2 Replies Latest reply on May 18, 2018 3:21 AM by Laubender Branched to a new discussion.
    How to select characterStyles panel "[none]"
    sk88746243 Level 1
      Hi friends,
      Just, I need to select "characterStyles panel [none]". Here with i have search properties for select option. But, not there.
      Please suggest friends!
      SK
        • 1. Re: How to select characterStyles panel "[none]"
          Derek Cross Adobe Community Professional
          Window > Styles > Character Styles (see screen shot);  If it doesn't appear reset your InDesign Preferences.
          • 2. Re: How to select characterStyles panel "[none]"
            Hi SK,
            don't know if something went wrong by moving the thread over to InDesign Scripting.
            I already replied to your question how to address character style named [None]. I will repeat my answer here:
            var charStyleNone = app.activeDocument.characterStyles[0];
            var c = 0;
            for( x in charStyleNone )
                try{
                $.writeln( c+"\t"+x +"\t"+ charStyleNone[x].toString() );
                }catch(e)
                    for( y in e )
                        $.writeln(c+"\t"+"ERROR"+"\t"+y+"\t"+e[y].toString() );
                c++
            The snippet above tries to list property/value pairs of Character Style [None]. Run it from the ESTK. It will return also some error messages. All messages, not only the error ones are listed in the JavaScript Console of the ESTK.
            You'll find, that the value of most properties is: NOTHING
            Here an excerpt from the result when run against an InDesign CC 2018.1 document as the active one. From my German InDesign.
            A message like: "Ungültige Anforderung für Stammformat." points at:  $ID/InvalidRequestForRootStyleError
            0    imported    false
            1    ERROR    number    516
            1    ERROR    fileName    (Script1)
            1    ERROR    line    8
            1    ERROR    source    var charStyleNone = app.activeDocument.characterStyles[0];
            var c = 0;
                try{
                }catch(e)
                    for( y in e )
                c++
            1    ERROR    start    -1
            1    ERROR    end    -1
            1    ERROR    message    Ungültige Anforderung für Stammformat.
            1    ERROR    name    Error
            1    ERROR    description    Ungültige Anforderung für Stammformat.
            2    appliedFont
            3    fontStyle    NOTHING
            4    pointSize    NOTHING
            5    leading    NOTHING
            6    kerningMethod    NOTHING
            7    tracking    NOTHING
            8    capitalization    NOTHING
            9    position    NOTHING
            10    underline    NOTHING
            11    strikeThru    NOTHING
            12    ligatures    NOTHING
            13    noBreak    NOTHING
            14    horizontalScale    NOTHING
            15    verticalScale    NOTHING
            16    baselineShift    NOTHING
            17    skew    NOTHING
            18    fillTint    NOTHING
            19    strokeTint    NOTHING
            20    strokeWeight    NOTHING
            21    overprintStroke    NOTHING
            22    overprintFill    NOTHING
            23    otfFigureStyle    NOTHING
            24    otfOrdinal    NOTHING
            25    otfFraction    NOTHING
            26    otfDiscretionaryLigature    NOTHING
            27    otfTitling    NOTHING
            28    otfContextualAlternate    NOTHING
            29    otfSwash    NOTHING
            30    ERROR    number    21
            30    ERROR    fileName    (Script1)
            30    ERROR    line    8
            30    ERROR    source    var charStyleNone = app.activeDocument.characterStyles[0];
            var c = 0;
                try{
                }catch(e)
                    for( y in e )
                c++
            30    ERROR    start    0
            30    ERROR    end    0
            30    ERROR    message    null is not an object
            30    ERROR    name    TypeError
            30    ERROR    description    null is not an object
            31    ERROR    number    21
            31    ERROR    fileName    (Script1)
            31    ERROR    line    8
            31    ERROR    source    var charStyleNone = app.activeDocument.characterStyles[0];
            var c = 0;
                try{
                }catch(e)
                    for( y in e )
                c++
            31    ERROR    start    0
            31    ERROR    end    0
            31    ERROR    message    null is not an object
            31    ERROR    name    TypeError
            31    ERROR    description    null is not an object
            32    underlineTint    NOTHING
            33    underlineGapTint    NOTHING
            34    underlineOverprint    NOTHING
            35    underlineGapOverprint    NOTHING
            122    rubyFontStyle    NOTHING
            123    rubyFontSize    NOTHING
            124    rubyOpenTypePro    NOTHING
            125    rubyXScale    NOTHING
            126    rubyYScale    NOTHING
            127    rubyType    NOTHING
            128    rubyAlignment    NOTHING
            129    rubyPosition    NOTHING
            130    rubyXOffset    NOTHING
            131    rubyYOffset    NOTHING
            132    rubyParentSpacing    NOTHING
            133    rubyAutoAlign    NOTHING
            134    rubyOverhang    NOTHING
            135    rubyAutoScaling    NOTHING
            136    rubyParentScalingPercent    NOTHING
            137    rubyParentOverhangAmount    NOTHING
            138    warichu    NOTHING
            139    warichuSize    NOTHING
            140    warichuLines    NOTHING
            141    warichuLineSpacing    NOTHING
            142    warichuAlignment    NOTHING
            143    warichuCharsAfterBreak    NOTHING
            144    warichuCharsBeforeBreak    NOTHING
            145    otfProportionalMetrics    NOTHING
            146    otfHVKana    NOTHING
            147    otfRomanItalics    NOTHING
            148    scaleAffectsLineHeight    NOTHING
            149    cjkGridTracking    NOTHING
            150    glyphForm    NOTHING
            151    rubyAutoTcyDigits    NOTHING
            152    rubyAutoTcyIncludeRoman    NOTHING
            153    rubyAutoTcyAutoScale    NOTHING
            154    id    118
            155    label
            156    isValid    true
            157    parent    [object Document]
            158    index    0
            159    properties    [object Object]
            160    styleExportTagMaps    [object StyleExportTagMaps]
            161    events    [object Events]
            162    eventListeners    [object EventListeners]
            163    isValid    true
            Regards,
            Uwe
