I have the latest update 18.011.20040 for Adobe Acrobat Reader DC. Keep getting the error message (523:523) indicating I have Adobe already open, but it is not. I have restarted my computer many times, tried to update, and also to fix the program. Also tried to uninstall but it would not allow that function. Help. I must print off documents but I am stuck.
[moved from Adobe Creative Cloud to Acrobat Reader]
Hi Kk24fan,
As the error message indicating that the application is already open, open the task manager and close all the background process running for Reader.
Then reboot the machine and then check if you can open the application or not.
If that does not help, end all the task for Reader in task manager and run the cleaner tool on the machine.
Restart your machine and then re-install the latest version from here Adobe - Adobe Acrobat Reader DC Distribution
Hope it helps.
If the issue still persists, please share the following details:
- OS version installed on the machine.
- Did you make any changes after which you start receiving the error message?
Let us know if you need any help.
Regards,
Meenakshi
Thanks for the information. I will try later today when I get home.
On Thu, May 17, 2018, 3:07 AM meenakshin83966505 <forums_noreply@adobe.com>
Hello, tried going to task manager, not sure what to do. I did download the link you provided, and restarted the computer, and it still showed the same error. So, when i open up the "Task Manager" do i end all tasks of Adobe.?
