17 Replies Latest reply on May 16, 2018 10:47 AM by davescm
    Puppet warp greyed out
    mirkof14400848 Level 1
      I didn't manage to try puppet warp because since the release it's been greyed out.
      premise: I use photoshop to work, so skip the part of tips like "unlock the level" or "select before transforming". Take for granted that puppet warp does not work because of some software problem.
      I tried everything, update drivers, update software, smart objects etc.: simply no way.
      The GPU acceleration is ON atm, but even if i switch it off, it won't change a thing.
        • 1. Re: Puppet warp greyed out
          c.pfaffenbichler Level 9
          You have provided insufficient data to verify your claim.
          What are the image’s Color Mode and bit depth?
          Could you please post a screenshot with the pertinent Panels (Layers, Channels, Options Bar, …) and dialog visible?
          • 2. Re: Puppet warp greyed out
            Color Mode RGB. I tried every bit depth, it doesn't work for 8-16-32.
            What you need in the Layer and channels panels?
            • 3. Re: Puppet warp greyed out
              norman.sanders Adobe Community Professional & MVP
              Are you saying Puppet Warp is not available after putting the selected area on a transparent layer?
              • 4. Re: Puppet warp greyed out
                Could you please post a screenshot with the pertinent Panels (Layers, Channels, Options Bar, …) and the menu visible?
                • 5. Re: Puppet warp greyed out
                  What you mean with that? Sorry for asking, English is not my primary language, so maybe I don't understand what you're asking.
                  • 6. Re: Puppet warp greyed out
                    Yes, transparent layer, and no Puppet Warp available. I think it's something related to GPU acceleration as well as the AIF error during Liquify.
                    It seems to me like PS is not using my GPU even when I select the option in the Edit>Preferences window, and I don't know why, or how to fix it...
                    • 7. Re: Puppet warp greyed out
                      Just to make sure: Have you deselected (cmd-D) yet?
                      • 8. Re: Puppet warp greyed out
                        I tried with both selected and not-selected item. No way unfortunately
                        • 9. Re: Puppet warp greyed out
                          I meant that menu:
                          Have you tried the various settings under Photoshop CC > Preferences > Performance > Graphics Processor Settings > Advanced Settings (while restarting Photoshop after each change)?
                          • 10. Re: Puppet warp greyed out
                            Sorry, »selected« is a bit ambiguous here: One Layer needs to be selected, but no Selection should be active (Select > Deselect).
                            • 11. Re: Puppet warp greyed out
                              davescm Adobe Community Professional
                              Hi
                              Can you go to Photoshop Help >System Info and click on the "copy" button . Then paste the info here. It may help us see what is preventing the GPU functions on your set up.
                              Dave
                              • 12. Re: Puppet warp greyed out
                                Yeah I mean I tried with and without an active selection on an active layer.
                                • 13. Re: Puppet warp greyed out
                                  Have you tried the various »Drawing Mode« settings under Photoshop CC > Preferences > Performance > Graphics Processor Settings > Advanced Settings (while restarting Photoshop after each change)?
                                  • 14. Re: Puppet warp greyed out
                                    Here Dave!
                                    And thanks.
                                    P.S: Not only Puppet Warp, Liquify doesn't work too, even 3D functions don't work as well, because some OpenGL document error if I remember well.
                                    Adobe Photoshop Version: 19.1.4 20180507.r.325 2018/05/07: 1170750  x64
                                    Number of Launches: 57
                                    Operating System: Windows 10 64-bit
                                    Version: 10 or greater 10.0.16299.431
                                    System architecture: Intel CPU Family:6, Model:12, Stepping:3 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2, AVX, AVX2
                                    Physical processor count: 4
                                    Processor speed: 3500 MHz
                                    Built-in memory: 32653 MB
                                    Free memory: 17414 MB
                                    Memory available to Photoshop: 29366 MB
                                    Memory used by Photoshop: 70 %
                                    Alias Layers: Disabled.
                                    Modifier Palette: Enabled.
                                    Highbeam: Enabled.
