative Cloud.
So many times I did it anyway but every time I gave this error I wanted to ask you also the Visual C++ VB. Programs that I wrote in case they all installed up to the smallest detail and running the DLL files x64 I need the x32 ones but I install it that way No choice. My problem will be solved if I can get it.
Dave is right. Much easier to uninstall and reinstall. Also, you really don't want to ask strangers for .DLL files. Good way to catch a bug.
Regardless.....AE is a x64 bit application. Unless you're using a much older version there is no 32bit (x86 is 32bit) There's no such thing as x32...at least not on Windows
My computer is a little different I just need the x32 ones of the DLL files I mentioned I found a few of them x86, but it didn't work. My computer worked a little differently when I found the mirrors in x32 I'm sure if you throw it in RAR, my problem will be solved.
When Gutterfish​ said that there is no such thing as x32...what do you expect from us?
I need the DLL files I mentioned, just put it in the RAR file and send it to me.
Wait...what do you need? Tell us one more time.
But, as has been said, what you are asking for doesn't sound like something that exists in the real world.
Uninstall.
Run the Adobe CC Cleaner Tool.
Reinstall.
Everything should be fine.
I tried, and it didn't solve my problem.
You know, you may not be able to run After Effects.
You never told us anything about your computer hardware or your operating system.
It's all a moot point. Even if anyone here had the "x32" versions of all those dlls, they are Adobe's intellectual property and they are not allowed to be shared. This person needs to contact Adobe tech support but I have an itch on the end of my nose that tells me they'll never do that.
