4 Replies Latest reply on May 17, 2018 12:24 AM by anj8488
    AEM6.3 - Issue with a pathfield in a multifield dialog
    elizabethp60981482
      I am using the pathfield from granite/ui/components/coral/foundation/form/pathfield in many places of our website and I never had a problem.
      Now, I am trying to use it on a multifield, and happens that if I select a path the value is stored but its not retrieved when I open the dialog again.
      Does anyone knows some workaround to correct this?
      Below are my dialog. Thanks in advance!
      <?xml version="1.0" encoding="UTF-8"?>
      <jcr:root xmlns:sling="http://sling.apache.org/jcr/sling/1.0" xmlns:cq="http://www.day.com/jcr/cq/1.0" xmlns:jcr="http://www.jcp.org/jcr/1.0" xmlns:nt="http://www.jcp.org/jcr/nt/1.0"
          jcr:primaryType="nt:unstructured"
          jcr:title="Carousel Component"
          sling:resourceType="cq/gui/components/authoring/dialog">
          <content
              sling:resourceType="granite/ui/components/foundation/container">
              <layout
                  sling:resourceType="granite/ui/components/foundation/layouts/tabs"
                  type="nav"/>
              <items jcr:primaryType="nt:unstructured">
                  <carousel-component
                      jcr:title="Example"
                      sling:resourceType="granite/ui/components/foundation/section">
                      <layout
                          sling:resourceType="granite/ui/components/foundation/layouts/fixedcolumns"
                          margin="{Boolean}false"/>
                          <column
                                  <item
                                      sling:resourceType="granite/ui/components/foundation/form/multifield"
                                      class="foundation-layout-util-maximized-alt long-label"
                                      fieldLabel="Item Carousel component">
                                      <field
                                          sling:resourceType="granite/ui/components/foundation/form/fieldset"
                                          acs-commons-nested=""
                                          name="./carousel">
                                          <layout
                                              method="absolute"/>
                                              <column
                                                      <itemPath
                                                          sling:resourceType="granite/ui/components/coral/foundation/form/pathfield"
                                                          fieldLabel="Image"
                                                          name="./itemPath"
                                                          rootPath="/content/dam/latam-portal-agencias/img"/>
                                                      <itemText
                                                          sling:resourceType="granite/ui/components/foundation/form/textfield"
                                                          fieldLabel="Link"
                                                          name="./itemLink"/>
                                                  </items>
                                              </column>
                                          </items>
                                      </field>
                                  </item>
                              </items>
                          </column>
                      </items>
                  </carousel-component>
              </items>
          </content>
      </jcr:root>