                                    Image tile size: 1024K
                                    Image cache levels: 4
                                    Font Preview: Medium
                                    TextComposer: Latin
                                    Display: 1
                                    Display Bounds: top=0, left=0, bottom=1080, right=1920
                                    Display: 2
                                    Display Bounds: top=0, left=-2560, bottom=1440, right=0
                                    OpenGL Drawing: Disabled.
                                    OpenGL Allow Old GPUs: Not Detected.
                                    AIFCoreInitialized=1
                                    AIFOGLInitialized=1
                                    OGLContextCreated=1
                                    NumGLGPUs=2
                                    NumCLGPUs=2
                                    NumNativeGPUs=0
                                    glgpu[0].GLVersion="4.1"
                                    glgpu[0].IsIntegratedGLGPU=0
                                    glgpu[0].GLMemoryMB=4096
                                    glgpu[0].GLName="NVIDIA GeForce GTX 970"
                                    glgpu[0].GLVendor="NVIDIA Corporation"
                                    glgpu[0].GLVendorID=4318
                                    glgpu[0].GLDriverVersion="24.21.13.9731"
                                    glgpu[0].GLRectTextureSize=16384
                                    glgpu[0].GLRenderer="GeForce GTX 970/PCIe/SSE2"
                                    glgpu[0].GLRendererID=5058
                                    glgpu[0].HasGLNPOTSupport=1
                                    glgpu[0].GLDriver="C:\WINDOWS\System32\DriverStore\FileRepository\nv_desktop_ref4i.inf_amd 64_5e0f3147a308ab3d\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileRepository\nv_desktop _ref4i.inf_amd64_5e0f3147a308ab3d\nvldumdx.dll,C:\WINDOWS\System32\DriverStore\FileReposit ory\nv_desktop_ref4i.inf_amd64_5e0f3147a308ab3d\nvldumdx.dll,C:\WINDOWS\System32\DriverSto re\FileRepository\nv_desktop_ref4i.inf_amd64_5e0f3147a308ab3d\nvldumdx.dll"
                                    glgpu[0].GLDriverDate="20180422000000.000000-000"
                                    glgpu[0].CanCompileProgramGLSL=1
                                    glgpu[0].GLFrameBufferOK=1
                                    glgpu[0].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.60 NVIDIA"
                                    glgpu[0].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[6553 6]
                                    glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[4]
                                    glgpu[0].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
                                    glgpu[0].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
                                    glgpu[0].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
                                    glgpu[0].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
                                    glgpu[0].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
                                    glgpu[0].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
                                    glgpu[0].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
                                    glgpu[0].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
                                    glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
                                    glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
                                    glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
                                    glgpu[0].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
                                    glgpu[0].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
                                    glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
                                    glgpu[0].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
                                    glgpu[0].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
                                    glgpu[0].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
                                    glgpu[0].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
                                    clgpu[0].CLPlatformVersion="1.2 "
                                    clgpu[0].CLDeviceVersion="1.2 "
                                    clgpu[0].IsIntegratedCLGPU=1
                                    clgpu[0].CLMemoryMB=1629
                                    clgpu[0].CLName="Intel(R) HD Graphics 4600"
                                    clgpu[0].CLVendor="Intel(R) Corporation"
                                    clgpu[0].CLVendorID=32902
                                    clgpu[0].CLDriverVersion="20.19.15.4835"
                                    clgpu[0].CLBandwidth=1.47498e+10
                                    clgpu[0].CLCompute=183.494
                                    glgpu[1].GLVersion="4.1"
