6 Replies Latest reply on May 22, 2018 9:06 AM by srishtib8795206
    Printer Profile
    radicalrob Level 1
      I've never had issues before when printing but for some reason now when I print the colors are majorly inconsistent.  Purples look blue, Greens look teal, etc.
      I'd like to be able to use the correct printer profile in Indesign but not sure which would be the best to use.
      I'm using an HP MFP M278 printer, and I also have an Epson Stylus Pro 4900 for posters.
      How would I go about configuring InDesign to use the most accurate color settings for both printers? I see so many options and tried quite a few of them but still wonky results.
      Thanks!
        • 1. Re: Printer Profile
          Derek Cross Adobe Community Professional
          Are you printing from a PDF created from your InDesign document?
          • 2. Re: Printer Profile
            srishtib8795206 Adobe Employee
            Hi Rob,
            As per your query when you print from InDesign colors are inconsistent. Could you please check how colors look on screen if your export file to Print PDF?
            Please try these steps:
            File > Export > Print PDF > Choose PDF/X-1a:2001 PDF preset
            Regards,
            Srishti
            • 3. Re: Printer Profile
              Bevi Chagnon | PubCom Adobe Community Professional
              When colors shift so dramatically, it usually indicates a problem with color management (what you see on the screen versus what is printed on various printers). Also, converting from RGB to CMYK can cause this, too.
              InDesign Secrets Magazine has some good basic instructions about color management that you might find helpful: https://indesignsecrets.com/indesign-color-management.php
              and this recent post in the forums discusses similar issues: Color management issues in PDFs destined for desktop printing
              • 4. Re: Printer Profile
                ceyhun_akgun Adobe Community Professional
                You can choose a profile that conforms to FOGRA 39 or Fogra 51 standard.
                Simply select the relevant option from the Bridge Color Settings settings and sync.
                Profiles are a very comprehensive issue. It's enough to use the standard settings.
                If you are using the RGB color mode, your colors will always be inconsistent. In Photoshop you should use the correct profile when converting from RGB to CMYK.
                When you command Print in Indesign, you can also select which profile you want to print.
                I use the / Europe Prepress 3 option via Bridge. When I synchronize, the settings are synchronized in InDesign, Photoshop, and Illustrator.
                • 5. Re: Printer Profile
                  Per Berntsen Adobe Community Professional
                  Documents printed on desktop printers should be in RGB, these printers do their own conversion to CMYK.
                  Printing CMYK documents will lead to a "double conversion", and may result in wrong colors.
                  When you install a printer, several printer profiles are usually installed, and you should pick the one with the correct printer model - paper combination. If you use a non-Epson paper on the Epson printer, check if the paper manufacturer has a profile for your printer. If not, you will have to experiment, and try to find one that works.
                  Alternatively, you can let the printer manage colors, this may also require some experimenting.
                  I am not familiar with the HP MFP M278, but it seems to be quite basic, and as far as I can tell, there aren't any printer profiles for it.
                  2 people found this helpful
                  • 6. Re: Printer Profile
                    Hi Rob,
                    I would like to know if the above mentioned suggestions worked for you, or the issue still persists.
                    Kindly update the discussion if you need further assistance with it.
                    Srishti
