• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Embed a Captivate HTML 5 output in WebHelp Pro project
Engaged ,
May 17, 2018 May 17, 2018
Hi there,
I am trying to Insert a Captivate HTML 5 output in a project.
I can choose the option HTML5 in the window when inserting Captivate piece but when choosing the index.html file I end up with a placeholder swf file inserted. Is that normal?
Thank you in advance
B
Views
252
Translate
Translate
Report
Report
Community guidelines
community guidelines
Community Expert ,
What version of RH? Are you hosting your output on a server running RHServer? That's what the Pro form is intended for - it's not to be used with non-RHServer instances. Are you looking at the index in the output or are you talking about the HTML in the topic where the Captivate output was inserted?
Votes
Translate
Translate
Report
Report
Engaged ,
Thanks Jeff,
The version is 2015
We are hosting the output on a server running RH Server. I am inserting the index file in the root folder of the Captivate output.
By the way I checked and it does work when I export from RH to Responsive HTML5.
Just wanted to check if WebHelp Pro can be used with HTML 5 captivate outputs.
Votes
Translate
Translate
Report
Report
Community Expert ,
A quick test would be to try it with regular WebHelp too & see what comes out.
Votes
Translate
Translate
Report
Report
Engaged ,
I tried it and what I can see is only the placeholder with the Captivate playbar.
Votes
Translate
Translate
Report
Report
LEGEND ,
Hi there
Indeed, whether you are producing WebHelp or WebHelp Pro, the placeholder SWF is totally normal.
I can't explain exactly why that placeholder is used, but when you insert Captivate HTML 5, the process combines all the assorted Captivate files and folders into a zip format and adds that to RoboHelp. Then when you generate it knows how to unpack that for proper usage on the destination server.
Cheers... Rick
Votes
Translate
Translate
Report
Report
Community Expert ,
LATEST
Oh, so we're talking about the RH project topic's appearance? I thought the OP was referring to the generated output..
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