                                    glgpu[1].IsIntegratedGLGPU=1
                                    glgpu[1].GLMemoryMB=2048
                                    glgpu[1].GLName="Intel(R) HD Graphics 4600"
                                    glgpu[1].GLVendor="NVIDIA Corporation"
                                    glgpu[1].GLVendorID=32902
                                    glgpu[1].GLDriverVersion="20.19.15.4835"
                                    glgpu[1].GLRectTextureSize=16384
                                    glgpu[1].GLRenderer="GeForce GTX 970/PCIe/SSE2"
                                    glgpu[1].GLRendererID=1042
                                    glgpu[1].HasGLNPOTSupport=1
                                    glgpu[1].GLDriver="igdumdim64.dll,igd10iumd64.dll,igd10iumd64.dll,igd12umd64.dll"
                                    glgpu[1].GLDriverDate="20171016000000.000000-000"
                                    glgpu[1].CanCompileProgramGLSL=1
                                    glgpu[1].GLFrameBufferOK=1
                                    glgpu[1].glGetString[GL_SHADING_LANGUAGE_VERSION]="4.60 NVIDIA"
                                    glgpu[1].glGetProgramivARB[GL_FRAGMENT_PROGRAM_ARB][GL_MAX_PROGRAM_INSTRUCTIONS_ARB]=[6553 6]
                                    glgpu[1].glGetIntegerv[GL_MAX_TEXTURE_UNITS]=[4]
                                    glgpu[1].glGetIntegerv[GL_MAX_COMBINED_TEXTURE_IMAGE_UNITS]=[192]
                                    glgpu[1].glGetIntegerv[GL_MAX_VERTEX_TEXTURE_IMAGE_UNITS]=[32]
                                    glgpu[1].glGetIntegerv[GL_MAX_TEXTURE_IMAGE_UNITS]=[32]
                                    glgpu[1].glGetIntegerv[GL_MAX_DRAW_BUFFERS]=[8]
                                    glgpu[1].glGetIntegerv[GL_MAX_VERTEX_UNIFORM_COMPONENTS]=[4096]
                                    glgpu[1].glGetIntegerv[GL_MAX_FRAGMENT_UNIFORM_COMPONENTS]=[4096]
                                    glgpu[1].glGetIntegerv[GL_MAX_VARYING_FLOATS]=[124]
                                    glgpu[1].glGetIntegerv[GL_MAX_VERTEX_ATTRIBS]=[16]
                                    glgpu[1].extension[AIF::OGL::GL_ARB_VERTEX_PROGRAM]=1
                                    glgpu[1].extension[AIF::OGL::GL_ARB_FRAGMENT_PROGRAM]=1
                                    glgpu[1].extension[AIF::OGL::GL_ARB_VERTEX_SHADER]=1
                                    glgpu[1].extension[AIF::OGL::GL_ARB_FRAGMENT_SHADER]=1
                                    glgpu[1].extension[AIF::OGL::GL_EXT_FRAMEBUFFER_OBJECT]=1
                                    glgpu[1].extension[AIF::OGL::GL_ARB_TEXTURE_RECTANGLE]=1
                                    glgpu[1].extension[AIF::OGL::GL_ARB_TEXTURE_FLOAT]=1
                                    glgpu[1].extension[AIF::OGL::GL_ARB_OCCLUSION_QUERY]=1
                                    glgpu[1].extension[AIF::OGL::GL_ARB_VERTEX_BUFFER_OBJECT]=1
                                    glgpu[1].extension[AIF::OGL::GL_ARB_SHADER_TEXTURE_LOD]=1
                                    clgpu[1].CLPlatformVersion="1.2"
                                    clgpu[1].CLDeviceVersion="1.2 CUDA"
                                    clgpu[1].IsIntegratedCLGPU=0
                                    clgpu[1].CLMemoryMB=4096
                                    clgpu[1].CLName="GeForce GTX 970"
                                    clgpu[1].CLVendor="NVIDIA Corporation"
                                    clgpu[1].CLVendorID=4318
                                    clgpu[1].CLDriverVersion="397.31"
                                    clgpu[1].CLBandwidth=1.4514e+11
                                    clgpu[1].CLCompute=1503.31
                                    License Type: Subscription
                                    Serial number: 96040480527323851653
                                    GUIDBucket:
                                    Application folder: C:\Program Files\Adobe\Adobe Photoshop CC 2018\
                                    Temporary file path: C:\Users\Daddy\AppData\Local\Temp\
                                    Photoshop scratch has async I/O enabled
                                    Scratch volume(s):
                                      F:\, 1,82T, 1,38T free
                                      D:\, 3,64T, 964,9G free
                                    Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\Plug-Ins\
                                    Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CC 2018\Plug-Ins\
                                    Installed components:
                                       A3DLIBS.dll   A3DLIB Dynamic Link Library   9.2.0.112
                                       ACE.dll   ACE 2017/11/22-18:28:12   79.589342   79.589342
                                       AdbePM.dll   PatchMatch 2016/11/03:19:48:57   1.578146   1.578146
                                       AdobeLinguistic.dll   Adobe Linguisitc Library   10.0.0
                                       AdobeOwl.dll   Adobe Owl   5.2.11
                                       AdobePDFL.dll   PDFL 2017/10/31-06:12:59   79.250229   79.250229
