• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Text to footnote in InDesign
Explorer ,
May 14, 2018 May 14, 2018
I have been trying run a script that helps in automatically converting and placing text to footnotes in an InDesign document. Script:
var scriptName = "Convert text to footnote",
doc, story;
app.doScript(PreCheck, ScriptLanguage.JAVASCRIPT, undefined, UndoModes.ENTIRE_SCRIPT, "\"" + scriptName + "\" script");
//===================================== FUNCTIONS ======================================
function Main() {
var mEndNotes = doc.textFrames.add( {name:"EndNotes"} ),
k, len, cIP, currPara, currFoot, mMarkers;
app.findGrepPreferences = app.changeGrepPreferences = null;
// edit doc.footnoteOption here
with (doc.footnoteOptions)
showPrefixSuffix = FootnotePrefixSuffix.PREFIX_SUFFIX_BOTH;
prefix = "[";
suffix = "]";
separatorText = "\t";
markerPositioning = FootnoteMarkerPositioning.NORMAL_MARKER;
// move endnotes to a separate textFrame
for (k=story.paragraphs.length - 1; k >=0; k--)
if (story.paragraphs.contents.search(/^\[\d+\]/) == 0)
currPara = story.paragraphs.move(LocationOptions.AT_BEGINNING, mEndNotes.parentStory);
currPara.words[0].remove();
// create footnote markers
app.findGrepPreferences.findWhat = "\\[\\d+\\]";
mMarkers = story.findGrep();
len = mMarkers.length;
while (len-->0) {
cIP = mMarkers[len].insertionPoints[0].index;
mMarkers[len].remove();
story.footnotes.add( LocationOptions.AFTER, story.insertionPoints[cIP] );
// fill footnote contents with proper text
for (k=0; k < story.footnotes.length; k++) {
currFoot = story.footnotes
mEndNotes.paragraphs[0].texts[0].move(LocationOptions.AT_END, currFoot.texts[0]);
if (story.footnotes.characters[-1].contents == "\r") story.footnotes.characters[-1].remove();
mEndNotes.remove();
function PreCheck() {
if (app.documents.length == 0) ErrorExit("Please open a document and try again.", true);
doc = app.activeDocument;
if (doc.converted) ErrorExit("The current document has been modified by being converted from older version of InDesign. Please save the document and try again.", true);
if (!doc.saved) ErrorExit("The current document has not been saved since it was created. Please save the document and try again.", true);
if (app.selection.length == 0) {
ErrorExit("Nothing is selected.", true);
else if (app.selection.length == 1) {
if (app.selection[0].constructor.name == "TextFrame" || app.selection[0].hasOwnProperty("baseline")) {
story = app.selection[0].parentStory;
else {
ErrorExit("Please select one text frame, or some text, or place the cursor and try again.", true);
else if (app.selection.length > 1) {
ErrorExit("Only one text frame or some text should be selected, or the cursor placed into the text.", true);
Main();
function ErrorExit(error, icon) {
alert(error, scriptName, icon);
exit();
Whenever I try to run this script in a document containing the following styling and text:
It generates the following error:
In all my documents, footnote text is marked in the same way and the text is usually at the end of the document. Though, the script worked for one of the documents however, it did not work for all others.
Could anyone help me with the idea of actually what is going wrong with the script? I have faced this problem in more than one file and have no idea about scripting.
Any help would be much appreciated.
Thanks and Regards,
Aman mittal
[This post moved from InDesign forum to InDesign Scripting forum by Moderator]
TOPICS
Scripting
Views
1.0K
Translate
Translate
Report
Report
Community guidelines
community guidelines
People's Champ , May 15, 2018 May 15, 2018
First thing to do, when you're debugging, is to change the doScript in line 5 to a simple function call. In your case, change line 5 to
PreCheck();
That way, when you're shown an error message, it will say on what line the error message is and give specific details. With doScript, you only get the unhelpful message that is shown now.
So do that and post back.
Looking quickly at the script, though, it seems to copy out certain types of paragraphs, but it also seems to assume that each paragraph it co
Votes
Translate
Translate
People's Champ ,
LATEST
PreCheck();
Looking quickly at the script, though, it seems to copy out certain types of paragraphs, but it also seems to assume that each paragraph it copies ends with a paragraph return. This might not always be the case, if the para is at the end of story.
So when you later loop through all (newly created) footnotes, you're assuming you'll find that many paragraphs, and it could be you won't.
Ariel
Votes
Translate
Translate
Report
Report
