So i'm trying to make an capture alien game where you will need to use your arrow keys to control a cage to capture the alien. Here is my uncompleted codes
import flash.events.Event;
stop();
lunar_txt.text="Please capture the alien using Up,Down,Left,Right arrow keys!";
var capture:Boolean=false;
var randomX:Number = Math.random() * stage.stageWidth
var randomY:Number = Math.random() * stage.stageHeight
/*alien_mc.addEventListener(Event.ENTER_FRAME, checkcapture)
function checkcapture(event:Event):void
while(capture==false)
alien_mc.x= randomX;
alien_mc.y= randomY;
var upPressed:Boolean = false;
var downPressed:Boolean = false;
var leftPressed:Boolean = false;
var rightPressed:Boolean = false;
stage.addEventListener(Event.ENTER_FRAME, keydirection);
stage.addEventListener(KeyboardEvent.KEY_DOWN, keycontrols);
stage.addEventListener(KeyboardEvent.KEY_UP, keyboard);
function keydirection(event:Event)
if (upPressed)
cage_mc.y -= 10;
if (downPressed)
cage_mc.y += 10;
if (leftPressed)
cage_mc.x -= 10;
if (rightPressed)
cage_mc.x += 10;
function keycontrols(event:KeyboardEvent):void
switch (event.keyCode)
case Keyboard.UP:
upPressed = true;
break;
case Keyboard.DOWN:
downPressed = true;
break;
case Keyboard.LEFT:
leftPressed = true;
break;
case Keyboard.RIGHT:
rightPressed = true;
break;
function keyboard(event:KeyboardEvent):void
case Keyboard.UP:
upPressed = false;
break;
case Keyboard.DOWN:
downPressed = false;
break;
case Keyboard.LEFT:
leftPressed = false;
break;
rightPressed = false;
break;
alien_mc.addEventListener(Event.ENTER_FRAME, checkinstage)
function checkinstage(event:Event):void
if(alien_mc.y > stage.stageHeight)
else if(alien_mc.x > stage.stageWidth)
Using while loop for looping the alien to random co-ordinates when it isn't captured gives me this error
"Error: Error #1502: A script has executed for longer than the default timeout period of 15 seconds.
at MainTimeline/checkcapture()"
On the other hand, using do while loop completely crashes my program.
So which loop should i be using in my case? & is my codes wrong? Also, how do i add a delay to the loop? Let's say i want it to change alien position every 2 seconds?
2nd question, is there something wrong with my function checkinstage codes? After adding those codes my alien is still appearing out of the stage
i don't download and correct files unless i'm hired. free help i only give via the forums.
someone else may download it though.
change the 'while' to 'if' in checkcapture and then define your capture boolean
Didn't work ;( after i change it to if, i'm getting more errors from the other scenes, I did declare my capture as a boolean > var capture:Boolean=false;
well, it actually did work. the fact that you have other errors wasn't caused by correcting that error.
it's going to be difficult to correct your code when only part of it's shown. and if there's a lot more code it's too much to correct in a forum.
what code did you have. prior to adding your checkcapture function, that worked without error?
Actually, the code does work now without showing any error but it didn't loop, it only changes location when i re preview the animation, i want it to keep on looping every 2 seconds within the same animation, here's the file link for you to take a look hello.fla - Google Drive
if you could help me to fix other errors like the netstream, that would be awesome, also, my alien is still appearing outside of my stage ;(
Located at game 2 btw appreciate your effort in helping me
That's the only answer i needed, Thanks for at least taking your time to reply & assist me, i've changed my game plan and ditch this since i couldn't solve it.
you're welcome.