                                       AdobePIP.dll   Adobe Product Improvement Program   7.4.1.109.46827
                                       AdobeSVGAGM.dll   AdobeSVGAGM   79.588619   79.588619
                                       AdobeXMP.dll   Adobe XMP Core 2017/07/13-01:06:39   79.160924   79.160924
                                       AdobeXMPFiles.dll   Adobe XMP Files 2017/07/13-01:06:39   79.160924   79.160924
                                       AdobeXMPScript.dll   Adobe XMP Script 2017/07/13-01:06:39   79.160924   79.160924
                                       adobe_caps.dll   Adobe CAPS   10,0,0,6
                                       AGM.dll   AGM 2017/11/22-18:28:12   79.589342   79.589342
                                       ahclient.dll    AdobeHelp Dynamic Link Library   3.0.0.6
                                       AIDE.dll   AIDE 2016/05/27-01:08:49   79.574279   79.574279
                                       amtlib.dll   AMTLib (64 Bit)   10.0.0.221 BuildVersion: 10.0; BuildDate: Tue Aug 1 2017 8:28:8)   1.000000
                                       ARE.dll   ARE 2017/11/22-18:28:12   79.589342   79.589342
                                       AXE8SharedExpat.dll   AXE8SharedExpat 2015/03/13-23:40:54   79.562390   79.562390
                                       AXEDOMCore.dll   AXEDOMCore 2015/03/13-23:40:54   79.562390   79.562390
                                       Bib.dll   BIB 2017/11/22-18:28:12   79.589342   79.589342
                                       BIBUtils.dll   BIBUtils 2017/11/22-18:28:12   79.589342   79.589342
                                       boost_date_time.dll   photoshopdva   11.1.0
                                       boost_filesystem.dll   photoshopdva   11.1.0
                                       boost_signals.dll   photoshopdva   11.1.0
                                       boost_system.dll   photoshopdva   11.1.0
                                       boost_threads.dll   photoshopdva   11.1.0
                                       cg.dll   NVIDIA Cg Runtime   3.0.00007
                                       cgGL.dll   NVIDIA Cg Runtime   3.0.00007
                                       CITThreading.dll   Adobe CITThreading   2.1.0.1   2.1.0.1
                                       CoolType.dll   CoolType 2017/11/22-18:28:12   79.589342   79.589342
                                       CRClient.dll   Adobe Crash Reporter Client DLL   1.6.3.0
                                       dnssd.dll   Bonjour   3,0,0,2
                                       dvaaudiodevice.dll   photoshopdva   11.1.0
                                       dvacore.dll   photoshopdva   11.1.0
                                       dvacrashhandler.dll   Adobe Audition CC 2017   10.0.0
                                       dvamarshal.dll   photoshopdva   11.1.0
                                       dvamediatypes.dll   photoshopdva   11.1.0
                                       dvametadata.dll   photoshopdva   11.1.0
                                       dvametadataapi.dll   photoshopdva   11.1.0
                                       dvametadataui.dll   photoshopdva   11.1.0
                                       dvaplayer.dll   photoshopdva   11.1.0
                                       dvatransport.dll   photoshopdva   11.1.0
                                       dvaui.dll   photoshopdva   11.1.0
                                       dvaunittesting.dll   photoshopdva   11.1.0
                                       dynamiclink.dll   photoshopdva   11.1.0
                                       ExtendScript.dll   ExtendScript 2017/08/31-12:13:14   81.1150526   81.1150526
                                       icucnv40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
                                       icudt40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
                                       icuuc40.dll   International Components for Unicode 2014/10/31-16:52:45    Build gtlib_6.0.21339
                                       igestep30.dll   IGES Reader   9.3.0.113
                                       imslib.dll   IMSLib DLL   10.0.0.22
                                       JP2KLib.dll   JP2KLib 2017/10/31-01:22:04   79.268591   79.268591
                                       libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
                                       libiomp5md.dll   Intel(R) OpenMP* Runtime Library   5.0
                                       libmmd.dll   Intel(R) C/C++/Fortran Compiler   17.0.0
                                       LogSession.dll   LogSession   7.4.1.109.46827
                                       mediacoreif.dll   photoshopdva   11.1.0
                                       MPS.dll   MPS 2017/10/31-01:22:04   79.588396   79.588396
                                       pdfsettings.dll   Adobe PDFSettings   1.04
                                       Photoshop.dll   Adobe Photoshop CC 2018   19.1.4
                                       Plugin.dll   Adobe Photoshop CC 2018   19.1.4
                                       PlugPlugExternalObject.dll   Adobe(R) CEP PlugPlugExternalObject Standard Dll (64 bit)   8.5.0
