4 Replies Latest reply on May 26, 2018 6:24 AM by Antony Mooe
    Auto data merge all csv files in folder
    Antony Mooe Level 1
      Hello,
      I have a folder with 10 csv files and an Indesign template file.
      I need to:
      1. open Indesign template file
      2. get all csv files in folder to indesign
      3. merge and record all csv
      4. save indesign files with the cvs names
      Is that possible to do?
      Thank you Guys!
        • 1. Re: Auto data merge all csv files in folder
          davidc19923048 Level 1
          I think so:
          var file = new File(templateFolder + "template.indt");
          app.open(file);
          for (var i = 0; i < 10; i++) {
               csvName = "csv"+i+".csv";
               csvFile = new File(csvPath + csvName);
          I didn't understand this
          app.activeDocument.save(csvName);
          • 2. Re: Auto data merge all csv files in folder
            Antony Mooe Level 1
            Hello davidc19923048,
            I'm sorry, but the script it's not working.
            I get the error: "templateFolder is undefined"
            In the step 3 you didn't understood, I need to create merged documents.
            Thank you very much!
            • 3. Re: Auto data merge all csv files in folder
              Hi Antony,
              you have to understand that you posted in the Adobe InDesign Scripting Forum where ( mostly ) scripters hang around.
              A snippet like the one by David is showing you just the way to write your own code or is just showing a principle of coding. It seldomly is meant to be a full script that is working in every case, in every occassion on data David cannot see into.
              About the error message: Of course it says "templateFolder is undefined.".
              It's your job to define the variable templateFolder so that it is a valid folder path to your data.
              David obviously cannot know where your data is.
              Regards,
              Uwe
              • 4. Re: Auto data merge all csv files in folder
                Antony Mooe Level 1
                Thank you Guys for your reply!
                I'm a scripter beginner, but in the past few weeks i've been struggling to get the code right.
                I came out with this code witch It does almost what I need:
                2. get the data source file "Example_01.txt" from the folder "_txt" to indesign
                3. merge data
                4. save an indesign file with the name "File9.indd"
                main ()
                function main () {
                    // create a path for the template files
                    var Templates = File("~/Desktop/_templates/Template_01.indt");
                    // open the template
                    app.open(Templates);
                    // create a path for a Indesign file
                    var dataSource = Folder ("~/Desktop/_txt/Example_01.txt");
                    // merge and record data
                    app.activeDocument.dataMergeProperties.selectDataSource(dataSource);
                    app.activeDocument.dataMergeProperties.mergeRecords();
                    // create a path for the new indesign file
                    var folderOut = Folder ("~/Desktop/_folderOut/");
                    inddName = "File"+i+".indd";
                    inddFile = Folder (folderOut + new File (inddName));  }
                    //save the file
                    app.activeDocument.save(inddFile);
                    //close the file
                    app.activeDocument.close();
                But what I really need is:
                1. open Indesign template file - OK
                2. get all "txt" files  from the folder "_txt" to indesign (I've got 15 "txt" files)
                3. merge data - OK
                4. save individual indesign files with the original names of each "txt" files
                Can anyone help me?
                Best regards,