                                       PlugPlugOwl.dll   Adobe(R) CSXS PlugPlugOwl Standard Dll (64 bit)   8.5.0.87
                                       PSArt.dll   Adobe Photoshop CC 2018   19.1.4
                                       PSCloud.dll                                                   1.0.0.1
                                       PSViews.dll   Adobe Photoshop CC 2018   19.1.4
                                       SCCore.dll   ScCore 2017/08/31-12:13:14   81.1150526   81.1150526
                                       SVGRE.dll   SVGRE   79.586793   79.586793
                                       svml_dispmd.dll   Intel(R) C/C++/Fortran Compiler   17.0.0
                                       tbb.dll   Intel(R) Threading Building Blocks for Windows   2017, 0, 2017, 0118
                                       tbbmalloc.dll   Intel(R) Threading Building Blocks for Windows   2017, 0, 2017, 0118
                                       TfFontMgr.dll   FontMgr   9.3.0.113
                                       TfKernel.dll   Kernel   9.3.0.113
                                       TFKGEOM.dll   Kernel Geom   9.3.0.113
                                       TFUGEOM.dll   Adobe, UGeom©   9.3.0.113
                                       updaternotifications.dll   Adobe Updater Notifications Library   10.0.0.1 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   10.0.0.1
                                       VulcanControl.dll   Vulcan Application Control Library   5.3.0.16
                                       VulcanMessage5.dll   Vulcan Message Library   5.3.0.16
                                       WinRTSupport.dll   Adobe Photoshop Windows RT Support   19.0.0.0
                                       WRServices.dll   WRServices Thu June 21 2017 12:26:24   Build 0.22473   0.22473
                                       wu3d.dll   U3D Writer   9.3.0.113
                                    Required plug-ins:
                                       3D Studio 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “U3D.8bi”
                                       Accented Edges 19.1.4 - from the file “Filter Gallery.8bf”
                                       Adaptive Wide Angle 19.1.4 - from the file “Adaptive Wide Angle.8bf”
                                       Angled Strokes 19.1.4 - from the file “Filter Gallery.8bf”
                                       Average 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “Average.8bf”
                                       Bas Relief 19.1.4 - from the file “Filter Gallery.8bf”
                                       BMP 19.1.4 - from the file “Standard MultiPlugin.8bf”
                                       Camera Raw 10.3 - from the file “Camera Raw.8bi”
                                       Camera Raw Filter 10.3 - from the file “Camera Raw.8bi”
                                       Chalk && Charcoal 19.1.4 - from the file “Filter Gallery.8bf”
                                       Chrome 19.1.4 - from the file “Filter Gallery.8bf”
                                       Cineon 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “Cineon.8bi”
                                       Clouds 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “Clouds.8bf”
                                       Collada 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “U3D.8bi”
                                       Color Halftone 19.1.4 - from the file “Standard MultiPlugin.8bf”
                                       Colored Pencil 19.1.4 - from the file “Filter Gallery.8bf”
                                       CompuServe GIF 19.1.4 - from the file “Standard MultiPlugin.8bf”
                                       Conté Crayon 19.1.4 - from the file “Filter Gallery.8bf”
                                       Craquelure 19.1.4 - from the file “Filter Gallery.8bf”
                                       Crop and Straighten Photos 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “CropPhotosAuto.8li”
                                       Crop and Straighten Photos Filter 19.1.4 - from the file “Standard MultiPlugin.8bf”
                                       Crosshatch 19.1.4 - from the file “Filter Gallery.8bf”
                                       Crystallize 19.1.4 - from the file “Standard MultiPlugin.8bf”
                                       Cutout 19.1.4 - from the file “Filter Gallery.8bf”
                                       Dark Strokes 19.1.4 - from the file “Filter Gallery.8bf”
                                       De-Interlace 19.1.4 - from the file “Standard MultiPlugin.8bf”
                                       Dicom 19.1.4 - from the file “Dicom.8bi”
                                       Difference Clouds 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “Clouds.8bf”
                                       Diffuse Glow 19.1.4 - from the file “Filter Gallery.8bf”
                                       Displace 19.1.4 - from the file “Standard MultiPlugin.8bf”
                                       Dry Brush 19.1.4 - from the file “Filter Gallery.8bf”
                                       Eazel Acquire 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “EazelAcquire.8ba”
                                       Entropy 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “statistics.8ba”
                                       Export Color Lookup Tables 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “Export3DLUT.8be”
                                       Extrude 19.1.4 - from the file “Standard MultiPlugin.8bf”
                                       FastCore Routines 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “FastCore.8bx”
                                       Fibers 19.1.4 - from the file “Standard MultiPlugin.8bf”
                                       Film Grain 19.1.4 - from the file “Filter Gallery.8bf”
                                       Filter Gallery 19.1.4 - from the file “Filter Gallery.8bf”
                                       Flash 3D 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “U3D.8bi”
                                       Fresco 19.1.4 - from the file “Filter Gallery.8bf”
                                       Glass 19.1.4 - from the file “Filter Gallery.8bf”
                                       Glowing Edges 19.1.4 - from the file “Filter Gallery.8bf”
                                       Google Earth 4 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “U3D.8bi”
                                       Graphic Pen 19.1.4 - from the file “Filter Gallery.8bf”
                                       Halftone Pattern 19.1.4 - from the file “Filter Gallery.8bf”
                                       Halide Bottlenecks 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “HalideBottlenecks.8bx”
                                       HDRMergeUI 19.1.4 - from the file “HDRMergeUI.8bf”
                                       HSB/HSL 19.1.4 - from the file “Standard MultiPlugin.8bf”
                                       IFF Format 19.1.4 - from the file “Standard MultiPlugin.8bf”
                                       IGES 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “U3D.8bi”
                                       Ink Outlines 19.1.4 - from the file “Filter Gallery.8bf”
                                       JPEG 2000 19.1.4 - from the file “JPEG2000.8bi”
                                       Kurtosis 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “statistics.8ba”
                                       Lens Blur 19.1.4 - from the file “Lens Blur.8bf”
                                       Lens Correction 19.1.4 - from the file “Lens Correction.8bf”
                                       Lens Flare 19.1.4 - from the file “Standard MultiPlugin.8bf”
                                       Liquify 19.1.4 - from the file “Liquify.8bf”
                                       Matlab Operation 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “ChannelPort.8bf”
                                       Maximum 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “statistics.8ba”
                                       Mean 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “statistics.8ba”
                                       Measurement Core 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “MeasurementCore.8me”
                                       Median 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “statistics.8ba”
                                       Mezzotint 19.1.4 - from the file “Standard MultiPlugin.8bf”
                                       Minimum 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “statistics.8ba”
                                       MMXCore Routines 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “MMXCore.8bx”
                                       Mosaic Tiles 19.1.4 - from the file “Filter Gallery.8bf”
                                       Multiprocessor Support 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “MultiProcessor Support.8bx”
                                       Neon Glow 19.1.4 - from the file “Filter Gallery.8bf”
                                       Note Paper 19.1.4 - from the file “Filter Gallery.8bf”
                                       NTSC Colors 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “NTSC Colors.8bf”
                                       Ocean Ripple 19.1.4 - from the file “Filter Gallery.8bf”
                                       OpenEXR 19.1.4 - from the file “Standard MultiPlugin.8bf”
                                       Paint Daubs 19.1.4 - from the file “Filter Gallery.8bf”
                                       Palette Knife 19.1.4 - from the file “Filter Gallery.8bf”
                                       Patchwork 19.1.4 - from the file “Filter Gallery.8bf”
                                       Paths to Illustrator 19.1.4 - from the file “Standard MultiPlugin.8bf”
                                       PCX 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “PCX.8bi”
                                       Photocopy 19.1.4 - from the file “Filter Gallery.8bf”
                                       Photoshop 3D Engine 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “Photoshop3DEngine.8bi”
                                       Photoshop Touch 19.0 - from the file “PSDX.8bi”
                                       Picture Package Filter 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “ChannelPort.8bf”
                                       Pinch 19.1.4 - from the file “Standard MultiPlugin.8bf”
                                       Pixar 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “Pixar.8bi”
                                       Plaster 19.1.4 - from the file “Filter Gallery.8bf”
                                       Plastic Wrap 19.1.4 - from the file “Filter Gallery.8bf”
                                       PLY 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “U3D.8bi”
                                       Pointillize 19.1.4 - from the file “Standard MultiPlugin.8bf”
                                       Polar Coordinates 19.1.4 - from the file “Standard MultiPlugin.8bf”
                                       Portable Bit Map 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “PBM.8bi”
                                       Poster Edges 19.1.4 - from the file “Filter Gallery.8bf”
                                       PRC 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “U3D.8bi”
                                       Radial Blur 19.1.4 - from the file “Standard MultiPlugin.8bf”
                                       Radiance 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “Radiance.8bi”
                                       Range 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “statistics.8ba”
                                       Render Color Lookup Grid 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “Export3DLUT.8be”
                                       Reticulation 19.1.4 - from the file “Filter Gallery.8bf”
                                       Ripple 19.1.4 - from the file “Standard MultiPlugin.8bf”
                                       Rough Pastels 19.1.4 - from the file “Filter Gallery.8bf”
                                       Save for Web 19.1.4 - from the file “Save for Web.8be”
                                       ScriptingSupport 19.1.4 - from the file “ScriptingSupport.8li”
                                       Shake Reduction 19.1.4 - from the file “Shake Reduction.8bf”
                                       Shear 19.1.4 - from the file “Standard MultiPlugin.8bf”
                                       Skewness 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “statistics.8ba”
                                       Smart Blur 19.1.4 - from the file “Standard MultiPlugin.8bf”
                                       Smudge Stick 19.1.4 - from the file “Filter Gallery.8bf”
                                       Solarize 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “Solarize.8bf”
                                       Spaces 19.1.4 - from the file “Spaces.8li”
                                       Spatter 19.1.4 - from the file “Filter Gallery.8bf”
                                       Spherize 19.1.4 - from the file “Standard MultiPlugin.8bf”
                                       Sponge 19.1.4 - from the file “Filter Gallery.8bf”
                                       Sprayed Strokes 19.1.4 - from the file “Filter Gallery.8bf”
                                       Stained Glass 19.1.4 - from the file “Filter Gallery.8bf”
                                       Stamp 19.1.4 - from the file “Filter Gallery.8bf”
                                       Standard Deviation 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “statistics.8ba”
                                       STL 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “U3D.8bi”
                                       Sumi-e 19.1.4 - from the file “Filter Gallery.8bf”
                                       Summation 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “statistics.8ba”
                                       Targa 19.1.4 - from the file “Standard MultiPlugin.8bf”
                                       Texturizer 19.1.4 - from the file “Filter Gallery.8bf”
                                       Tiles 19.1.4 - from the file “Standard MultiPlugin.8bf”
                                       Torn Edges 19.1.4 - from the file “Filter Gallery.8bf”
                                       Twirl 19.1.4 - from the file “Standard MultiPlugin.8bf”
                                       U3D 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “U3D.8bi”
                                       Underpainting 19.1.4 - from the file “Filter Gallery.8bf”
                                       Vanishing Point 19.1.4 - from the file “VanishingPoint.8bf”
                                       Variance 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “statistics.8ba”
                                       Virtual Reality Modeling Language | VRML 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “U3D.8bi”
                                       Water Paper 19.1.4 - from the file “Filter Gallery.8bf”
                                       Watercolor 19.1.4 - from the file “Filter Gallery.8bf”
                                       Wave 19.1.4 - from the file “Standard MultiPlugin.8bf”
                                       Wavefront|OBJ 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “U3D.8bi”
                                       WIA Support 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “WIASupport.8li”
                                       Wind 19.1.4 - from the file “Standard MultiPlugin.8bf”
                                       Wireless Bitmap 19.1.4 (20180507.r.325 2018/05/07: 1170750) - from the file “WBMP.8bi”
                                       ZigZag 19.1.4 - from the file “Standard MultiPlugin.8bf”
                                    Optional and third party plug-ins:
                                       Lazy Nezumi Pro 17.10.20.1526 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Plug-Ins\MouseHookPro64.8li”
                                    Duplicate and Disabled plug-ins: NONE
                                    Plug-ins that failed to load: NONE
                                    Extensions:
                                       com.adobe.inapp.purchase  2.13.141 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_2_13_141\purchaseStock.html”
                                       Libraries  2.13.141 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_2_13_141\index.html”
                                       com.adobe.inapp.typekit.purchase  1.0.0 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\CC_LIBRARIES_PANEL_EXTENSION_2_13_141\purchaseTypekit.html”
                                       Start  2.2.1 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\com.adobe.ccx.start-2.2.1\index.html?v=2.2.1.67”
                                       Coolorus 2․5  2.5.12 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\com.moongorilla.coolorus2\index.html”
                                       Export As  3.1.2 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.photoshop.crema\PSPanel\dialog.html”
                                       com.adobe.Butler.backend  2.0.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.Butler.backend\index.html”
                                       New Document  2.2.1 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\com.adobe.ccx.fnft-2.2.1\fnft.html?v=2.2.1.30”
                                       Adobe Color Themes  6.1.0 - from the file “C:\Program Files\Adobe\Adobe Photoshop CC 2018\Required\CEP\extensions\com.adobe.KulerPanel.html\index.html”
                                       Brusherator Preview  1.0.0 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\com.kritskiy.previewrator\index.html”
                                       Brusherator  1.2.0 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\com.kritskiy.brusherator\index.html”
                                       Prisma Palette Beta 5  0.1.0 - from the file “C:\Users\Daddy\AppData\Roaming\Adobe\CEP\extensions\com.colourconstructor.prismapalette\ html\index.html”
                                       Brusherator Plus  1.2.1 - from the file “C:\Program Files (x86)\Common Files\Adobe\CEP\extensions\com.kritskiy.bt_a\index.html”
                                    Installed TWAIN devices: NONE
                                    • 15. Re: Puppet warp greyed out
                                      Hi
                                      You are shown as having two GPUs (Intel and NVIdia) which will have different drivers. This is known to cause issues with Photoshop. Photoshop works well with multiple monitors (I use three) provided those monitors are driven by a single GPU.
                                      See sections 7 and 8 here:
                                      Troubleshoot Photoshop graphics processor (GPU) and graphics driver issues
                                      Dave
                                      2 people found this helpful
                                      • 16. Re: Puppet warp greyed out
                                        Copypaste from another thread:
                                        "Ok, this is weird and I don't know how it worked, but it did.
                                        After changing my setup from 3 to 2 monitors, it looks like for some error my PC assigned my integrated GPU to my Cintiq, or maybe Nvidia had troubles working with my tablet. I uninstalled the Nvidia GPU drivers completely and unplugged HDMI port cables, then reinstalled Nvidia Drivers, switched off and pluged back HDMI. After restarting and updating Windows 10 all is working.
                                        I don't know if it was a software problem related to HDMI ports somehow, Nvidia, or...Maybe it's been some kind of black magic?
                                        Thanks for the assistance tho.
                                        The solution for my problem could be useful for all multiple monitor users (Wacom Tablets count): be sure to have your dedicated GPU assigned to both your monitors!
                                        Thanks Ged Traynor and davescm
                                        • 17. Re: Puppet warp greyed out
                                          Yes - multiple monitors work well but multiple GPUs do not.
                                          Glad you have it working now
                                          Dave
